Finding a dead short component
  • Beton
    • Dec 2021
    • 10
    • Hungary
    Hi guys!
    I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
    So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
    I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
    I have a bench PSU and if I try to inject voltage the voltage drops to ~0.1V (if I remember correctly). I can go up to 6-7 amps but nothing gets hot at least not in a way I can feel it with my hand/fingers or can see it with ipa.
    Obviously taking into consideration Ohm's law this is expected.
    I suspect I killed these cards a long time ago by applying a lot of current (if they were not dead before) nevertheless I don't want to make the same mistake in the future.
    So I tried measuring the resistance at different points on that rail but my multimeter only shows four digits in ohms mode. The lowest on the rail was 00.21 ohm but that's the resistance of the leads...
    I tried measuring voltage at different points (while injecting voltage), I can measure 4 digits in millivolts but that didn't show me anything meaningful (or I'm just stupid).
    So what do you suggest? I've seen a Northridgefix video in which the guy pinpointed the location of the short on a dead shorted board with a Flir cam, the heat spot (mosfet) was barely noticable on the cam (only a few degree difference vs the board) so even with a Flir cam it's not easy but I don't have a Flir cam.
    How do you deal with this situation?
    Thank you in advance.
  • foshland
    • Jan 2017
    • 122
    • Spain
    Re: Finding a dead short component
    Hi, first of all, how many volts did you inject? You should never inject more than the rail is suppose to have in working condition, for example, in Vcore, never go up to 0.8 or more, on memory work with 1V or near it.
    Have you tried with alcohol? it disipates faster in the heated zone, apply in the suspected zone and inject, maybe you find it.
    Some people uses flux atomizers, others thermal cams. I invested in a Seek thermal cam for mobile phones, 250-300$ and is a good invest for this and other things
    • Beton
      • Dec 2021
      • 10
      • Hungary
      I tried with 1V, I know it has to be equal or lower than the rail voltage itself. But it doesn't matter because the short protection lowers the voltage on the psu.
      I tried the alcohol method, ipa is isopropyl alcohol. Btw a 0.1 ohm resistor was the hottest (barely noticable hot) by my observation with ipa but the resistor is fine.
      I haven't tried the flux atomizer yet.
      I'm asking this because as I said a 0 ohm dead short not gonna get hot, that's the whole point.
      • DynaxSC
        • Apr 2021
        • 463
        • Poland
        U can try to examine the MLCC caps with a magnifier glass, sometimes the shorted caps have some visible irregularities. Other way is apply more amps, with 15-20 amps, you schould be able to observe faster disappearing of alcohol, however it is not easy to get 15-20 amps with a normal psu. I put two 10 amps psu's in paralel. You might also see the area where most current is flowing narrowing the search. Cables must be thick too. The not easy way is desolder the rams and gpu, then you must not care so much of voltage, as caps have usually higher tolerances. But you need then to reball the devices and solder back after shortage found. Do it only if you know how to. Another method is to measure when injecting the voltage on the caps in a sensitive mv range with a high resolution meter, the voltage near the short will be with good chance dependent on the board topolgy and injection point lowest.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          getting two PSUs in parallel is also a feat...not all can be connected in parallel.
          A low resistance device will indeed get hot if you force it...
          • Beton
            • Dec 2021
            • 10
            • Hungary
            Wouldn't applying such high amperage destroy the traces? I know these VGAs in question might be already totally dead but in case I run into something else with similar problem.
            Btw it just occured to me that the testing probes were hot when I injected voltage, I mean I could feel it but nothing serious... but not the VGA.
            My psu on paper is capable of 30V/10A.
            • DynaxSC
              • Apr 2021
              • 463
              • Poland
              Hi, I did go to ca 15A on different GTX1070, you need to do it step by step, not 20A at once, this can lead to track burnout, but if you do it with care and slowly, you should be safe on the safe side. Also it is not easy to get 20A with 0,8V, due to the supply cable resistance. If you have luck, 10A might be enough, depends on "how good" the short is. The alternative is to desolder all caps one by another, could be time consuming and destroy the board too from heat.
              • DynaxSC
                • Apr 2021
                • 463
                • Poland
                ... and solder the supply cables to the board, the positive lead after the coils, eg. on the memory secondary coil side, and the negative lead somewhere to the video output sockets on the back side of the card, and observe what is happening when increasing the amperes, I use my hand to do it, the best tool to feel the heat, however do it with care, at least the first touch should be very short. Isopropanol is also OK, and has the protective advantage, that it takes heat when vaporating, at least for a short time when something becomes really hot.
                • Victor Moreira Silva
                  Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                  by Victor Moreira Silva
                  I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                  Well, my decice specs are the following:
                  Model: Acer Nitro 5 AN517-54-55T5
                  CPU: Intel Core i5-11400H
                  GPU: NVIDIA GeForce GTX 1650
                  Motherboard: GH51G LA-L181P Rev:1c
                  The symptom:
                  When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                  05-26-2025, 10:49 AM
                • grimacelord
                  Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
                  by grimacelord
                  Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
                  After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
                  I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
                  10-24-2024, 12:31 PM
                • nagkiller
                  Asus Geforce Cerberus GTX1050TI-O4G-DIS short circuit in the FBVDDQ rail
                  by nagkiller
                  Hello everyone!
                  This grafic card came for repair, but when I connected it to the motherboard, the board would not start (short circuit in the 12V rail).
                  After removing some PLs to isolate the short in the 12V rail, I got to PML1/PML2, according to the BoardView reference.
                  Even injecting a voltage of 1V0 and a current of 3A in the FBVDDQ rail, for example, the voltage drops to 0V20 and none of the components heat up.
                  The attached boardview file is very similar to this grafic card, which I am basing the repair on.
                  I would like some...
                  05-10-2025, 09:19 AM
                • ktmmotocross
                  Asus UX433FAC - batery dead after short on VIN rail
                  by ktmmotocross
                  Hello.
                  Have this Asus UX433FAC that came with shorted mosfet on main power rail. After replace laptop works ok, but battery is dead. Laptop show charging but voltage on battery is 0.2V. when remove battery voltage on battery connector goes to 8.5V, but when connect battery again it goes down to 0.2V.
                  can that short shorted battery? batmon show that battery is full at 80%
                  12-29-2022, 12:06 PM
                • playit
                  450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
                  by playit
                  hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
                  09-02-2023, 02:43 AM
