  • grimacelord
    • Jan 2017
    • 380
    Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website and this is basically where I am stuck. The downloaded .CAP file from ASUS's website is 24,580KB. The dump I took from GD25B64ESIG is 8,192KB and the dump from GD25B128ESIG is 16,384KB. If you were to add the file sizes of my two dumps, it would add up to roughly the size of the downloaded .CAP file from the ASUS website.
    The problem I am having is I have absolutely no idea how I can go about flashing this new BIOS to the chip when they are separated between two chips like this. It seems to me like the original dump will need to be edited in a HEX editor to have the .CAP update "merged in" or something and I am still not skilled enough in this area to do this. I have read over the guides here a million times and watched countless YouTube videos and I have still just been unable to figure out how to successfully edit a BIOS file and have it actually allow the computer to boot. I've tried it before on other systems and failed every time haha.
    I think I understand what needs to be done here, but I have absolutely no idea how to go about doing it, so I am here asking for help. Attached is the original dumps from both the 64MB and 128MB chips as well as a copy of the latest available BIOS update from ASUS's website. If someone could please take a look at this I would greatly appreciate it. Thank you.
    Also, as a follow-up question. Assuming someone here is able to help me and edit the original BIOS dump to "merge in" the updated BIOS region or whatever needs to be done, I am assuming I am going to end up with a single file. I would flash that single file to the 128MB chip, I assume, but what does that do to the 64MB chip? Does the updated BIOS from the 128MB somehow automatically update the 64MB chip or will I have two separate files to flash individually to their respective chips? I don't understand how that part works. Thank you so much!
    Also, in case I didn't make it obvious enough:
    TUF-GAMING-Z790-PLUS-WIFI-ASUS-1820.zip = Downloaded ASUS Update file for this motherboard
    GD25B64E@SOIC8.zip = Original dump for 64MB chip
    GD25B128E@SOIC8.zip = Original dump for 128MB chip
  • m1ch43lzm
    • Mar 2019
    • 669
    • Peru
    The "easy" way: Borrow a 12th/13th gen CPU, update BIOS from USB drive, install 14th gen CPU, done
    The "hard" way: Open the .cap with UEFITool (no need if you follow the steps below), extract the Intel Image (should be 25,165,824 bytes), and manually split with a hex editor
    The first 0x800000 go to the 8MB chip, the remaining 0x1000000 go to the 16MB chip
    i tried joining the 2 files from your dumps: first the 8MB+16MB, and UEFITool showed an Intel image, with a Descriptor, ME, and BIOS regions, but it's corrupt
    If using a clip, try changing the SPI clock frequency in your programmer to lower frequency to try to get a good read, then read the chips 3 times each and compare the dumps with a hex editor; if exactly the same, it's very likely you got a good read
    Example: I have the T48, look for a setting similar to this, and lower the value (I set it to 8MHz when using a clip):
    Click image for larger version  Name:	spiclk t48.png Views:	0 Size:	58.6 KB ID:	3679692
    How your dump looks, vs how should it be:
Name:	corrupt full dump.png
ID:	3679697 Click image for larger version
    ______________________
    Check here for reference:
    https://winraid.level1techs.com/t/pr...fi-d4/108012/2
    In short:
    Download FD44Editor https://github.com/LongSoft/FD44Edit...ases/tag/0.9.2
    Join your BIOS dumps with hex editor, in a new file, first the 8MB, then the 16MB, in that order, the contents of the 16MB file should start at 0x800000, the file should end exactly at 0x17FFFFF (length: 0x1800000), or exactly 25,165,824 bytes
    Open your "full" BIOS dump with FD44Editor, use the "Open from BIOS image file" button, and note your S/N, MAC address, UUID, etc.,
    Press "Save to BIOS image file", select the .cap downloaded from ASUS website, overwrite it; the .cap header will be removed and you'll be left with a .bin exactly 25,165,824 bytes, or 24,576KB
    Now, split the BIOS image .bin with hex editor (I use HxD as an example)
    Go to position 0x800000, Edit, set length to 1000000 hex
    Ctrl-X, a warning about changing file size will appear, press OK
    File - Save as a new file (example: 8MB.bin)
    Press the "New file" icon, and paste (Ctrl-V), again the same warning, press OK
    Save the new file (example: 16MB.bin)
    • grimacelord
      • Jan 2017
      • 380
      Thank you for the help. I also use the T48 and I indeed used a clip on both dumps. I'll try again with a lower frequency as you suggested and see if the dumps are the same after 3 reads.
      As far as the process goes, thank you for explaining that so clearly. I think I might be able to follow that. I'm going to give it a try and if I fail miserably as I have in the past at this sort of thing, I'll post back with fresh dumps and maybe you could give it a try? Haha.
      I really appreciate your help. I'll be giving this a try in about an hour...
      • grimacelord
        • Jan 2017
        • 380
        Well, looks like I botched it again somehow. I felt like everything was going smoothly and I was getting the exact file sizes that you said I should, but I think I must've made an error when splitting my "full bios" file I created as per your instructions. After flashing my "split image" to each chip and attempting to boot, the computer doesn't POST.
        I am attaching my new dumps that I took after I set the frequency to 8MHz (verified with 3 dumps) and I am also attaching my "full bios image" I created according to your instructions as well as my "16mb.bin" and "8mb.bin" images I made after I split them so you can see what I did and perhaps show me where I made a mistake because I am sure that I did somehow. This BIOS editing stuff always seems so complicated to me. I thought I had it for sure this time, but I guess I screwed it up again.
        Attached are my files.
        "8mb.zip" = My attempt at splitting the "full_bios" image to create the 8mb image
        "16mb.zip" = My attempt at splitting the "full_bios" image to create the 16mb image.
        "GD25B64E@SOIC8@8mhz.zip/GD25B128E@SOIC8@8mhz.zip" = The newly created dumps I made with reduced frequency to 8mhz.
        "full_bios.zip" = The "full bios" image I created by joining the two in HEX editor. The file size matched what you said it should, so I felt like I did everything right up to this point, but you may want to check this too. I don't know what I am doing. Ha.
        Thank you so much for your help.
        • grimacelord
          • Jan 2017
          • 380
          I went back and tried this method and the resulting 8MB image I came up with was identical in hex to the first 8MB image I created, but the second 16MB image I made using the method above was different than the 16MB image I created the first time. I went back and flashed that 16MB image, hoping that I found my error, and still - no POST. Just figured I'd let you know everything that I have done. I'm still no closer to figuring this out myself, so I hope you are able and willing to help me. Thank you again.
          • m1ch43lzm
            • Mar 2019
            • 669
            • Peru
            I'll check later your BIOS dumps, as I'm not on my PC right now
            Test with the basics, just CPU, 1 stick of RAM, GPU if you're using a CPU without integrated graphics (CPU model ends in F)
            • m1ch43lzm
              • Mar 2019
              • 669
              • Peru
              Your original BIOS is version 1402, it should work with 14th gen Intel CPUs out of the box
              TUF GAMING Z790-PLUS WIFI BIOS 1402
              Versión 1402
              11.25 MB
              2023/09/19
              "1. Update Microcode for Intel® Core™ 14th gen processors
              2. Update ME to version 16.1.30.2264v2 for Intel® Core™ 14th gen processors
              3. Improve system stability
              Updating this BIOS will simultaneously update the corresponding Intel ME to version16.1.30.2264v2. Please note after you update this BIOS, the ME version remains the updated one even if you roll back to an older BIOS later."
              The issue may be somewhere else
              The way you split the files is correct, just small differences in how the serial etc. are stored (using FD44Editor, vs doing it by hand copying from the original dump), nothing that affects POST
              Even without serial, MAC address, UUID the board should POST
              S/N, MAC, UUID are stored in those offsets, I copied manually to the new BIOS (those offsets are from the full image)
              864000-86415F
              A90090-A900CF
              Attached the split files for BIOS 1820, now with your S/N, MAC address, UUID
              As i said before, test only motherboard, CPU + heatsink, 1 stick of RAM in slot DIMM_A2, GPU if using a "F" CPU(without integrated graphics), nothing else connected to the board except keyboard/mouse/monitor (connected to GPU, or the onboard HDMI port if no GPU installed); it will take some time, give it 5 minutes for the 1st boot
              • grimacelord
                • Jan 2017
                • 380
                864000-86415F
                A90090-A900CF
                Thank you again for your help. I won't be able to get back to this until Monday, but I'll try this first thing Monday morning and let you know how it goes. Have a great weekend!
                • grimacelord
                  • Jan 2017
                  • 380
                  Hello again,
                  I finally was able to give this another try, but unfortunately, I still have no POST.
                  I first flashed your files to each respective BIOS chip and then disconnected everything except for the essentials. Motherboard, CPU, a single stick of RAM in slot A2, and of course the power supply. I then cleared CMOS using the jumper on the motherboard, connected power, and powered on the computer and allowed it to try and POST for about 10 minutes the first time. Then, I shut down the computer, tried adding a GPU card and switched the HDMI cable to that, CMOS clear again, and try to POST again. 10 minutes later, still no POST. Next, I tried a completely different stick of RAM altogether (still compatible, just different manufacturer) and again, no POST.
                  Not really sure what to try next...
                  • m1ch43lzm
                    • Mar 2019
                    • 669
                    • Peru
                    At this point I think you have defective motherboard or CPU
                    Inspect the CPU socket pins with a magnifier or microscope, check if you have bent or damaged pins
                    If CPU socket is good, only way to know is swapping parts, testing the CPU/RAM on another motherboard
                    Have you checked the debug LEDs at the top, near the RAM slots? Where does it get stuck
                    If all else fails, and there's no visible damage on the CPU socket, RMA the motherboard (reinstall the socket cover)
                    • Citymin
                      by Citymin
                      S/N : 5RNK9FFT70...
                      08-05-2025, 05:12 AM
                    • Forest79
                      by Forest79
                      However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                      07-23-2023, 07:39 AM
                    • maanee11
                      Help to get Lenovo BIOS bin file for Thinkpad T560
                      by maanee11
                      Hello Everyone,
                      I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                      https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                      In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                      05-15-2022, 11:59 AM
                    • Sebastian Codrean
                      BIOS file for ASUS F542UN laptop
                      by Sebastian Codrean
                      Hello to all of you! I need help with a BIOS file.
                      The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                      So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                      02-20-2025, 10:25 AM
                    • Fr33man
                      BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
                      by Fr33man
                      I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
                      *Novo button power on
                      *Disconnected internal battery...
                      09-23-2024, 01:16 PM
