boardview/schematics for MSI Z690-A PRO (MS-7D25)
  • DynaxSC
    • Apr 2021
    • 477
    • Poland
    Looking for a boardview/schematics for MSI Z690-A PRO (MS-7D25) - would appreciate if somebody could post.
    Alternatively if someone could kindly measure the two missing components on this first image below (probably resistors):
    Second image for orientation on the place on the board:
  • DynaxSC
    • Apr 2021
    • 477
    • Poland
    Re: boardview/schematics for MSI Z690-A PRO (MS-7D25)
    Have determined the components by buying a second broken board. It came out that beside the missing components on the frist board both boards have broken Z690 chipsets, so seems these boards are some kind of chipset killers or just these Intel chipsets are some kind of crap produced by Intel. Have got now new chipsets from Ali, will try to replace them. But funny is, that at least the first board the chipset in broken only partially, as it generates correctly SLP_S3#, but hangs then later on communication with CPU, and CPU VCORE is not initiated at all.
    • McWhitePink
      • Apr 2023
      • 103
      To replace the z690 chipset, do you need to flash the BIOS? I heard if you don't flash the BIOS the boot up time will be extreme long.
      • DynaxSC
        • Apr 2021
        • 477
        • Poland
        Re: MSI Z690-A Pro DDR4 (MS-7D25
        Boardview attached
        • topway
          • Jul 2020
          • China
          Please share the circuit schematic ,Thank you
          Boardview attached
          • DynaxSC
            • Apr 2021
            • 477
            • Poland
            Schematic for MS-7D25 is unfortunately not available anywhere so far.
            • CG_Dionysos
              MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
              by CG_Dionysos
              I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
              • Model: A1707
              • 15-inch, Mid 2017
              • 3.1 GHz Core i7
              • 16 GB RAM
              • Radeon Pro 560
              • 1 TB SSD
              • Board number: 820-00928-A
              I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
              Thanks in advance!
              Greetings from Germany...
              09-16-2025, 06:43 AM
            • Tribalus43
              Lenovo Thinkpad T14 gen 2 intel schematics/boardview
              by Tribalus43
              Request: Lenovo ThinkPad T14 Gen 2 (Intel) Schematics/Boardview
              I’m looking for the schematics or boardview for a Lenovo ThinkPad T14 Gen 2 (Intel) with the following board:
              HT4B07HP4B0 / HT5B1 / HP5B1 / HT4B2 NM-D352 Rev: 2.0
              I’m currently dealing with some startup issues and would like to test for shorts. Any help would be greatly appreciated.
              Thanks!
              09-01-2025, 12:10 PM
            • Jag013
              HP OMEN 15-ax204ns Boardview and schematics
              by Jag013
              Hi, I need the boardview and schematicsfor an HP OMEN 15-ax204ns laptop, purchased in 2018, with the following specifications:
              • Processor: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
              • RAM: 4.00 + 4.00 GB
              • Hard Drive: 1TB
              • Product ID: 00325-96088-89605-AAOEM
              • N/S: 5CD70805T8
              I’m trying to repair a short circuit in the battery charging section.
              If you can help me locate the boardview and schematics or a boardview file, I would really appreciate it.
              Thank you for your help!...
              07-02-2025, 02:15 AM
            • Daniel Kubica
              Lenovo Thinkpad T14 Gen 1 NM-C801 Schematics and Boardview
              by Daniel Kubica
              Hi, I needed a schematic and boardview for this motherboard earlier and I found out it's not available to download on here as the links expired, so I found it myself, hope it helps someone.
              Schematics and boardview attached below....
              06-25-2025, 05:02 AM
            • Factiss
              ASUS G713QE-HX043 Schematics and boardview
              by Factiss
              Can anyone get a hold of the schematics and boardview for the Asus laptop ROG Strix G713QE-HX043 ! I have a motherboard that is missing parts, I would like to replace them but I can't find a boardview or schematics for it anywhere. Motherboard part number : G513-6050A3249301-MB-A04( A4 )
              THANKS !!
              04-26-2024, 07:51 AM
