820-00967 - 051-01649 schematic
  • JOHNLAG7
    • Nov 2014
    • 19
    • Greece
    Here is the SCHEMATICS brd not available.
  • bcherdak
    • Oct 2017
    • 5
    • usa
    was anyone able to find schematic for this?
    • mesha1956
      • Sep 2025
      • UAE
      THANKS ALOT
      • ShadowAi
        ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
        by ShadowAi
        Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
        Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
        After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
        03-15-2024, 10:46 AM
      • skynet85
        VGC-LV1S MBX-199 M820/M830 find the schematics
        by skynet85
        The device is quite old, M/V MBX-199 M820/M830
        1P-0087J02-8011, the video chip flew (artifacts - no picture), removed the old one and installed a new one, but before installing the new one, the area under the video chip sank slightly and Pyataks were found, under a microscope, the contacts were not involved, it was decided to install. Now after switching on there is no initialization, all voltages are normal,
        I couldn't find a diagram, maybe someone will have one. The MBX-199 motherboard was also installed on these models, but I couldn't find the schematics for these either PCG-2E1M...
        12-04-2023, 02:37 AM
      • mgd
        MSI GF65 : Request help for find a burn IC ALHM 889 (or schematics)
        by mgd
        " Hello guys. i have a Laptop MSI GF 65 (motherboard MS-16W REV ) with à IC in short circuit. It's mark "ALHM 889"
        think it's the IC for regulate the Fan of GPU. I can't find any datasheet of this IC
        Can you post the schematics for this motherboard for locate the IC or tell me what it's the reel part number of this chip
        Thank you for the help. Really appreciate in advance
        09-28-2024, 03:52 AM
      • dbuergi
        Help to identify components / find schematics on a Flir Scout TKX board
        by dbuergi
        i got a Flir scout where a connector was ripped off and i will have to make new pads. One big problem i have right now is that 2 small smd components are missing near the pads and i was only able to find a comparable pic of this part of the board.
        So right now i need to know what i need exactly for a replacement and the values. I contacted Flir by mail but they don't give out schematics and told me that i can use the guarantee if i have it (funny guys).
        Anybody has an idea what i can do?
        09-09-2024, 03:11 AM
      • LA1
        Trying to find a datasheet for 2 smd's and the schematic for SMPS made by APEVIA
        by LA1
        I am trying to find two smd datasheets for an Apevia 1000w prestige power supply ATX-PR1000W the SMD's are ST9S313 which is a SMPS supervisory chip and a EST 915HP or XP48024 not sure which or both is the chp prod number and the schematic
        01-23-2024, 11:27 AM
