AMD HD 6990 old beast very low 3.3 V resistance
  • aysat
    • Feb 2015
    • 17
    • Kazakhstan
    Hi guys,
    i have a hd 6990 which has 2 gpus in a pcb. the odd thing is the card works but 3.3V line has various resistance readings. mostly 0.7 ohm and sometimes i read 1 kohm. both cases the card runs just fine but 3.3 V line becomes very hot due to low resistance,i guess. especially dc to dc buck convertor on the riser. it reaches 95 C degrees in 5 minutes. a good working card makes it run at 45 C degrees usually. what should be my next move ? inject voltage from 3.3 V to see what is causing extra heat and check with thermal cam ?
    any suggestions will be appreciated. i can upload photos if needed.
  • aysat
    • Feb 2015
    • 17
    • Kazakhstan
    Re: AMD HD 6990 old beast very low 3.3 V resistance
    no ideas?
    • mon2
      • 14171
      Never worked on video cards before but could the issue be dry / old heatsink compound on this video card? Can you confirm the required chips are being dissipated of the heat properly? There are some great current heatsink pads (T-Global, Taiwan) and heatsink pastes that are worth trying to reduce this heating.
      Otherwise, would say that you have possible stale caps due to the very low resistance on the 3v3 rail. Can you compare the resistance against a known good video card?
      • aysat
        • Feb 2015
        • 17
        • Kazakhstan
        heatsink is fine. a good working card has more than 250 ohms
          master hoarder
          • May 2008
          • 12175
          Originally posted by aysat
          Hi guys,
          Try the video card directly into a motherboard without a riser and see if 3.3V line going to the card is still dropping. If it is, check the RAM VRM / MOSFETs, as those sometimes get power from 3.3V rail (not always though.) There should also be a linear regulator or two that take 3.3V and convert it to lower voltages required for starting up the GPU chip (hence why if you disconnect power cables from the video card, it can still show a message on the screen, telling you that the power cables are disconnected.)
          If you do have a thermal camera, that could actually help see if anything is getting abnormally hot on the video card PCB... so give that a try as well.
          BTW, RAM Vdd/Vddq VRM should have a resistance of around 10 to 200 Ohms (varies, depending on the type and number of RAM chips used, as well as manufacturer.) 0.7 Ohms sounds more like a reading for the GPU Vcore(s).
          • lezsimply
            Low resistance reading on 3v line, Asus Prime H310M-A R2.0 desktop motherboard
            by lezsimply
            Hello Everyone and Good Day,
            I've got an issue with this desktop motherboard. It does not power on, Asus Prime H310M-A R2.0. I tested 33ohms reading on 3v line on the ATX connector. It beeps on continuity mode. I tried injecting voltage from 0.9v at 1.5amps and no current being drawn. I raised the voltage to 3v @ 4amps and now I only get 22mA on current. I checked with thermal camera and there is no part heating up. I'm afraid of going further the safe voltage. What could possibly causing the line to be shorted. 5vsb has no short. I get 0.9v on positive pin of power switch. There's...
            11-22-2024, 03:14 AM
          • cind12
            GTX 1080 TI Gigabyte Aorus low resistance on vmem
            by cind12
            Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
            Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
            The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
            Resistance on 12V 4K ohms (Power present when on)
            Resistance on 12V PEX 4K ohms...
            12-08-2023, 09:09 AM
            MEDION ERAZER Beast X40 Notebook Specification for Upgrade or Repair
            This specification for the MEDION ERAZER Beast X40 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Beast X40 boardview and Beast X40 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for MEDION...
            09-07-2024, 06:38 AM
            09-07-2024, 06:31 AM
