Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
Elitedesk 800 G6 SFF Bios Password Lock XM25QH128A (3.3v) - Am I doing this right?
  • BrentH561
    • Jul 2011
    • 16
    Hello everyone, I am looking for help to make sure I am on the right track to remove lost BIOS Admin password on an HP EliteDesk G6 800 SFF. I recently purchased this on ebay and the seller is willing to accept a return but I have already installed my new HDs, NVME, and setup proxmox so I would like to keep it.
    Here is the hardware identification specs:
    HP EliteDesk 800 G6 SFF
    Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
    Serial No: MXL1223499
    Product No: 26S74UT#ABA
    BIOS/IC chip seems to be the 4 pin XMC XM25QH128A (3.3v). However most threads I have read regarding elitedesk bios have a 25B127DSIG so I am not exactly sure if the XM25QH128A is the correct one I should be reading/writing to eliminate bios password.
    Tools at my disposal:
    - CH341a programmer (black) unmodded showing 5v at pins – Will order CH341A V1.71.8V with level shift if necessary.
    - computer boots up (not currently bricked) running proxmox but I need to allow GPU passthrough which requires a change in the bios settings.
    - hopefully your help
    Troubleshooting:
    - Using NeoProgrammer 2.2.0.10 The device was automatically detected when Neoprammer was first opened. Search IC found 1 chip – Device: XM25QH128A. I then clicked READ IC which completed successfully. I then saved the .bin as XM25QH128A.bin.
    -I then dragged the XM25QH128A.bin on top of RCUnlocker v1.0 .exe. The opening screen displays “Unlock finished!” however underneath this text it does not display any system information which worries me something is not correct and thus the reason for this post.
    I have included both the .bin from Neoprogrammer (original) and the unlocked.bin from RCUnlocker in the attached zip file.
    - I did attempt to do CMOS reset via button + battery pull out but that only achieves 'bios defaults' reset and no BIOS Admin password removal.
    - Hobbyist experience with soldering wiring and led lights but no experience with this small soldering on board. Watched video on CH341A jumper mod and would rather just order the new version.
    Questions:
    1. Is the XM25QH128A the correct chip I need to unlock for bios pw reset?
    2. Is it safe to use the CH341a black on this chip or do I need to use the new version which allows for 3.3v?
    3. Have I completed the read process correctly and ok to proceed further utlizing Neoprogrammer to Erase IC then Write IC using the unlocked.bin produced by RCUnlocker ?
    THANK YOU GROUP !
    Premium supporters get full download access and other benefits.
  • BrentH561
    • Jul 2011
    • 16
    Any help appreciated
    • hoaca388
      Badcaps
      • Jan 2022
      • 12685
Name:	2024-09-08 10_54_07-Settings.png
      Bios is 16 pins chip , CH2568KIQ
      If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
      Subscribe to support us. It only takes 1 minute:
      https://www.badcaps.net/settings/subscriptions
      • EbrahimSiami
        Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
        by EbrahimSiami
        I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
        **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
        **What I have tried so far:**
        1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
        07-02-2025, 02:31 PM
      • intelg
        HP Elitedesk 800 G6 lost BIOS admin password
        by intelg
        Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
        HP EliteDesk 800 G6 Desktop Mini PC
        BIOS ver S21 Ver. 02.05.01 01/05/2021
        Born on date: 07/26/2021
        SN MXL11841GN
        SKU 3X8V9UCHABA
        UUID 8116E79EF6FFE94DB0B98A3188270C5C
        SYSTEM BOARD ID 8710
        SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
        11-03-2023, 02:05 AM
      • Luigi123
        Need full SPI BIOS dump – ASRock Z590-C/ac (CH341A recovery)
        by Luigi123
        I’m looking for a full raw 16 MB (128 Mbit) SPI BIOS dump for an ASRock Z590-C/ac motherboard.
        Issue / symptoms:
        The board powers on (fans spin, USB devices get power), but there is no POST, no display output, and no beep codes, even with a speaker connected and RAM fully removed.
        What happened:
        I attempted recovery using a CH341A external SPI programmer after a failed BIOS update. I flashed the official ASRock BIOS v1.30 file directly to the chip. I later learned this file is intended for Instant Flash only and is not a complete...
        01-16-2026, 12:49 AM
      • Deniz
        IdeaPad Gaming 3 16IAH7 BIOS Issue / GPU Not Detected
        by Deniz
        Bu: https://pcsupport.lenovo.com/tr/tr/p...065tx/mp2br7d9
        I have a Lenovo IdeaPad Gaming 3 16IAH7. When the device first arrived, there was no display at all.
        I had the BIOS cleaned, but the issue was not resolved and there was still no image.
        Later, I flashed a different BIOS dump from the same model. With this BIOS, the device boots and display works, but the GPU is not detected in the BIOS (RTX 3060 is missing).
        After that, I tried to update the...
        01-27-2026, 06:56 AM
      • Vesko356
        by Vesko356
        08-11-2023, 03:27 AM
