Unlock Request: HP Elite Mini 8 G1a (Product B02PXAV) - BIOS Password Removal / Clean ME
  • rbdealmeida
    • Mar 2026
    • 9
    • Portugal
    My name is Ricky and I'm a repair technician/enthusiast. I've been learning a lot from this community and have successfully done some basic BIOS unlocks in the past, but this particular modern HP model is giving me a really hard time!
    I need some help manually removing the BIOS administrator password from this machine.
    I have already tried using the "HP G9 Unlocker V3.0" on my 32MB dump. I successfully bypassed the U68 Sure Start chip (SPI NAND) by isolating Pin 8, preventing the auto-recovery. The machine boots and bypasses Sure Start, but when I press F10, it still asks for the password. It seems the automated tool failed to locate and patch the password hash for this specific Mini Desktop model.
    Could someone please help me manually clear the password and clean the ME region on my original dump?
    Here are the exact details of the machine:
    Model: Desktop HP EliteDesk 8 Mini G1a IDS
    Serial Number (SN): 1HF5420L66
    Product Number (PN): B02PXAV
    Main BIOS Chip (U19): Macronix MX25U25672GZ4I40 (32MB / 256Mbit, 1.8V NOR)
    Sure Start Chip (U68): Macronix MX35UF1GE4AD (128MB, 1.8V NAND) - Currently bypassed (shunt between pin 2 and 4).
    I have attached my ORIGINAL locked 32MB U19 dump read with NeoProgrammer.
    Thank you very much in advance for your time and help!
  • shiyab
    • Sep 2023
    • 3094
    • india
    Originally posted by rbdealmeida
    POST og backup bios both need
    • rbdealmeida
      • Mar 2026
      • 9
      • Portugal
      Hi shiyab, thanks for replying!
      By "both", do you mean the U19 dump and the U68 dump? Or do you mean the Original U19 dump and the G9 Unlocker modified dump?
      ​If you mean the U68 chip, unfortunately, I cannot read it right now because it is an SPI NAND (MX35UF1GE4AD) and my basic CH341A programmer (with NeoProgrammer) doesn't seem to support it. That is why I am currently bypassing the U68 using the hardware shunt method.
      However, if the U68 dump is absolutely necessary to clear the password, do you know of any alternative software or trick that allows the CH341A to read this specific NAND chip?
      The ZIP file attached to my first post contains the ORIGINAL U19 (32MB) dump.
      Do you think you can clear the password using only this U19 file (since U68 is currently bypassed)? Let me know how I should proceed!
      Thanks a lot.
      • shiyab
        • Sep 2023
        • 3094
        • india
        nedd 16mb og backup
        • rbdealmeida
          • Mar 2026
          • 9
          • Portugal
          Hi shiyab,
          Thank you for your patience while I performed the hardware analysis and data extraction.
          I have completed the dumping process for both the U19 (32MB Macronix) and the U68 (128MB Macronix NAND). To ensure 100% data integrity, I performed three separate read passes for each chip. I am pleased to confirm that all three hashes (MD5) match perfectly for both chips, so the attached dumps are verified and reliable.
          Regarding your request for a 16MB chip: I have meticulously inspected both the front and back of the motherboard and there is no 16MB SPI chip on this board. The only relevant firmware chips present are the U19 and U68.
          As this is a very recent model (HP EliteDesk Mini G1a, 2025 architecture), it seems HP has updated the layout, moving away from the older 32MB+16MB configuration. I am attaching high-resolution photos of both sides of the motherboard to confirm this for your reference.
          U19_32MB_Original_Verified.zip (Main BIOS)
          U68_128MB_NAND_Original_Verified.zip (Sure Start / Security)
          Motherboard_Photos_Front_Back.zip
          Original Specifications.zip
          With these full sets of verified data, could you please check if you can patch the firmware to clear the administrator password?
          Thank you very much for your time and expertise.
          • shiyab
            • Sep 2023
            • 3094
            • india
            Hi shiyab,
            try 32 mb
            • rbdealmeida
              • Mar 2026
              • 9
              • Portugal
              Hi shiyab,
              Thank you so much for the modified file! I really appreciate the time and effort you put into patching this for me.
              I will flash this file to the U19 chip and test the machine today.
              Just one quick question before I proceed: since this is an "unss" patched file, can I just boot the PC normally to the BIOS after flashing the U19? Or do I still need to perform the physical shunt/short on pins 2 and 4 of the U68 NAND chip during the first boot to bypass the Sure Start check?
              I will let you know the results as soon as I test it.
              Thanks again!
              • rbdealmeida
                • Mar 2026
                • 9
                • Portugal
                Hi shiyab ,
                Thank you for your help and for providing the file. I have just finished testing it, but unfortunately, the password remains active.
                I performed the tests in two ways:
                With the U68 shunt (bypass): The password was still there.
                Without the shunt: The result was exactly the same.
                In both scenarios, the machine triggers the following warning during boot: "BIOS Identity Data Recovered: The BIOS has recovered its identity data from the Embedded Controller due to data mismatch."
                It seems the EC is detecting the modification in the U19 dump and performing an automatic recovery of the identity data, effectively overriding the patch.
                Do you have any suggestions on how to bypass this specific EC recovery on the G9 models, or perhaps a different approach to the patch?
                Thanks again for your time!​
                • rbdealmeida
                  • Mar 2026
                  • 9
                  • Portugal
                  Just a quick follow-up to reinforce this request. All technical details, serial numbers, and the original dumps are already provided in the previous posts of this thread.
                  shiyab
                  Vesko356
                  peste
                  hoaca388
                  SMDFlea
                  rethink
                  If any of you could spare a moment to help me with this HP G9 BIOS, I would be extremely grateful.
                  Thank you for your time and assistance!
                  • marian4474
                    • Dec 2014
                    • romania
                    Try this one, before flashing make sure the CMOS battery has power and do not remove it, power up the computer and let it POST. After that flash the file on the U19 chip, the computer should only reboot once not more. If it doesn't boot in manufacturing mode you might have to reprogram the Embedded Controller.
                    • rbdealmeida
                      • Mar 2026
                      • 9
                      • Portugal
                      Hi marian4474 (and everyone else following),
                      Thank you for the file and the instructions. I followed your steps exactly (kept the CMOS battery connected, let the original BIOS POST, and then flashed your modified file to the U19 chip).
                      As you predicted, the machine only rebooted once. However, the password is still there.
                      This time, the previous "EC Identity Data" error is gone. Instead, the machine throws a new, specific HP Sure Start error screen. Here is the exact message:
                      "HP Sure Start Recovery: HP Sure Start detected an unauthorized change to the Secure Boot Keys. The keys were restored automatically and there is no further action required. The repeated occurrence of this problem indicates a security problem that should not be ignored."
                      (Note: I got this behavior despite doing multiple attempts, including with the hardware bypass/shunt applied to pins 2 and 4 on the U68 NAND).
                      Here is the complete system info for context, in case it helps with rebuilding the AMD PSP/BIOS structure:
                      Product Name: HP EliteDesk 8 Mini G1a DEsktop PC
                      Processor: AMD Ryzen 3 210 w/ Radeon 740M Graphics
                      Memory Size: 16384 MB
                      System BIOS: X27 Ver. 02.02.02 (Date: 07/17/2025)
                      Born on Date: 11/03/2025
                      Serial Number: 1HF5420L66
                      SKU Number: B02PXAV
                      UUID: 5875E396-E8DF-44D3-8C46-0E3E0467114E
                      Feature Byte: 3E476J6S6b7B7H7M7Q7T7W7maBapaqaubhcAfPguhKhZjhk8mEn7nWngpDpnpqprrNsZ.3R
                      System Board ID: 8DAB
                      System Board CT Number: PUSKE0C87LK083
                      Since this is an AMD G1a architecture and the Sure Start auto-recovery triggers even with the U68 NAND bypassed physically, does anyone know if the security backup is being pushed directly by the Embedded Controller? How should we approach the AMD structure for this unlock?
                      Thank you again for all your time and help!
                      • marian4474
                        marian4474 commented
                        Editing a comment
                        The U68 chip its a security feature, even if it is blank (all FF) the EC will write it's firmware back. The EC handles security / platform recovery / BIOS code execution so that is what we need to modify, unfortunately I have no experience regarding ECs at all. All I can say is the newest HP desktops or laptops have the most strict security features making them useless if passwords are set.
                    • rbdealmeida
                      • Mar 2026
                      • 9
                      • Portugal
                      I want to provide a technical summary of everything I’ve tried so far on this HP Elite Mini 8 G1a (AMD Ryzen 3 210) to see if any expert can point me in the right direction. It seems the standard patching methods are being defeated by the new EC/PSP security synchronization.
                      Current Status & Failed Attempts
                      1. Automated Patching: Tried HP G9 Unlocker V3.0 on the 32MB U19 dump.
                      • Result: Password still active. The tool likely doesn't support this 2025/26 offset yet.
                      2. Manual Patch (attempt 1): Flashed a modified U19.
                      • Result: Triggered EC Recovery: "BIOS Identity Data Recovered". The EC detected the hash mismatch and restored the original locked data.
                      3. Manual Patch (attempt 2 - marian4474's method): Flashed while keeping CMOS battery power.
                      • Result: Triggered Sure Start Error: "Unauthorized change to Secure Boot Keys". The AMD PSP rejected the signature of the modified BIOS.
                      4. Hardware Bypass (U68 Shunt/Erase): Attempted to short pins 2-4 on the U68 NAND and even tried a full erase of the chip.
                      • Result: Ineffective. The EC automatically re-writes the U68 firmware or forces a recovery from its internal ROM.
                      The Challenge
                      On this G1a (AMD) architecture, the Root of Trust is extremely aggressive. Even with the U68 completely erased, the EC/PSP validates the U19 integrity before allowing access to F10.
                      What I’m looking for:
                      • Does anyone have experience putting these G1a boards into Manufacturing Mode (Commit State 0) via hex editing the VSS/NVAR stores?
                      • Is there a known way to disable the EC's "Auto-Healing" feature on these newer models?
                      • Would a clean/virgin BIOS dump (with clear ME/PSP) combined with an EC reprogram be the only way?
                      If anyone can help me "break" this EC-to-BIOS link, I’d be very grateful! Sparo
                      • rex98
                        • Feb 2023
                        • 1348
                        • Mandaue CEBU, Philippines
                        • Computer hardware repair
                        i also tried all these methods it didn't work.
                        • HP MPM Tool v20 — Donor L1 Swap + Safe Patch
                          Proven method: 630 G11 donor L1 swap + signature-based VSS2.
                          Donor has H_MpmTest (no nonce enforcement) + FF-wiped SMM handlers.
                          Pipeline:
                          1. L1 SWAP → Replace 0x1B4D000-0x1D60000 with 630 G11 donor
                          → Eliminates: nonces, SMM handlers, VerifyGate
                          2. VSS2 → Signature-based: HP_MUD, BuildId, FactoryConfig,
                          → TheftRecoveryFlags, HpMpm, UserCred (35 bytes)
                          3. DXE → TpmOptions -8, VariableAuth -8, Tcg2 flip, POSTCODE01
                          4. VERIFY → VerifyGate JNE→JMP (if pattern found post-swap)
                          ✓ Donor L1 embedded (630 G11, GZip compressed, ~765 KB)
                          ✓ No nonce patching needed (donor has none)
                          Loaded: elitebook 8 g1 fresh bios reg.BIN (33,554,432 bytes)
                          ═══ v20 DONOR L1 SWAP + SAFE PATCH ═══
                          [1] L1 DONOR SWAP (630 G11)
                          Loading embedded 630 G11 donor L1...
                          Loaded donor from embedded resource
                          __KEYM__ signing key: MATCH ✓
                          L1 region: 1,263,938 / 2,174,976 bytes will change (58.1%)
                          L1 donor swap complete: 1,263,938 bytes replaced ✓
                          Nonces after swap: 0 (ELIMINATED) ✓
                          H_MpmTest: found @ 0x01B7BDC0 ✓
                          SMM handlers: FF-wiped ✓ | GetMfgStatus: FF-wiped ✓ | LockCmd: FF-wiped ✓
                          [2] VSS2 SIGNATURE PATCH (absolute.exe method)
                          Mode: Signature-based pattern scan (like IDA/absolute.exe)
                          TheftRecoveryFlags @ 0x019DA3AC: state 0x3F→0x3C (invalidated) ✓
                          HP_MUD @ 0x019E241C: state 0x3F→0x3C (invalidated) ✓
                          BuildId @ 0x019E39FC: state 0x3F→0x3C (invalidated) ✓
                          FactoryConfig @ 0x019E3664: state 0x3F→0x3C (invalidated) ✓
                          HpMpm @ 0x019E47F0: data patched (proven values) ✓
                          data[1]: 0x00→0x23 data[2]: 0x00→0x01 data[4]: 0x00→0x02
                          UserCred @ 0x019E50B8: surgical patch (4 blocks, 21 bytes) ✓
                          Block 1: data[0x08] credential count → FF FF FF FF
                          Block 2: data[0x10] AdminPW name → zeroed (14 bytes)
                          Block 3: data[0x3C,0x728] flags → 0x00
                          Block 4: data[0x730,0x738] hash blocks → FF FF FF FF
                          VSS2 total: 6 patches
                          [3] DXE LZMA PATCHES
                          LZMA FV @ 0x00F00000 (11,038,720 bytes)
                          Decompressed: 45,699,088 bytes
                          TpmOptions: 9 struct, 3 alloc patches
                          VariableAuthSmm: 2 patches
                          Tcg2Smm: JZ→JNZ @ +0xA2B
                          Tcg2Smm: 1 total patches
                          POSTCODE01: state 0xF8→0x00 (REMOVED) ✓
                          Recompressing LZMA (~20-40 sec)...
                          DXE recompressed: 8,550,341 bytes ✓
                          [4] VERIFY GATE (post-swap)
                          VerifyGate: donor has different code (0x%02X), no action needed
                          ═══ v20 COMPLETE ═══
                          1. L1: Donor swap complete (630 G11, no nonces, FF-wiped handlers)
                          2. VSS2: HP_MUD + BuildId + FactoryConfig + TheftRecovery + HpMpm + UserCred
                          3. DXE: TpmOptions + VariableAuth + Tcg2 + POSTCODE01 patched
                          4. Gate: VerifyGate checked/applied
                          v19 ( this is my revision of patch)
                          1 SMM Security Handler 0x1D028EF push ebp; mov ebp,esp; sub esp,10h xor eax,eax; ret (31 C0 C3)
                          2 GetMfgStatus 0x1D03631 push ebp; mov ebp,esp; sub esp,10h mov eax,0x11; ret (B8 11 00 00 00 C3)
                          3 LockCommand 0x1D0443A push ebp; mov ebp,esp; sub esp,0Ch xor eax,eax; ret (31 C0 C3)
                          4 VerifyGate 0x1D30A93 jne +0x47 (75 47) jmp +0x47 (EB 47)
                          v19 DXE Driver Patches (LZMA compressed)
                          TpmOptions Bypass TPM check Skip TPM policy enforcement
                          VariableAuthSmm Bypass auth check Allow variable writes
                          Tcg2Smm Bypass TCG2 Skip measurement log
                          POSTCODE01 Status override Force success POST code
                          v19. L1/EpSC Region Swap
                          Region 0x1B4D000 - 0x1D60000
                          Size 2,124 KB
                          Bytes changed 1,263,938 (58.1%)
                          Source EliteBook 630 G11 (bak patched.bin)
                          v19. What the Donor Provides
                          __KEYM__ key 0x1B4D400 0x1B4D400 ✅ same
                          __KEYM__ offset Identical Identical ✅
                          Signing key Match Match ✅
                          SMM Security Handler Active enforcement 0xFF erased
                          GetMfgStatus Active check 0xFF erased
                          LockCommand Active lock 0xFF erased
                          VerifyGate Active verification 0xFF erased
                          H_MpmNoncIntnl 4 instances (nonce timer) Absent
                          H_MpmTest Absent Present (test mode)
                          Nonce enforcement Active None
                          Side-by-Side Security Handler Comparison elitebook 8 g1 vs 630 g11 patched
                          v19 Surgical 630 G11 Donor Swap
                          SMM Handler: 31 C0 C3 FF FF FF FF FF ...
                          (xor eax,eax; ret) (erased, no code)
                          → returns 0 → CPU fault, no exec
                        • GetMfgStatus: B8 11 00 00 00 C3 FF FF FF FF FF ...
                          (mov eax,0x11; ret) (erased, no code)
                        • → returns "locked" → CPU fault, no exec
                        • LockCommand: 31 C0 C3 FF FF FF FF FF ...
                          → returns success → CPU fault, no exec
                        • VerifyGate: EB 47 (jmp, skip check) FF FF FF ... (erased)
                          ARM Nonces: PRESERVED (in signed zone) ELIMINATED (H_MpmTest)​
                          this is what i did now i copied their entire L1 no nonce. its identical analyzed from ida pro. i hope someone would help. and i hope hp would not see this
                          i think there's something that verifies in ec because all g9 g10 doesn't have nonce check and all my post about g9 and g10 requires old version of the ec.
                        • volinakis
                          • Jan 2021
                          • 3231
                          • N/A
                          rbdealmeida
                          try this one. Remove RTC battery and power adapter, press power button for 10s, write&solder bios chipset (U19) and start unit without RTC battery.
                          please support this forum
                          • Lechutek
                            Lenovo Yoga 9 14IAP7 (82LU) HNCN51WW – Supervisor Password Removal / SVP Unlock Request
                            by Lechutek
                            I need help removing Supervisor Password (SVP) from a Lenovo Yoga 9 14IAP7.
                            Laptop details:
                            • Model: Lenovo Yoga 9 14IAP7
                            • MTM: 82LU0080PB
                            • BIOS version: HNCN51WW
                            • Platform: Alder Lake / InsydeH2O
                            SPI chips on board:
                            • W25Q128JVSN (main BIOS, 16 MB)
                            • W25Q80DVSIG (possible EC/security firmware)
                            • W25R64JVSIN (Intel IFWI/CSE region)
                            I already dumped all chips using CH341A + NeoProgrammer.
                            Attempts already made:
                            • NVRAM clear on W25Q128 -> black screen / no POST
                            • Surgical setup variable patch -> black screen
                            • Original BIOS restored
                            05-14-2026, 01:16 AM
                          • alexhoopes
                            HP Elite Mini 800 G9 BIOS Password Unlock
                            by alexhoopes
                            Model: HSC-Q001Dm
                            Serial: MXL4102Y9S
                            Board: DAF96AMB8G0 REV G
                            BIOS and EC (I think) attached.
                            Thanks in advance, and if there are any guides into learning how to do this I would appreciate a link! I'd love to learn how to do these instead of coming on here to get the needed files....
                            01-11-2025, 06:29 PM
                          • Chopster1986
                            HP Z2 G5 Mini - BIOS Password Removal
                            by Chopster1986
                            Hi All,
                            HP Z2 Mini G5 (PN 4J5W3EC)
                            Serial number: 8CN1450K3T
                            Board Number: G5-6050A3153001-MB-02(A2)
                            It's got a BIOS password currently - I've got CH341A and managed to connect to the left chip (Winbond W25Q128JVSQ) and pull a BIN file, I tried RC Unlocker and reflashed but besides the PC saying it was completing a BIOS update it's kept the password. I can't read the other chip (Winbond W25Q256JVEN) currently without removing it from the board (I'm really not a fan of soldering so might need to get someone to do that!)
                            The other chip I can't connect...
                            05-21-2025, 08:51 AM
                          • volinakis
                            HP Elite Mini 600 G9 Desktop PC Bios Password
                            by volinakis
                            Hi, I need help to remove bios password please.
                            Name: HP Elite Mini 600 G9 Desktop PC
                            S/N: 8CC4131WJ8
                            Prod Id: 4C5J7AV
                            I did usual modifications to enter in MPM mode but with modifications it restarts several times then when it boots it appears message: "Bios Identity Data Recovered The BIOS has recovered its identity data from the Embedded Controller due to data mismatch" and did not enter in MPM mode.
                            I attach main and EC backups, maybe Badcaps Masters can help me, thank you in advance.
                            post moved......
                            09-10-2024, 12:34 PM
                          • witcher79
                            Hp Elite Mini 800 G9 Bios Password
                            by witcher79
                            Hello
                            Can anyone remove the bios password from the Hp Elite Mini 800 g9. I am attaching the bios password file. Thank You...
                            08-02-2023, 01:29 AM
