Asus prime x670e boardview request
This topic has been answered.
  • McWhitePink
    • Apr 2023
    • 103
    Hi Friends
    Does anyone have boardview for Asus prime x670e? There are some missing part on my board. Need the boardview to identify the parts.
  • Answer selected by McWhitePink at 08-11-2025, 12:15 PM.
    Rezistor
    • Jun 2021
    • 287
    • USSR
    I found a boardview for your motherboard, solder the missing 39 Ohm resistor in place, without it the board will not work
    • Rezistor
      • Jun 2021
      • 287
      • USSR
      Originally posted by McWhitePink
      Hi Friends
      ASUS PRIME X670E-PRO WIFI or ASUS PRIME X670E-P ?
      Send a photo of the board section with missing elements
      • McWhitePink
        • Apr 2023
        • 103
        It's X670e -pro wifi.
        thanks
        • McWhitePink
          • Apr 2023
          • 103
          Below are the pics
          • Rezistor
            • Jun 2021
            • 287
            • USSR
            Capacitors of 10 µF and 0.1 µF
            • McWhitePink
              • Apr 2023
              • 103
              then there must be some other missing components.
              can you please share the boardview?
              • McWhitePink
                • Apr 2023
                • 103
                Here I found another missing component.
                • Rezistor
                  • Jun 2021
                  • 287
                  • USSR
                  There are many versions and part numbers for one model on Asus. My boardview version does not have the RAA229621 PWM controller on the back of the board. Download the STRIX B650E-E GAMING WIFI boardview from the forum and find the RAA229621 PWM controller on the back of the board. Ring which leg of the PWM your missing element goes to and look at the boardview you downloaded. It may be a 39 Ohm resistor
                  https://www.badcaps.net/forum/troubl...0e-e-boardview
                  • McWhitePink
                    • Apr 2023
                    • 103
                    It seems like a resistor but not populated. I don't really know why it stuck at QCODE 00.
                    I will probe on the BIOS CS pin, but I don't expect the CPU is really sending out CS signal.
                    Quite strange behavior to me. already did flash with latest BIOS.
                    • Rezistor
                      • Jun 2021
                      • 287
                      • USSR
                      Send a photo of your model and part number, this photo is for example
                      • McWhitePink
                        • Apr 2023
                        • 103
                        it's ASUS PRIME X670E-PRO WIFI
                          • 21164
                          What revision number, and what does it say on the barcode sticker 60MBxxxxxx
                          • McWhitePink
                            • Apr 2023
                            • 103
                            It should not matter much for the version number. But I attached my board here.
                            • Rezistor
                              • Jun 2021
                              • 287
                              • USSR
                              • McWhitePink
                                • Apr 2023
                                • 103
                                yeah, already did that. it works now. but thanks a lot.
