Hello, I have a Lenovo M70q Gen5 minicomputer s/n GM0SM419. Motherboard LQ672 NM-F911, the user forgot the bios password and can no longer reinstall the OS, can someone help me unlock this bios, thank you.
Lenovo M70q Gen5 bios unlock
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by enlotHello!
I'm trying to remove the bios password of an Lenovo ThinkCentre M75q Gen5
Unfortunately i cant find many resources about the Gen5 or the bios chip.
Bios chip is XMC 25RU256CXIQ.
SN is GM0QDZ77
Let me know if there is an issue with the attached bios dump, as this is my first attempt and i dont have a wson8 clip
Would be great if someone could decrypt the password from the dump, but if thats not possible i can attempt to flash the chip (hoping my crappy solder job works)...-
by fefocaceresHi everyone,
I need some help unlocking the BIOS on a Lenovo ThinkCentre M70q Gen 2.
The admin password is set and I can’t access BIOS settings.
Here are the system details:- Model: Lenovo M70q Gen 2
- Product type: 11DT
- Serial number: MJ0GSLST
- Loading...
