Does any one have a working bios for HP 285 Pro G8 . The one i have attached only does fan spin no post/display
HP 285 Pro G8 Micro Tower PC AMD Ryzen BIOS Request
You MUST:- Read BIOS guides, methods, resources and tools
- Try the method at BIOS guides, methods, resources and tools before requesting help
- Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
- Use search function in case someone already answered your request
- Post under a related thread if it exists
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
- Name your thread with make, full model numbers and request
- Provide a BIOS/EC dump if possible
- Attach files directly to your post instead of linking to external websites
- Post what the problem is,be specific - Black screen,no boot,running slow,password.
Do NOT post "clean me","clear bios","clean bios","bios need" or other such terms
https://www.badcaps.net/donate -
Sorry about that. Duly noted for next request.
I have tried to download the bios from the HP website and extracted the bin file which i flashed and it did nothing. no fan spin no power to board..
The one i attached spins the cpu fan but has no display. I have searched the forum and i havent found any.....
The Make and Model - HP 285 Pro G8 - AMD Processor((without graphics) i am using a graphics card)
SN: CT:PLERD0BCYH20Y
Other codes on the qr
AS#M45442-001
SP#M476-001 NO DPK
SP#M476-601 WIN
I have attached the BIOS Dump above
HP 285 Pro G8 Microtower PC IDS Base ModelSorry about that. Duly noted for next request.
AS#M45442-001
SP#M476-001 NO DPK
SP#M476-601 WIN
Serial_4CE131Z2B2
BuiID_21WW1MAT601#SABG#DABG
Product_1Y4D6AV
Fearture byte_2U3E 3K3N 3Q3Y 5Y6E 6b6y 7J7M 7T7Y 7d7j apbD bheJ fPka m9 .5h
Attached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
by DavidChuncoHi, I hope someone can help me with this, my Dell G15 Ryzen Edition does not post anymore (black screen, no Windows boot, no BIOS screen) after Windows Update pushed what appears to be a buggy bios image, I've tried the following with no success:
- Receive help from Dell Support (it is out of warranty).
- Disconnect machine from AC power and battery overnight.
- BIOS recovery process
- Connected external display via HDMI
- Disassembled machine and found bios chip, its a Gigadevice 25LR128DSIG (GD25LR128DSIG), at first I tried to get it detected by CH341A (with...-
Channel: BIOS Requests ONLY!
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
- I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
- I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
- I could only locate two chips that look like bios chips. Could someone verify this
- Loading...
