Asus strix z490-g gaming wifi bricked after bios update
  • keeper5511
    • May 2024
    • 20
    • Ελλάδα
    I have a motherboard Asus strix Z490- g Gaming wifi and a 10th gen CPU. I have update BIOS to 2701 version but then I realized that I needed to update the ME firmware first. I didn't read the ASUS notice that said, "Before BIOS update, please download Intel ME update tool from ASUS support site. I updated the BIOS without doing this, and everything seemed fine until the system performed an Intel ME update and shut down permanently. Now the motherboard have "No power issue" and it seems dead!!! My attempts to reflash it were unsuccessful. Searching online, I found several people who had the same issue, and some of them resolved it with a ch341a. Does anyone have the proper ME firmware so I can reflash it on 8mb chip?
  • DynaxSC
    • Apr 2021
    • 540
    • Poland
    You can't just reflash only the ME into the bios with ch341. Ch341 can't write part of the spi chip, only the whole image. What you need to do is: 1. Backup current bios image from the spi chip to disk, 2. Download a stock bios image from Asus site which has inside a next lower ME version included, this will be in a lower bios version, but not necessarily in the first lower bios version, 3. Extract the ME from this stock bios, 4. Exchange the ME in the bios image you backuped from the spi chip, 5. Program this image with exchanged ME back to the spi chip, 6. Repeat steps 2-5 with next lower version ME's until you get a match between the ME version in the bios and the version the chipset expects and accepts.
    This process is the only way to preserve the DMI data and MAC address in the bios, which is unique for each motherboard. If you just program a stock bios image to the spi chip you will loose this DMI data for ever, eg. having no valid MAC address, no UUID, no serial no, etc.
    For viewing / editing bios image you can use UEFI Tool and UEFI Tool NE or any other tool which allows to make such operations. This is somewhat demanding, but there are good instruction how to do this to be found in the internet or just ask AI.
    You can also find all possible ME versions on station-drivers site, but the issue with ASUS is that their ME's are usually not standard Intel provided ME. ASUS does often customize their ME's, so stock Intel ME's not always work fully, eg. some M.2 ports not working, or other weird issues. That's why is is better to extract the ME from a stock ASUS bios image or alternatively from the ME update software packages provided on ASUS support site.
    If all this does not work due to ME mismatch between bios and chipset you will probably have to program the first stock bios version to the spi chip, having before or after transferred the DMI data and MAC from the backup BIOS image to the first stock bios image. The first BIOS version on ASUS boards has often the ability to reinitialise the chipset on the first run to accept a new ME (a factory initialisation process). There are also Intel CSME tools which can modify any bios image to do this, but this is a process demanding lot of advanced technical knowledge, not easy to do due to lack of any publicly available instructions. Make sure you have a proper CPU supported by this first bios version.
    • keeper5511
      • May 2024
      • 20
      • Ελλάδα
      Thank you for reply. 2 questions:
      1) I have uefi tool but how do I extract the ME from this stock bios?
      2)Are you sure second BIOS chip (8mb) has only ME firmware on it?
      • Tesla
        • Jul 2011
        • 146
        Why isn't the Asus BIOS-FlashBack (low-level switch) function working?
        • keeper5511
          • May 2024
          • 20
          • Ελλάδα
          Hello! Led is steady and when I press the flash button, led flashes one time and becomes steady again. I have used many USB sticks with many BIOS files with NO result. I don't understand the reason....
          • Tesla
            • Jul 2011
            • 146
            Work this problem as it should always work in an emergency.
            Verify Directions from a real Asus manual
            Try smaller 2gb or 8gb flash-drive.
            Be sure just normal partitioning and FAT32 formatted.
            Verify your recover file is correct and in the expected format.
            • keeper5511
              • May 2024
              • 20
              • Ελλάδα
              I am using 8gb flash-drive with normal partitioning and FAT32 formatted.
              The file has been downloaded from https://rog.asus.com/motherboards/ro...helpdesk_bios/
              and has been renamed using BIOSRenamer. Some people say ME firmware of the current chip (8MB) may be corrupted and as a result motherboard reject flashing original BIOS. I have never face such a problem in the past....
              • Tesla
                • Jul 2011
                • 146
                Sounds appropriate. I suggest you step-back, and then try again ...
                Because (like the similar MSI tech on my Intel-i9 desktops) it's designed to work in circumstance of Emergency Recovery like this. If fact, that's ALL it was designed and implemented for (not really even for normal BIOS-Firmware updates).
                As an aside ... when MSI, Asus/ASrock makes motherboards for Dell, Alienware, or HP ... they DO-NOT include this functionality. It's reserved only for their real (full featured) "retail" boards.
                  • 23881
                  Did you read tbout that at the win-raid forum https://winraid.level1techs.com/t/so...lashback/37997
                  Buy a CH341A and a clip and post your backups
                  • keeper5511
                    • May 2024
                    • 20
                    • Ελλάδα
                    I already have CH341A for programming. I just dont understand the procedure so I can prepare the proper files to flash (16mb chip and 8mb chip).....
                    • peste
                      • 15170
                      • ROMANIA
                      The bios chip must be unsoldered from the board before writing or reading..
                      do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                      solder wires between the programmer and the bios chip..
                      you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                      If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
                      It only takes 1 minute:
                      https://www.badcaps.net/settings/subscriptions
                      • keeper5511
                        • May 2024
                        • 20
                        • Ελλάδα
                        I have already flash with programmer main BIOS (16mb) version 2701 after I have remove header. The problem is that I dont know if the Me BIOS firmware from it is the correct one with the secondary BIOS chip (8MB) which has this file on it. Furthermore I dont know why some people clean main BIOS file (dump) and then flash it again...
                          • 23881
                          Post your backups and we can have a look at them.
                          • m1ch43lzm
                            • Mar 2019
                            • 2173
                            • Peru
                            Descriptor + ME region is on the 8MB chip, it can be extracted from the ASUS .cap, it's hidden compressed inside another compressed section of the BIOS region...
                            The extracted .cap goes to the 16MB chip, best to transfer DMI from the original backup before blindly flashing anything
                            Make a backup of the 8MB chip, and try this file (extracted from BIOS 2601), ME version 14.1.51.1528
                            Also upload your backup of the 16MB chip before you flashed 2701 with the CH341A (you should have made a backup before flashing it)
                            • keeper5511
                              • May 2024
                              • 20
                              • Ελλάδα
                              Thank you very much. I will try to flash that one in 8mb SPI chip. I have upload the BIOS files (both dumps and the stock one I have already flashed at Main SPI chip).
                              • keeper5511
                                • May 2024
                                • 20
                                • Ελλάδα
                                I think that 2701 stock BIOS needs Version 14.1.53.1649V1.1
                                “Before BIOS update, please download Intel ME update tool from ASUS support site, and update ME firmware to Version 14.1.53.1649V1.1 to ensure optimized system settings.”
                                Are you sure ME version 14.1.51.1528 is ok for 2701 main BIOS???
                                And why are there so many errors at this file (extracted from BIOS 2601)???
                                ║ 2601 8MB ME.bin (1/1) ║
                                ║ Family │ CSE ME ║
                                ║ Version │ 14.1.51.1528 ║
                                ║ Release │ Production ║
                                ║ Type │ Region, Extracted ║
                                ║ SKU │ Consumer H ║
                                ║ Chipset │ Unknown ║
                                ║ TCB Security Version Number │ 1 ║
                                ║ ARB Security Version Number │ 8 ║
                                ║ Version Control Number │ 9 ║
                                ║ Production Ready │ Yes ║
                                ║ OEM RSA Signature │ No ║
                                ║ OEM Unlock Token │ No ║
                                ║ FWUpdate Support │ No ║
                                ║ Date │ 2020-11-24 ║
                                ║ File System State │ Unconfigured ║
                                ║ Size │ 0x6E000 ║
                                ║ Flash Image Tool │ 14.0.51.1528 ║
                                ║ Latest │ Yes ║
                                ║ Power Management Controller ║
                                ║ Family │ PMC ║
                                ║ Version │ 140.2.01.1018 ║
                                ║ Type │ Independent ║
                                ║ Chipset SKU │ H ║
                                ║ Chipset Stepping │ A ║
                                ║ TCB Security Version Number │ 3 ║
                                ║ ARB Security Version Number │ 3 ║
                                ║ Version Control Number │ 0 ║
                                ║ Date │ 2021-02-22 ║
                                ║ Size │ 0x14000 ║
                                ║ Chipset Support │ CMP ║
                                ║ Latest │ Yes ║
                                Error: MFS Scratch Page 0 Header CRC-8 is INVALID!
                                Error: MFS Scratch Page 4294967295 Header CRC-8 is INVALID!
                                Error: MFS final System Area Buffer is empty!
                                Warning: The detected SKU Platform may be unreliable!
                                Warning: Data in Engine region padding, possible data corruption!
                                Note: This PMC CMP firmware was not found at the database, please report it!
                                Note: This CSE ME firmware was not found at the database, please report it!
                                • Sparo
                                  Quicksilver
                                  • Jan 2022
                                  • 2026
                                  • M\A
                                  • Anime, Edge Computing, Football, Snooker
                                  keeper5511
                                  Hi use the latest MEAnalyzer it won't show any of those MFS related errors
                                  And Post the serial number of the machine (I can't find DMI in your original backup and also it's the rules)
                                  Enjoying our forum? Help keep it running and unlock extra perks!
                                  >> Upgrade here <<
                                  • keeper5511
                                    • May 2024
                                    • 20
                                    • Ελλάδα
                                    What do you mean serial number of the machine? Where I can find it?
                                    • Sparo
                                      Sparo commented
                                      Editing a comment
                                      There is no sticker or barcode on the motherboard with SN/SID on it? or a small QR code?
                                      Normally it's also on the packaging box but I don't know if you still have that
                                  • keeper5511
                                    • May 2024
                                    • 20
                                    • Ελλάδα
                                    Serial Number is 677318-00420-MB1300-A11 0403
                                    I am going to try and flash this file (extracted from BIOS 2601), ME version 14.1.51.1528 right now....
                                    • Sparo
                                      Sparo commented
                                      Editing a comment
                                      That ID is for the motherboard the S/N should look like L9M0AB123456 or L7M0AB123456 or K2M0CV12345678 etc
                                  • keeper5511
                                    • May 2024
                                    • 20
                                    • Ελλάδα
                                    Unfortunately problem remains. No reaction to the power button!!! And also cant use BIOS flashback....
                                    • ronaldopdias
                                      ASUS ROG Strix B660-I Gaming WiFi – BIOS dump vs ASUS CAP size mismatch, need corruption check, please.
                                      by ronaldopdias
                                      I’m troubleshooting an ASUS ROG Strix B660-I Gaming WiFi motherboard and I’m a bit stuck at the BIOS level. What I’ve tried so far
                                      • Attempted to flash the BIOS using the USB BIOS FlashBack (Q-Flash) port with a properly formatted FAT32 USB drive.
                                      • BIOS file downloaded directly from the official ASUS support page.
                                      • Followed the exact FlashBack procedure (correct port, renamed file, standby power only).
                                      Issue:
                                      The FlashBack LED does not blink at all — no activity whatsoever. Further investigation
                                      Because FlashBack didn’t work, I:
                                      • Removed the BIOS SPI IC from
                                      02-04-2026, 03:16 AM
                                    • akwky
                                      by akwky
                                      Hi!
                                      04-14-2025, 01:56 PM
                                    • razor_amd
                                      by razor_amd
                                      12-15-2020, 07:07 PM
                                    • Technodoc
                                      ASUS G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
                                      by Technodoc
                                      Asus laptop G614JZ-N3012W Rog Strix with i7
                                      Mainboard G634J-PMV-VGT
                                      6050A3441302-MB-A01
                                      2023-02-10
                                      Power button works okay....power light goes on
                                      Red "bottom" leds go on
                                      Charging led works
                                      Fans do not spin, capslock key does nothing, screen stays black
                                      I would like to program the bios again, to rule out a corrupted bios.
                                      However I run into a size error
                                      The bios chip is a Winbond 25R256JVEN
                                      Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
                                      02-24-2025, 04:46 AM
                                    • Corey Barkley
                                      Asus ROG Strix Scar 17 G733ZX-DS94 Need fresh bios forgot password
                                      by Corey Barkley
                                      Device: Laptop
                                      Brand: Asus
                                      Model: G733ZX-DS94
                                      CN: DK3L
                                      Motherboard: G533R-PMV-VGT 6050A3340404-MB-A01
                                      SN: N2NRKD008429084
                                      Request: BIOS dump
                                      Problem: Forgot Password
                                      I need fresh bios i forgot the password but i have been able to get the bios dump using CH341A so just need the new bios without password....
                                      04-20-2026, 09:03 PM
