Re: Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
Bump on this again? Really struggling to flash a BIOS to my chip; Tried using AMI's flash utilities as an alternative and got the below error:
127 - Error: Failed to load image into memory.
BIOS Guard is enabled, This feature may not be supported.
Any input from anyone at all would be very much appreciated.
Try our *UPDATED* boardview, bios, & schematic search. Over 2.3 million files for download!
Anyone that has any input on this or can help?Leave a comment:
Hey guys,
Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit so that flash descriptors are unlocked until reboot, and then flashed a modified flash descriptor with the HAP bit disabled so that it will persist over reboot and disable Intel Management Engine.
I thought that this would also enable write access for the BIOS region of my SPI, however it did not. After some heavy research, I found out that my BIOS has a Flash Protection Range Register option (hidden from the menu) so I booted into a UEFI shell and Disabled that option as well as the BIOS lock using datasone's setup_var.efi package here: https://github.com/datasone/setup_var.efi.
However it does not persist after a reboot. I noticed that whenever I modify the BIOS lock or even just the FPRR option and reboot, I get to the Lenovo BIOS screen and the screen goes black then reboots again, where it again goes to the Lenovo BIOS screen and ultimately will continue booting the OS. It seems like when this BIOS screen goes black and reboots, the modified setup_var's get reset to default.
Can anyone here assist me in disabling this Flash Protection Range Register setup_var? My chip is an XMC WSON8 chip and I would rather not have to desolder it from the board just to read/write to it if at all possible, I would like to keep this completely software-based.
I know its possible as the option is there in the BIOS, I just can't figure out why the OS won't boot if those options are modified and the BIOS will ultimately reset the values on its own. I do have Secure Boot disabled.
May I post my BIOS here for assistance? If so, would you need a full SPI dump (including DESC, ME, GbE, etc regions) or just the BIOS region?
Thanks in advance for any assistance!Last edited by abhorsen; 07-06-2023, 10:34 AM.Tags: None
by youngjaeHello,
My GIGABYTE B660M DS3H DDR4 Rev.1 motherboard is not powering on, and I am trying to diagnose the cause myself. I would appreciate any advice from people with experience in motherboard repair. 1. How the failure occurred
While replacing the PC case, the graphics card scratched the motherboard PCB, and one SMD component near the SIO (ITE IT8689E series) came off.
After checking the Boardview, I found that the component at that location was OBC16, a 22µF MLCC, 0603 size, so I purchased an identical-spec MLCC and soldered it back onto the board....08-31-2026, 01:12 PM -
by ekozeko333Hi all,
I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
🔥 The Problem Started After Suspected ESD/PD Fault
I experienced a power issue or ESD event through a USB-C charger
After that, the NX20P5090 power switch was visibly burned and was replaced
Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
🧠 What I’ve Done So Far
Flashed...-
Channel: BIOS Requests ONLY!
by corrizeHello, I'm stuck in troubleshooting…
The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
When I press the flash button, it's detected by the system, flash icon appear on LDC display.... -
by JayZeeHello everyone,
I am trying to repair a Samsung Odyssey G9 49" monitor and I suspect corrupted firmware / NVM data or a bad SPI flash.
Monitor details:
Model: Samsung Odyssey G9
Model: C49G95TSSR
Model code: LC49G95TSSRXEN
Type No.: C49G95TSS
Version No.: CA02
Mainboard: BN94-17725A
PCB: BN41-02843B
Firmware/platform marking: M-T9549GGAA-1017.0
Official Samsung USB update available: M-T9549GGAA-1020.0
Scaler/platform: Novatek NT68500 / T9549
SPI flash: Winbond 25Q40CLSIP (if it is the right chip)...4 Photos-
by ZingeHi everyone!
I'm trying to make a backup of the Flash memory from a Hanshow Nebular electronic shelf label. The controller on my board is marked Hanshow HS9118, which may be related to the Telink TLSR835x family, particularly the TLSR8359. I also have an NT083V electronic display equipped with a TLSR8359 chip.
I'm not interested in programming the microcontroller, writing code, or flashing alternative firmware. My only goal is to read the original memory contents and save them to a BIN file, if the chip allows it.
I want to preserve the original contents... - Loading...
