HP 205 G3 AIO 7 blink code
  • reb202
    • Mar 2021
    • 6
    • Italy
    I have this HP 205 which blinks 7 times. No video output, nothing. Motherboard is DAN91CMB6D0 Rev. D. I tried flashing a new firmware and nothing changed. Also I measured a couple of caps from the DC-DC converters, they are fine.
    Is there anything else I could try? I'm running out of ideas I couldn't even find what the 7 blink code means it only says "Replace main board" which obviously doesnt help, thanks HP.
    Thank you!
  • reb202
    • Mar 2021
    • 6
    • Italy
    Re: HP 205 G3 AIO 7 blink code
    After a process of elimination I came to the conclusion that the problem must be the CPU since I've checked the following things and they work:
    - Firmware, flashed a new one with no change
    - Memory, tested and works fine
    - DC-DC converters, measured them and voltages are ok
    - EC, seems to be fine since its the one who produces the blink patern and controls the DC-DC converters
    - Caps in DC-DC converters, measured them and they are fine
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      and changing the CPU, did that fix it?
      Follow me on YouTube
      Learn Electronics Repair
      • reb202
        • Mar 2021
        • 6
        • Italy
        I can't change the CPU because I don't own a reballing station.
        • dokterpc
          • Aug 2020
          • 47
          • Indonesia
          i have some trouble, correctly your bios is works fine, then remove cmos, and change jumper pin 4-6 to 3-4, plugin your adaptor and power on, remove adaptor and return the jumper pin to 4-6 then plug cmoc battery and done.
          • Prabuth
            Technician
            • Sep 2018
            • 78
            • Sri Lanka
            i do. but not ok.
            • mandum
              • Aug 2020
              • 8
              • Indonesia
              i got the same failure, any solution?
              • Andersson95
                • Apr 2023
                • 8
                • Colombia
                Hi, it may be a screen error, if possible try with another screen.
                On some devices, if you disconnect the backlight connector, the device will immediately give you the error code 7 times when connecting the charger. If you reconnect it, it does not do so immediately, only after pressing the power button.
                That may give you an idea of the problem.
                This connector sends a signal to ground that has the EC or KBC as communication.
                • cloo
                  Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                  by cloo
                  I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                  It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                  So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                  After doing a factory reset this problem was gone and the picture was back to...
                  01-06-2025, 06:02 AM
                • rmacintosh
                  Panasonic Plasma repair - TH-P60GT50 - Dead, 3 blink code
                  by rmacintosh
                  I aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
                  The symptoms of the tv ar as follows:
                  • Plug AC in to back of TV
                  • After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
                  • The 3 blink code is given by the power LED
                  • If the TV is unplugged and then
                  03-14-2020, 12:24 AM
                  LCD LED TV Service Menu Codes
                  TCL LED TV Service Menu Code
                  LG LED TV Service Menu Code
                  10-31-2024, 03:58 AM
                • reporter1979
                  2 red blink code on old led tv Sony KDL-40W2000
                  by reporter1979
                  Hi all, the TV KDL-40W2000 was flashed by a lightning.
                  Firstly I got the 3 red blink code.
                  Following other threads I changed the power supply board and got always 3 blinks.
                  So I changed also the mainboard and now I get 2 blinks error code. Tried also with the other ps board, still getting 2 blinks.
                  The TV turns on for a minute or two with green led and blank screen, if I press buttons the green led blinks fast. It turns to 2 red blinking led after a while.
                  What else can I do?...
                  02-17-2023, 11:50 AM
                • Curtissimo
                  HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
                  by Curtissimo
                  Hi everyone.
                  I have a HP Elitebook 850 G8.
                  Serial: 5CG2324XM0
                  ProdID 6L8D5EC#ABA
                  It has a Winbond W25Q256JVEN Chip.
                  I need to remove BIOS Password.
                  I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
                  Attached my dump.
                  I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
                  I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
                  What I did:...
                  08-26-2025, 04:42 AM
