MSI B660M Mortar DDR4 (MS-7D42 Rev 1.1) Request for EC flash chip (W25X20CLNIG)
  • mizuh0
    • Jul 2025
    • 7
    • singapore
    Hi all I hope im doing this correctly,
    I need a firmware dump for the Nuvoton NCT6687D‑M controller (EC flash chip: W25X20CLNIG) used on the MSI B660M Mortar DDR4 (MS‑7D42, revision 1.1).
    I acquired a ch341a black to reflash my bios, and was so excited to use it that I tested it on the W25X20CLNIG 3.3v chip as I didn't have the 1.8v yet for the bios chip itself.
    Being a total newbie I straight up corrupted the EC flash chip, and now the power button does nothing, PS_ON# does not change, and when I manually short the PS_ON# pin it immediately turns off when I stop shorting.
    The chip still works, after trimming the cheap soic8 clip I now have a reliable connection.
    If anyone has a working dump from the same board, I would be very thankful.
  • mizuh0
    • Jul 2025
    • 7
    • singapore
    opps i meant MSI B660M Mortar wifi DDR4, but i think that the non wifi one works too.
    • noname2024
      • Aug 2024
      • 290
      • CỎ MỸ XỊN
      MAG B660M MORTAR DDR4
      U30
      • mizuh0
        • Jul 2025
        • 7
        • singapore
        thank you noname2024 for the u30 chip firmware, my front panel headers now work after shorting the controller pins as i think the controller was in a semi bricked state.
        im now trying to fix the msi ez led debug light where it is showing yellow despite me having a ram stick
        could it be a bios issue as i flashed a clean msi bios with no dmi information?
        • noname2024
          • Aug 2024
          • 290
          • CỎ MỸ XỊN
          Bios msi you can get it from homepage msi
            • 31208
            pretty sure you need a matching pair of ram.
            not a single stick.
            • mizuh0
              • Jul 2025
              • 7
              • singapore
              Oh nice I got it working with a new ram kit I got, but I am still plagued with sudden shut downs I had gotten before I corrupted my bios and ec.
              It reports 0 degree for system temp and some of the reported voltages are bogus readings but these shouldn't be the cause of the random shutdowns because i already had them before.
              Somethings gotta be weird with the ec controller or pch or even the cpu lol.
              any idea on how to pinpoint this random power off issue
              Click image for larger version  Name:	image.png Views:	0 Size:	23.6 KB ID:	3708886
              • iaf86
                MSI B660M Mortar DDR4 MS-7D42 bios Password
                by iaf86
                Hi Experts, I need help to unlock Bios PW for MSI B660M Mortar DDR4 (MS-7D42 Rev 1.1) Desktop Gaming PC, i tried Jbat1 Jumper method but does not work. iam uploading the original bios dump if someone can remove the password. thank you...
                07-28-2025, 04:51 AM
              • Koyneki
                Boardview for PRO B660M-P DDR4
                by Koyneki
                HI! I need boardview for MSI PRO B660M-P DDR4 because some components on the back side are missing(resistors). the motherboard just stop on BOOT light....
                05-03-2025, 01:35 AM
              • ekozeko333
                [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                by ekozeko333
                I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                🔥 The Problem Started After Suspected ESD/PD Fault
                I experienced a power issue or ESD event through a USB-C charger
                After that, the NX20P5090 power switch was visibly burned and was replaced
                Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                🧠 What I’ve Done So Far
                Flashed...
                06-21-2025, 02:48 AM
              • corrize
                Nikon D800 camera - flash don’t work and capacitor don’t charge
                by corrize
                Hello, I'm stuck in troubleshooting…
                The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                10-01-2022, 10:02 AM
                HP Z2 G4 + 8GB (1x8GB) DDR4-2666 ECC RAM E-2124G Specification for Upgrade or Repair
                This specification for the HP Z2 G4 + 8GB (1x8GB) DDR4-2666 ECC RAM can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z2 G4 + 8GB (1x8GB) DDR4-2666 ECC RAM boardview and Z2 G4 + 8GB (1x8GB) DDR4-2666 ECC RAM schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                09-12-2024, 02:20 PM
