MSI MS-7A09 Schematic
  • black0ut
    • Aug 2020
    • 8
    • Austria
    Hi I would need the boardview for that board or the marking of the 8 pin between the caps and the buzzer.
    Thanks in advance
  • zhaoxin888
    • Dec 2021
    • 14
    • chiina
    Re: MSI MS-7A09 Schematic
    • AL._.EX
      • Dec 2022
      • 896
      • Belarus
      It motherboard desktop HP Omen 900
      • newtest
        • Apr 2022
        • 18
        • vn
        Originally posted by zhaoxin888
        thank you very much <3
        • black0ut
          • Aug 2020
          • 8
          • Austria
          Thank you very much
          • TinkerTron
            Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
            by TinkerTron
            Hey everyone,
            I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
            Instead, here's what's been bugging me so far:
            The schematic...
            03-06-2025, 02:03 PM
          • UserXP
            Vintage SONY Digital Clock Radio ICF-C12W no audio
            by UserXP
            Dear all,
            I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
            i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
            My question is, do you know of this brand of capacitors and how bad are...
            07-21-2025, 08:35 AM
          • PMDev
            Lenovo L13 Gen 2 20VH Schematic
            by PMDev
            I am looking for the schematic (PDF) and boardview file for the Lenovo ThinkPad L13 Gen 2.
            Here are the device details:
            • Type Number: 20VH-001NMX
            • Serial Number: R9-1092XF
            • Motherboard marking: attachment.
            If anyone has access to these files or can share them, I would be extremely grateful.
            Thank you very much in advance!
            Best regards,
            PMDev
            05-04-2025, 02:26 AM
          • Thetechdude
            MSI Ventus RTX 4080 16G Broadview schematic needed
            by Thetechdude
            Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
            I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
            Thanks.
            07-15-2025, 11:15 AM
          • ianpoultonknights
            Zenbook Flip 15 UX562AI schematic
            by ianpoultonknights
            Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
            06-26-2025, 02:41 PM
