HP 400 G9 MINI bios
Can someone help remove bios password, try several times using other patch procedure still same recover bios password
here is my dump
serial#: 8CC44704HHAttached FilesPremium supporters get full download access and other benefits.
Remove the CMOS battery before power on and hold ESC during startup. Be aware Sure Start can revert this change.Attached FilesPremium supporters get full download access and other benefits.
Hi. I flashed your 02.21.00 dump on my HP Pro Mini 400 G9.
Nothing changed. I flashed the EC from message 61. Same thing.
With the i5-12500T processor that was in the PC, the board reports no memory, but at 30 watts it freezes and then goes silent (it doesn't even get to USB initialization). Now I'm assuming my processor (i5-12500T) is partially dead and that's the culprit.
I tested it with an i3-12300T. I have two of them. With both, it returns error 3.6 due to the firmware being tied to the corporate ME. That's what I think, but maybe I'm wrong. Please advise.
I also tried putting an i5 14500 processor in there - error 3.4.
Perhaps you have a BIOS with a clean Consumer ME for regular processors, or could you tell me what's best to do here since I don't have a known-good i5-12500T to test and I have nothing to test it with.Comment
tryAttached FilesPremium supporters get full download access and other benefits.
hi
can someone help remove mdm please
regardsAttached FilesPremium supporters get full download access and other benefits.
If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
It only takes 1 minute:
https://www.badcaps.net/settings/subscriptionsComment
Hi again, The HP Pro Mini 400 G9 is a business/enterprise product line, not a consumer model
3.4 The system board displays a power failure (crowbar).*
3.6 The processor does not support an enabled feature.
I suggest moving to the parent Troubleshooting Section You might get the hardware-related help you need there
Maintenance and Service Guide HP Pro Mini 400 G9 Desktop PC > https://kaas.hpcloud.hp.com/pdf-publ...12_en-US-1.pdfComment
Hi, could you help me remove the BIOS password?Attached FilesPremium supporters get full download access and other benefits.
Hi, You have to post the Serial Number with every request (As per the Forum rules)
> RULES UPDATE for BIOS requests/offers *AVOID BANNING, READ BEFORE POSTING* - BadcapsComment
Flash only the main BIOS, remove the CMOS battery and hold ESC during startup.
hi try flash main then remove rtcAttached FilesPremium supporters get full download access and other benefits.
by ArzigolHello everyone!
I am looking for experienced BIOS modders who can help analyze or unlock the BIOS of my Acer Nitro Lite 16 NL16-71G.
Please note that this post was written with the help of ChatGPT because my English is limited. My native language is Russian. If anything is unclear, please let me know and I will do my best to explain.
Laptop Information
Model:
Motherboard:
CTE_NB_NL160P1G_RTH (NB6807C)
CPU:
Intel...-
Channel: BIOS Requests ONLY!
by rbdealmeidaHi everyone,
My name is Ricky and I'm a repair technician/enthusiast. I've been learning a lot from this community and have successfully done some basic BIOS unlocks in the past, but this particular modern HP model is giving me a really hard time!
I need some help manually removing the BIOS administrator password from this machine.
I have already tried using the "HP G9 Unlocker V3.0" on my 32MB dump. I successfully bypassed the U68 Sure Start chip (SPI NAND) by isolating Pin 8, preventing the auto-recovery. The machine boots and bypasses Sure Start,...-
by subzerilloHi guys.
I need some help with a laptop Dell that is locked with Absolute Lock, when powering up it will show Device Freeze screen.
Here are the details of the laptop:
Dell Inspiron 3505
ST: 2H1T883
Please help me remove the Absolute status, after that I just need to reinstall the Windows right?
Bios read with Xgpro T48, while chip was on the board. Hope the reading was correct....-
by berrylinxDell Latitude 7400 2-in-1 bios with absolute persistence lock, Service Tag: HRPJN53
Can someone please assist with this please. I've provided two dump files using Xgeco T48, one is the read and default saved and other is the Flash saved option, they're labeled according.
Thank You....-
- Loading...
