MSI Z590 MS-7D07 rev 2.1 EC Firmware
  • skynetto
    • Aug 2015
    • Italy
    Hello there.
    I have this mainboard (MSI Z590 Gaming edge - MS-7D07 rev 2.1) with these symptoms.
    1. SIO_3VA ON
    2. ATX_5VSB ON
    3. 3VDSW ON
    4. Mainboard stucked in Deep_S5 state
    Problem:
    RSMRST Incative. (Obviosly everything dead)
    Tried just for fun to update the BIOS with its Bios flashback function (Push button and USB stick with bios in it).
    Main Bios restored succesfully.
    When updating Bios all the voltages comes on except PCH which is not needed.
    EC Controller: NCT6687D-M
    External SIO Firmware on SPI Mx25v2033fm1i-hf
    Long story short:
    Replaced SIO Controller with china stuff: same behaviour
    Replaced SIO Controller with NCT6679D (took it from an ASUS). The voltages come on but the board does not start (different pinout)
    Cleared SIO Firmware on SPI and with original controller on: The board starts at full speed telling there is an error on RAM and after a minute the error moves to VGA.
    With the SIO Firmware cleared, i lost the Bios flashback function.
    Restored SIO Firmware and Bios flashback is on and running again.
    So basically i think there is some kind of corrupted EC firmware as the only thing i see with an oscilloscope there are a lot of communication between SIO SPI and SIO Controller and it seem to hang while reading from it.
    I am not able to exctract this firmware from the main BIOS (seems its not into it).
    With FlashImageTool i see only a EcFirmwarePointer wich leads to nothing.
    Now the question: What to do next?
    Thank you
  • Ahari
    by Ahari
    I...
    08-13-2025, 06:12 AM
  • DynaxSC
    by DynaxSC
    06-14-2024, 03:49 PM
  • pirati
    by pirati
    10-27-2025, 04:20 PM
    by Vesko356
    08-11-2023, 03:27 AM
  • grimacelord
    Foscam C1 V2 IP Camera BIOS/Firmware Help
    by grimacelord
    I am not sure if someone can help me with this or not. I am hoping someone can.
    I have a client who brought me a Foscam C1 V2 IP Camera after they disconnected power to the device during the middle of a firmware upgrade because they got impatient and thought it was frozen, so they disconnected the power despite a warning message telling them not to do that. Currently the device shows the power LED when connected to power, but it doesn't complete it's boot process and the camera is inaccessible on the network through Foscam's App for Android or the Windows application....
    11-12-2025, 10:23 AM
