MSI RX6900XT - i fcked up - shorted TOUT with BOOT on
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3577
    • slovakia
    MSI RX6900XT MS-395 r5 - i fcked up - when measuring i shorted TOUT/FLT with BOOT on DRMOS. now i dont have main VGPU
    what can be bad? did i burn XDPE132G5D ?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3577
    • slovakia
    Re: MSI RX6900XT - i fcked up - shorted TOUT with BOOT on
    god bless AMD for fusing everything. i find that my short blown one of OptiMOS and 20A fuse. after MANY usoldered/soldered capacitors and coils and three hours of work my mistake is repaired.
    But this OptiMOS i cannot find to buy. I have this AON5470 with same layout from RX6800. Have anybody datasheet for it to check if have enought current to use it?
    • MasterCap
      • Jul 2022
      • 37
      I soldered a wire onto the bottom side PCB, to get at the enable pin of a DRMOS, and now the resistance of the pin reads way more, even with the wire removed again. I don't get how I damaged anything.
      I barely touch these when powered, I'd fry too much stuff.
      • DynaxSC
        • Apr 2021
        • 453
        • Poland
        The 5470qe is probably a custom chip, no datasheet/public offer available, only solution is buy another broken card and use it as donor. You can try to write to Alpha&Omega, but wouldn't expect a helpful response. Remember that MOS devices can change and hold some time state during measuring from non-conducting to conducting and vice versa only due to the applied measuring voltage (gate must be included, state depends on polarity applied to gate), so sometimes it's possible to measure completely different values, and this must not mean, that the device is broken.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3577
          • slovakia
          guys anybody know where can buy this TDA21490 ? Best from ali or ebay
          • petehall347
            • Jan 2015
            • 4426
            • United Kingdom
            looks like they are on backorder
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3577
              • slovakia
              i canot find this chip anywhere. who kows where i find this TDA21490
              or i find simillar HIGH CURRENT ic ISL99390
              have somebody datasheet with pinout to compare these two?
              • blghn
                • Sep 2022
                • 3
                • TÜRKİYE
                Hi, my RX 6800 is shorted. I have to find 5470QE. Unfortunately, none is selling it. How did you find it? Is TDA21490 proper and equivalent?
                • Andi992
                  Acer Nitro shorted PCH doesnt Boot an517-52
                  by Andi992
                  Hello, after changed the shorted PCH Hm470 the Notebook have good value in the cool. Blue light comes on once U Press Power but nothing more Happening.
                  It have before a short on one Cap near the ALC Soundchip. I fixed the shorted Cap.
                  BIOS and EC BIOS are also new but still nothing Happening.
                  CPU has No Short.
                  Orderd a new alc295 can it BE that the Sound IC is Not good and thats why IT doesnt start.
                  There is also Missing a inductor near the 19,5v Port but IT should still Boot without it.
                  09-02-2024, 08:51 PM
                • privato89
                  Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                  by privato89
                  I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                  Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                  Let's begin:
                  Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                  03-26-2024, 06:37 AM
                • reessi
                  Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                  by reessi
                  Hello:
                  I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                  I started on the ACER:
                  Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                  All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                  I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                  10-29-2024, 11:31 AM
                • S14Sr20det
                  Samsung QN65Q60RA boot loop “shorted lcd” repaired
                  by S14Sr20det
                  Hello all. First time posting but long time lurker here.
                  First off I am not expert but I do know my way around electronics and have a fairly good grasp on troubleshooting them.
                  I acquired this tv for free from a neighbor who had a repair man out and diagnosed it having a shorted lcd panel.
                  Symptoms were that I would start up and reach the Home Screen and work for thirty or so seconds then the lcd would fade to black and enter a boot loop where it would get shorter with each attempted boot.
                  Went through the basic trouble shooting...
                  04-01-2023, 11:22 AM
                • hinisa
                  Xiaomi router freezes at boot after re-capping
                  by hinisa
                  I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                  When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                  After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                  Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                  07-08-2023, 05:58 AM
