Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
Hp EliteDesk 705 G4 SFF bios required.
  • AlexPas
    • Dec 2024
    • 7
    • Greece
    How can I do that ? Can I use the LBE++ program to fix it as that video ( https://www.youtube.com/watch?v=lLj8GHZgveU ) ?
    Thank you.
    • AlexPas
      • Dec 2024
      • 7
      • Greece
      Hello again. Can you check if that file bin file (final_G5_MT_with_details.BIN) is ok for bios installing. I add also my original corrupted one (corrupt_G5_MT.bin).
      ​Thank you.
      • Description: HP EliteDesk 705 G4 MT
      • Serial Number: CZC932CMJD
      • Product Number: 3AB55AV
      • BID: 18WWF7FT6**#SABU#DABU
      • Feature Byte: 3E3X 475K 6J6S 6b7B 7H7M 7Q7T 7W7m aBapaqau bhcA dUdp dqhK hZjh .Rr
      • hoaca388
        Badcaps
        • Jan 2022
        • 12664
        ​Thank you.
        HP EliteDesk 705 G4 Microtower PC RCTO Base Model
        • AlexPas
          • Dec 2024
          • 7
          • Greece
          So I have only to inject the Pc details into the Base model file, that you provide me, at the correct place and the bios file can run ?
          Thank you
          • SomnusDisney013
            • Oct 2022
            • 20
            • Poland
            Computer won't start. Can someone fix BIOS?
            SN CZC9457HLS, HP 705 G4 SFF, PRODUCT 3AD02AV
            • hoaca388
              Badcaps
              • Jan 2022
              • 12664
              #26
              Did you get the wrong file ? 20250219_121049_W25Q128JV-klucz.bin , this is DELL bios.
              • SomnusDisney013
                • Oct 2022
                • 20
                • Poland
                #27
                I apologize profusely. I mistakenly selected a different BIOS. That one comes from a motherboard where the bridge is damaged.
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12664
                  #28
                  HP EliteDesk 705 G4 Base Model Small Form Factor PC
                  • vagomauro
                    • Oct 2024
                    • México
                    #29
                    Hello, could you please help me with the BIOS for an HP EliteDesk 705 G4 MT. The only light on the computer is red and the fans are spinning. I noticed it has three chips identical to the BIOS, but only one is labeled as BIOS on the motherboard
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12664
                      #30
                      You MUST:
                      • Read BIOS guides, methods, resources and tools
                      • Try the method at BIOS guides, methods, resources and tools before requesting help
                      • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                      • Use search function in case someone already answered your request
                      • Post under a related thread if it exists
                      • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                      • Name your thread with make, full model numbers and request
                      • Provide a BIOS/EC dump if possible
                      • Attach files directly to your post instead of linking to external websites
                      • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
                      • svyato15
                        • Jul 2025
                        • Україна
                        #31
                        Hi. Could you help with the bios?
                        HP 705 G4 SFF
                        PRODUCT 6ZU04UC#ABA
                        SN MXL92644YV
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12664
                          #32
                          HP 705 G4 SFF
                          PRODUCT 6ZU04UC#ABA
                          SN MXL92644YV
                          I can help but what help ?
                          • svyato15
                            • Jul 2025
                            • Україна
                            #33
                            I have an HP 705 G4 but it has a problem with the password set on the BIOS, I would like to flash it with a fresh BIOS but with my serial number, but I don't know what lines to copy into the editor.
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12664
                              #34
                              Unlocked
                              • svyato15
                                • Jul 2025
                                • Україна
                                #35
                                Unlocked
                                Thank you very much!
                                • t4x
                                  • Jul 2023
                                  • Usa
                                  #36
                                  HELLO
                                  I NEED ELITEDESK 705 G4 65W
                                    • 23075
                                    Originally posted by t4x
                                    HELLO
                                    Post the serial number - https://www.badcaps.net/forum/troubl...18#post3666218 and explain what the problem is..
                                    • t4x
                                      • Jul 2023
                                      • Usa
                                      #38
                                      SN:MXL9332RZG
                                      PN:3AE45AV
                                      PROBLEM:NO DISPLAY
                                      • Square squirrel
                                        • Jul 2023
                                        • dsfsdfe
                                        #39
                                        Hello Could someone help me please? I've tried to update my BIOS on HP EliteDesk 705 G4 Small Form Factor with the programmer CH341A and AsProgrammer utility. I downloaded BIOS from HP site but realised that size of those BIOS is bigger only when program sad "BIOS file is bigger than flash". Before that I did a dump, so I've tried to flash it back but system won't start with post code signals that BIOS is incorrect (2 long signals with white led and 4 short signals with the red one). What I did wrong? What should I do now? Can somebody help me to fix it?
                                        Serial № MXL9263WT6
                                        Product № 6ZU04UC#ABA
                                      • Danmoh
                                        • Sep 2021
                                        • 66
                                        • Kenya
                                        #40
                                        HP Elite desk 705 G4 MT.
                                        Product number: 6RX05US
                                        Serial number: MXL9283DQG
                                        Bios q09 version.
                                        Powers on.no display.kindly repair my attached bios thank you
                                        • intelg
                                          HP Elitedesk 800 G6 lost BIOS admin password
                                          by intelg
                                          Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
                                          Here is the hardware identification specs:
                                          HP EliteDesk 800 G6 Desktop Mini PC
                                          Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                                          BIOS ver S21 Ver. 02.05.01 01/05/2021
                                          Born on date: 07/26/2021
                                          SN MXL11841GN
                                          SKU 3X8V9UCHABA
                                          UUID 8116E79EF6FFE94DB0B98A3188270C5C
                                          SYSTEM BOARD ID 8710
                                          SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
                                          11-03-2023, 02:05 AM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • BrentH561
                                          Elitedesk 800 G6 SFF Bios Password Lock XM25QH128A (3.3v) - Am I doing this right?
                                          by BrentH561
                                          Hello everyone, I am looking for help to make sure I am on the right track to remove lost BIOS Admin password on an HP EliteDesk G6 800 SFF. I recently purchased this on ebay and the seller is willing to accept a return but I have already installed my new HDs, NVME, and setup proxmox so I would like to keep it.
                                          HP EliteDesk 800 G6 SFF
                                          Serial No: MXL1223499
                                          Product No: 26S74UT#ABA
                                          BIOS/IC chip seems to be the 4 pin XMC XM25QH128A (3.3v). However most
                                          08-23-2024, 08:36 AM
                                        • surcharge6650
                                          HP Elitedesk 800 G4 SFF BIOS/EC firmware error (Code 5.2) - Fixable?
                                          by surcharge6650
                                          Hello guys,
                                          I stupidly tried to read out my BIOS & EC flash (with a clamp). This didn't work, I only read FF's. But after this operation, the PC is not longer turning on, just beeps 5 times (and blinks red) then 2 times (blinks white). The manual says this is the error code for: "The embedded controller cannot find valid firmware.".
                                          I think it locked itself because of my experiment. Is this fixable? I now removed both chips from the board and dumped them, I attach the files in this post hoping someone can help me fix my stupid error. Thanks so much in advance anyone...
                                          12-11-2025, 09:44 AM
                                        • brispuss
                                          Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
                                          by brispuss
                                          Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
                                          Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
                                          I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
                                          12-28-2022, 02:58 AM
