No love for SuperMicro C7Q67 (BIOS fix)
    I bought two SuperMicro C7Q67 as "won't start" condition, thinking it's impossible to kill a SuperMicro
    Well, they wouldn't even power on, much less boot
    After blood, sweat & tears, I got the first to boot with my i5-2500K processor
    SuperMicro don't publish a Supported Processors list, and hoping to use a G1610 processor, I updated BIOS C7Q673_628
    Used a USB key booting into DOS, everything went fine, finally powered off then cleared CMOS according to ReadMe instructions
    Powered back on to get six beeps, then a CATERR LED lighting up
    Neither that beep code nor CATERR LED are documented in the C7Q67 User's Manual
    I've tried everything I can think of, can't get past CATERR
    The second C7Q67 is, if possible, even more frustrating
    Got it to power on, to get a blank screen
    If I remove memory - a pair of Hynix modules on their Tested Memory list - I get five short beeps and one long, meaning no memory
    FWIW, a POST card in the PCI slot, shows a status of 4B
    I thought SuperMicro was a brand you could trust
    Or have they gone like Asus, with Sudden Death Syndrome exacerbated by sh**ty documentation ?
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
    Re: No love for SuperMicro C7Q67
    The CATERR LED is driven by the CAT_ERR_N signal and indicates a "Catastrophic Error". The 6 beeps indicate "Flash update has failed".
    Perhaps you can try a BIOS Recovery as specified in Appendix C of the user manual.
    Machina improba! Vel mihi ede potum vel mihi redde nummos meos!
      Thanks for your feedback
      I've followed a number of wild goose chases related to that error, on various forums - at one stage even tried hooking fans up to all unused fan connectors, after reading a thread on an Intel server forum, where someone got that error from wrongly connected fans
      Is there a reference to that anywhere in SuperMicro documentation ?
      There was no indication of failure during the update process, and this was one of many flash updates I've done
      Maybe no indication because there's no error checking in the crappy batch file that SuperMicro supply to do the update
      I -have- tried that
      Cannot get it to register my pressing Ctrl+Home, using a PS/2 keyboard
      Speaking of Ctrl+Home - what a throwback to AMI BIOSes of 486 vintage, where processor speed was more leisurely - this is supposed to be a new UEFI BIOS
      You'd expect jumpers on the motherboard for BIOS recovery, like Intel boards, for a product having pretensions as server grade
      More suggestions would be appreciated
        The 6 beeps indicate "Flash update has failed" came from an AMI document on their Aptio bios which is used in this motherboard.
        You haven't mentioned it, but I am sure you have tried removing the battery to reset the cmos.
        This motherboard does have a jumper to enter recovery mode, but it seems they forgot to mention it in Appendix C with the recovery instructions. The jumper for recovery mode is JPME1. See page 2-30 in the user manual for description and location. It seems to be used for recovery of the Management Engine part of the bios. I don't know if that will be helpful or not.
          You're correct - one of the first things I tried
          I have tried jumpering JPME1 which is supposed to "enable ME (Manufacture Mode) Recovery"
          Didn't make any difference to the outcome, certainly didn't light up the USB key
          With nothing left to lose, I also tried jumpering JCPUVRD_SMB which is next to the CATERR LED
          It's mentioned in the manual as "PWM SMB programming header(for debugging only)" so jumpering may have been the wrong thing to do
          At least no magic smoke came out - I recall one of the positions changing the pitch of the beeps
          Thanks for your advice - you're a lot more helpful than "SuperMicro support" (an oxymoron if ever I heard one)
            May be poorly seated DDR SDRAM modules.
            Or the socket... (because it's LGA)
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
              Now that it's getting warm in the Southern Hemisphere, I can play in the workshop without freezing
              Inspired by
              http://mondotech.blogspot.com.au/200...spi-flash.html
              and
              http://www.mylesgray.com/hardware/fi...n-motherboard/
              I tried a reflash in situ
              Without success - maybe would have worked had I known at first, what I subsequently learned
                So I desoldered the BIOS chip - what a tiny little thing, beside a CR2032 battery for comparison
                  Then learnt the hard way how to reflash it with the latest Supermicro C7Q67 firmware image - which has changed, together with their reflash script, from the version I originally used
                  The Rube Goldberg setup used for reflashing, via the LPT port on another motherboard
                    The C7Q67 ready for replacement of its BIOS chip
                      Replaced
                        And all this effort rewarded
                          A pox on Supermicro and all their houses
                          My thanks to ReverendJones for setting me on the right track
                            Wow!
                            My hat off to you sir. That's a very good save right there .
                              Nothing like saving a Supermicro!!
                              <--- Badcaps.net Founder
                              Badcaps.net Services:
                              Motherboard Repair Services
                              http://folding.stanford.edu/
                              Team : 49813
                              Join in!!
                              Team Stats
                                The title should be:
                                Fixing a beloved Supermicro(the hard way)
                                Permanently Retired Systems:
                                Kooky and Kool Systems
                                sigpic
                                  I fixed an identical board here but afterwards noticed the MAC address for NIC1 was wrong.
                                  Instead of something sensible it was 88:88:88:88:87:88
                                  I found the following thread that described the use of Eeupdate which I've also attached to this post.
                                  The MAC address was printed on a sticker on the board and it was no problem to update it.
                                  There might be some more SMBIOS & DMI data etc still being wrong but at least the board seems to work fine like this with Server 2016
                                    The attached tool can fix the DMI data on the AMI BIOS for the Supermicro C7Q67
                                    Usage in MS-DOS as with the tool in my previous post.
                                    It has a built in help so it's easy to understand.
                                    Code:
                                    amidedos /SS 0123456789
                                    amidedos /SV V1.01
                                    amidedos /BS 0123456789
                                    amidedos /BV V1.01
                                    In the post I linked before I did dump my corrupted BIOS.
                                    The data is stored in the BIOS under GUID: FD44820B-F1AB-41C0-AE4E-0C55556EB9BD
                                    I could use AMI Aptio UEFI MMTool v5.0.0.7 to extract that module and confirm my serial number and board revision.
                                    (Which is also printed on a sticker & the PCB respectively).
                                    Of course I could also have replaced the module from my backup and flashed the BIOS.
                                    But as recovery of soldered BIOS chips is not my favorite past-time I prefer a nice MS-DOS utility
