Exo Smart XL4-H3548 - Placa madre XU133U REV. 7.2.
  • Leandro Javier Ioele
    • Oct 2024
    • 16
    • Argentina
    Hi colleagues, today I'm here to discuss a topic. I'm hoping to see what you guys can recommend, or rather, how you would carry out this repair...
    This is an Exo Smart XL4 laptop, with the XU133U REV 7.2 motherboard.
    A customer brought it to me because it suddenly stopped recognizing his HDD. What happens is you turn on the computer and this screen appears:
    Click image for larger version  Name:	IMG_20250422_142409490.jpg Views:	0 Size:	2.24 MB ID:	3621505
    The first thing I did was test the HDD on another machine, and obviously it worked perfectly. However, I tried other drives on the motherboard, and it still didn't recognize them.
    Below are the series of tests I performed and the corresponding tests:
    1. I was reading online that it's common for this device to not recognize certain drives, and that programming the BIOS and the ITE fixes the problem. I already tried this with a file I downloaded from a forum (it was the only one I found), and it didn't work; I still had the same error.
    2. I measured the voltages on the SATA connector; I got the corresponding 5V power supply, and there were no short circuits.
    3. I measured the data lines of the SATA connector with the device on with an oscilloscope, and as expected, I didn't get any readings on any of its four data pins. Just by pressing the Power button I get a VERY SMALL spike on the 4 pins, which I don't think is important since it could be due to the machine starting up itself.
    Click image for larger version  Name:	IMG_20250422_233310289.jpg Views:	0 Size:	3.41 MB ID:	3621508
    Click image for larger version  Name:	IMG_20250422_233333131.jpg Views:	0 Size:	688.3 KB ID:	3621507
    4. I checked the integrity of the SATA connector and it is also correct.
    Click image for larger version  Name:	IMG_20250422_233324709.jpg Views:	0 Size:	769.1 KB ID:	3621506
    5. And finally, I'll leave you with two photos of the BIOS so you can see some of its specifications:
    Click image for larger version  Name:	IMG_20250422_142444362.jpg Views:	0 Size:	2.61 MB ID:	3621509
    Click image for larger version  Name:	IMG_20250422_142427134.jpg Views:	0 Size:	2.91 MB ID:	3621511
    I hope I haven't missed any important information. If you have any questions, just ask me and I'll let you know. First of all, thank you for your help. I suspect the problem is in the BIOS file. Therefore, I would be extremely grateful if you could help me find reliable files. I'm attaching the ones I extracted from the laptop when it arrived.
    MOD EDIT: Bios request posted -> https://www.badcaps.net/forum/troubl...il#post3621591
