Intel DH77EB schematic requested
  • BlueNGray
    • Jul 2023
    I have a DH77EB motherboard which has stopped responding to the power switch. I know that the power supply is not the problem, because I was able to get the computer to power up by momentarily pulling the PS_ON# line low on the power connector. This got me running for a while, but one day it got to the point where pulling the line low would cause the fans to start, but the fans stopped and the computer didn't boot when I released PS_ON#.
    I tried visually following the front panel power switch from where it arrived at the connector on the mother board to some point that I could do some tracing, but they did a good job of hiding it, so I'd love to see a schematic to see if there's any hope of salvaging this guy.
    Any help?
    Thanks.
  • emil_t
    RTX3090 working fine but fans not spinning
    by emil_t
    Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
    04-12-2024, 06:54 AM
  • b-slayer
    Asus Strix-G15-G513RM fans don't work
    by b-slayer
    I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
    The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
    (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
    (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
    ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
    09-04-2025, 04:58 AM
  • JayPoorJay
    Hot Water Rad - A Few ECU Fans and a Timer Switch
    by JayPoorJay
    Good Afternoon, Good People.
    I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
    I REALLY would appreciate y'alls help.
    This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
    10-29-2024, 12:54 PM
  • flat-earther
    HP F4180 stopped working please help troubleshoot
    by flat-earther
    I was doing a large print job with my HP Deskjet F4180, and after about 50 pages the printer stopped in the middle of a page and the black ink light started flashing.
    So I went to refill the black ink cartridge with a syringe, but found out it still had a lot of ink.
    I tried to print a page again but every time it would print only a bit of the page and immediately stop with the black ink light flashing again.
    I tried two other black ink cartridges, and the problem still endured, so I knew this problem had to be with the printer itself.
    I ran HP Print and Scan...
    05-11-2025, 02:21 AM
  • mferna14
    ASUS G513QE-SB91-CB freezes all of a sudden
    by mferna14
    Dear Friends., I am working on an ASUS Model: G513QE-SB91-CB, Serial # M8NRKD041417338, Motherboard: G513-6050A3249301-MB-A03(A3). The problem is that while using the laptop, just freezes all of a sudden., & sometimes while booting the ring stops to spin. I replaced with known good Memory & the a New SSD, installed Fresh Win 11 on this same laptop. Did not freeze during installation. But when re-booted, Win 11 boot ring stopped. I turned off from the power button. Again turned on & it booted well to Windows. Upon Windows update, it froze again. Even the BIOS has been updated &...
    11-28-2024, 08:21 PM
