Re: XFX RX 5700XT No Display
Sadly there is no schematics for this card as I was searching the interenet . Some specialist here on forum sent me a private message on what to test , but I cannot understand quite well . Maybe you can help me out on this :
(Try it with a mining adapter in single PCIe lane mode
Have a look at the resistance to ground (use doide mode) on all the PCIe lanes - both the side which has a direct connection and the side which has the little capacitors on each pair of tracks. On this check from the capacitor to ground, not ht ePCIe finger to ground. They should all read the same - any reading different suggests bad GPU
Have a look at the reset signal coming from the PCIe (SMRST) it is usually ANDed with the Power Good coming from the last vrm to power up - check as best you can this is getting to the GPU) .
I will attach a photo with what I think I should measure in diode mode . Is this pcie lanes (with green circle around them) ?
Ok now check with multimeter on resistance mode if the side which gave the wave signal and pin 6 of the bios chip have a direct contact. should look like a short. I would say test Pin 6 again too if required.
Now this is what i'm assuming as this has reached outside my league. i would wait for someone with more knowledge to assist here.
Yes , it has resistance and quite big (6,12 mohms)Leave a comment:
Now this is what i'm assuming as this has reached outside my league. i would wait for someone with more knowledge to assist here.Leave a comment:
So pin 8 has 3,3 V , but unfortunately there is no noise on pin 1 (tested with osciloscope) - also pin 1 has 3,3v (just measured it) . Also pin 2 and 5 both produce some weaves on the osciloscope , but unfortunately pin 6 doesn`t do anything (same as pin 1) . Unfortunately I don`t have a CH341 programmer to unsolder the chip from the board and test it out . I fear the worst that the GPU chip may be goneLast edited by frazerxavier; 01-28-2022, 11:18 AM.Leave a comment:
So pin 8 has 3,3 V , but unfortunately there is no noise on pin 1 (tested with osciloscope) - also pin 1 has 3,3v (just measured it) . Also pin 2 and 5 both produce some weaves on the osciloscope , but unfortunately pin 6 doesn`t do anything (same as pin 1) . Unfortunately I don`t have a CH341 programmer to unsolder the chip from the board and test it out . I fear the worst that the GPU chip may be goneLeave a comment:
I have added and example from a RX 580 which uses a chip from the same manufacturer.Last edited by frazerxavier; 01-28-2022, 11:00 AM.Leave a comment:
So I took some voltage and resistence check-ups and I got the following results (posted in the pictures above) . Any suggestions where to check or what to do next ?
LE : Just tested the bios pin with an arrow pointed towards it , and the osciloscope doesn`t sense anything when powering it up .
My understanding is if there is VCC (3.2V) on pin 8 and there is clock on pin 6 but nothing on pin 1 (no noise) and the BIOS chip is readable by the CH341 programmer, the GPU chip is the problem. I may be wrong but I'm sure someone can throw some light here.Last edited by frazerxavier; 01-28-2022, 10:48 AM.Leave a comment:
LE : Just tested the bios pin with an arrow pointed towards it , and the osciloscope doesn`t sense anything when powering it up .Last edited by Goblin999; 01-28-2022, 09:24 AM.Leave a comment:
I am not an expert but if you take a look at the image at the start of the post it shows the measurements at every point on the graphic card, you can refer to these points to take measurements on your card at the same points to get a better understanding of what the card is doing. Secondly with your multi meter in diode mode test the PCIE lanes coming from the GPU. Remember they are all in pairs. It does not matter what the reading is but the reading should be in the similar range on all pairs (16 pairs in total). Check the caps on the first pair on the back connected to the PCIE lane (closest to the 12V @3.3V from PCIE. I have uploaded am image marked with a green circle ) if its present or missing. I am sure with some readings on a pic of your card someone here will be better equipped to help you. For me I had returned the card back to my friend and he sold the card so i could not continue the work on the card. You would need some kind of heatsink and thermal paste to pop on top of the CHIP when testing voltages.
Thanks a lot for the fast reply . Will be getting back on the card later today as now I am at work . I literally don`t know how to test if the GPU chip is gone or not . I was assuming that if the chip get hot is still working properly , but I don`t know much about itLeave a comment:
I also got an RX5700 XFX DD that has the same issue as yours . The GPU gets warm-to hot when powered up . I first measured for shorts on 12v and 3,3v rails and seems good . Card does not get seen at all in HIVEOS . I measured some resistance on various parts and they all have some ohms but I don`t know which is good or bad becauseI just started to repair GPU , inspired by @dicky96 . I did not test voltages because I stop the card as the GPU chip is getting warm and I didn`t want to brake it . The thing is some guy who sold me the card told me that he went to a repair shop and they said the GPU core is bad . Could that be possible and the GPU still get warm to hot when powered up ? Can anyone help me into pointing where to look ? Thanks a lot guysLast edited by frazerxavier; 01-28-2022, 05:01 AM.Leave a comment:
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Nitro Nitro 5 AN515-56 - (Intel Core i5-11300H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce GTX 1650 4G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-56 - (Intel Core i5-11300H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce GTX 1650 4G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-56 - (Intel Core i5-11300H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce...09-06-2024, 11:40 PM
This specification for the Acer Predator Predator Helios 300 PH315-53 - (Intel Core i7-10750H, 16 GB, 512GB PCIe NVMe SSD + 1TB HDD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Predator Helios 300 PH315-53 - (Intel Core i7-10750H, 16 GB, 512GB PCIe NVMe SSD + 1TB HDD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Predator Helios 300 PH315-53 - (Intel...09-06-2024, 10:20 PM
This specification for the Acer Aspire Intel Core i5-10300H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce GTX 1650Ti 4G, 15.6" FHD IPS Display, Windows 10, Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Intel Core i5-10300H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce GTX 1650Ti 4G, 15.6" FHD IPS Display, Windows 10, Black boardview and Intel Core i5-10300H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce GTX 1650Ti 4G, 15.6" FHD IPS Display, Windows 10, Black schematic....09-06-2024, 11:20 PM
- Loading...
