XGpro parameters?
  • Buzzfuzz2k
    • Nov 2023
    • 29
    • france
    XGpro parameters?
    Hi everyone.
    I have dumped a bios from a motherboard. The chip is a GD25B128E@SOIC8 and the T48 reconnised it without problem
    I have dumped the bios, modded it and burn back.... Computer screen is not lighting up anymore.... I tried to burn the original img but it's the same problem...
    There are some options in XGpro i don't know what they are for??? Can you please tell me what they are for and if i have to use them
    In reading mode, I have this:
    Do i Have to change "To region(buffer)" parameters?
    DO i have to "clear buffer" ?
    also, on "Write mode" i have this
    What is "OTP Secu R" for? do I have to use it?
    I fact i don't understand where i miss something... why if i burn the same IMG (orignal one) it still doesn"t boot like before ?
    Many thanks
  • cgtec
    • Feb 2014
    • 56
    • France
    • firmware and embedded systems
    can you share the dump ....
    • ttmi100x
      HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
      by ttmi100x
      Greetings everyone,
      I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
      The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
      Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
      Upon closer inspection...
      07-31-2024, 06:36 PM
    • howardc64
      Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
      by howardc64
      Eventually discovered a burn mark near lower corner of LCD. Here is a summary
      • Backlight on, no image
      • Disconnect right buffer board (view from front), left side display comes on
      • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
      • Buffer board is pretty simple
      Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
      07-11-2025, 04:04 PM
    • Remusutules1
      [Request] Intel DQ35MP dumped 4MB firmware in .bin format.
      by Remusutules1
      I need a dumped firmware for Intel DQ35MP motherboard after its firmware got corrupt in a bios update. I need the dumped firmware to be in .bin format and have 4MB in size, since the chip is 32Mb in size.
      02-14-2026, 08:46 AM
    • Tom41
      AOC U27G3X strange burn-in
      by Tom41
      I have an AOC U27G3X 4K gaming monitor that I use both as a TV and for gaming on a Nintendo Switch 2 console. Recently, something very strange has been happening to it. After playing a game that has an on-screen timer for a few minutes, the last digit of the timer (the one rapidly flickering from 0 to 9) appears to burn in on the monitor. Going to a different source or power cycling the monitor does not help; there is a constant flickering area on the screen where that digit was.
      It seems strange that only that digit would burn in, and NOT the other digits that are changing less frequently....
      10-23-2025, 04:33 AM
    • Kentsfield
      Lenovo Thinkcentre M75n DMI Data extraction from dumped BIOS
      by Kentsfield
      I got a Lenovo Thinkcentre M75n (MT-M 11G5 PF3XG5V3) with a semi-bricked bios.
      Short recap: I want to add an external GPU via the M.2 slot (Oculink). It does work but has some problems with the onboard GPU of the Ryzen 3 3300U. So I used Smokeless_UMAF to disable it. Since then I don't get any video via the external GPU nor the iGPU and Can't access the BIOS, but the PC does boot to the OS.
      I desoldered the flash IC MX25U12872F and dumped the flash.
      I also downloaded the newest BIOS and have it as a .bin file (I loosely compared the contents...
      08-04-2025, 07:46 AM
