rx580 not detected/ no display/ messing with primary card
  • woody-009
    • Sep 2021
    • 26
    • australia
    Hi everyone
    I've got a bit of a funny one, I've got an rx580 that is not detected/ wont display. It had all of the voltages needed on the core, memory, memory controller, 1.8 and 1.8 enable but the core wasn't getting warm. I found a 1k ohm resistor that was maybe missing from the pex reset A11 pin (R120 it didn't look like it was originally there but is on the board viewer). Now my core is starting to get warm but its still not detected. I have found that I don't have a 3.3V VDDC_VDDCI_PWROK signal because I don't have a 3.3V VDDC_PWR_GOOD signal to the nc7sz08p5x U1000 chip, I do have 3.3v PERSTB_BUF. I have tried putting a 5k ohm resistor from 3.3V to the power good pin but I still get no output for power ok. Is there anything else I can check? It also stops the fan from spinning on my main card if I run the faulty card as a second card. I also get no fan spin on the faulty card on windows but the fans initially spin on my HiveOS Linux machine. I do have a couple of cards here that i can check voltages and stuff on.
    Thanks, Kurt
    Gigabyte AORUS Radeon RX 580 (RX580) Graphics Card Boardview
    Gigabyte AORUS Radeon RX 580 (RX580) Graphics Card Boardview...
    10-28-2024, 12:17 PM
  • Christos Tsiligiannis
    Marian Trace Alpha sound card repair help
    by Christos Tsiligiannis
    Hello to the forum.
    My name is Christos, I am new to the forum here and i am posting from Greece.
    So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
    To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
    So i tried asking for a schematic from the company and they would not give me one. Instead they...
    11-18-2024, 05:26 AM
  • Kemer
    Graphics Card mounting frame
    by Kemer
    Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
    As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
    I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
    What worries me right now is the possibility that...
    09-14-2024, 08:57 AM
    HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook Specification for Upgrade or Repair
    This specification for the HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) boardview and 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
    09-06-2024, 08:30 AM
    Alcor AU6368 USB 2.0 Flash Memory Card Reader Datasheet
    The AU6368 is an integrated single chip memory card reader controller specially designed for notebook, hand-held and other PC peripheral devices, which require fewer components for small PCB area. It supports a widely used flash memory card such as CF, MD, SMC, xD Picture Card, MS, MS Pro, MS Duo, SD and MMC. It can be used as removable storage disks in enormous data exchange applications between PC and PC or PC and various consumer electronic appliances.
    The AU6368 reads digital content saved on memory card that user captured with the portable device such as notebook, digital camera,...
    10-23-2024, 03:26 AM
