Asus Z87 Expert - No Power, LDO Regulator Gets Hot!
  • suzukiyota
    • Feb 2021
    • 6
    • Japan
    Due to a power surge my Asus board does not power on, when I connect 24 pin power connector to motherboard (without turning on the board), the LDO regulator (UZ2085G / PU300) gets hot immediately. Hot I mean insanely hot! which burns my finger.
    I replaced the LDO regulator, but it didn't help. Probably something is using high ampere and causing the regulator become hot.
    So which components should I check? What's the best way to diagnose the issue?
  • peste
    • 13421
    • ROMANIA
    Re: Asus Z87 Expert - No Power, LDO Regulator Gets Hot!
    you probably have a short piece on the ground at the output of the regulator ...
    • suzukiyota
      • Feb 2021
      • 6
      • Japan
      I found one resistor, one pin goes to regulator output and the other goes to +3VSB ATX.
      Boardview shows it should have 1.15K OHM. But multimeter reads 1.13K OHM. Is that a problem?
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        Nahh that's close enough. As Peste already advised you - check for a short circuit to ground form the output of the LDO.
        Follow me on YouTube
        Learn Electronics Repair
          master hoarder
          • May 2008
          • 12175
          Was the computer connected to Ethernet when the surge occurred? If yes, I would suspect the LAN IC, as that's usually the one that gets toast from surges and lightning storms (and it also is the one that usually uses 3.3VSTB generated from the motherboard.)
          Of course, do check if any other IC is getting hot before removing anything - that is, check the SuperIO/LPC, LAN IC, Audio IC, and any Firewire or extra SATA RAID controller IC.
          • suzukiyota
            • Feb 2021
            • 6
            • Japan
            I can see the whole 3VSB rail is short to ground. No, Ethernet was not connected when surge occurred. I checked LAN and audio chips, only 3VSB pin is short to ground. I guess the chip is ok?
            How do I find which component is short? Should I use external 3V to burn the component?
            • dicky96
              Sun Seeker
              • Mar 2017
              • 1825
              • Spain
              Most common method would be to use a bench power supply to power the 3VSB.
              You want a constant current power supply. Set the output to 3V, then short the leads of the power supply together and set the current for about 1 amp. Now connect it to 3VSB and wait a minute to see if anything gets warm. Don't worry if the PSU goes down to a very low voltage (like less that 0.5V)
              If nothing is getting warm, increase the current limit (not the voltage ) on the bench PSU to about 2 amps and try again
              Keep on increasing the current half an amp at a time until either something gets hot or you reach the maximum rating of your PSU.
              If this method doesn't help (nothing seems to get hot) then we have to try another way - but for that we are going to need the boardview. I have attached it here. Are you familiar with using boardviewer?
              • suzukiyota
                • Feb 2021
                • 6
                • Japan
                Voltage injection makes PCH warm. So the PCH is shorted then.
                • dicky96
                  Sun Seeker
                  • Mar 2017
                  • 1825
                  • Spain
                  Maybe, maybe not. PCH generally get warm anyway.
                  When you injected the 3VSB voltage, did you use a bench PSU? What voltage and current could you see was supplied by the PSU?
                  Do you have a good multimeter? You need something that can read 4.5 digits or better resolution, so it can read 0.01 ohms on the lowest resistance range. I have a Uni-T at the workshop I use for this sort of purpose, I can't remember which one, but it wasn't expensive. I'll check in the morning.
                  Take the heatsink off the PCH, turn the power off, remove the CMOS battery and check the resistance across all the little capacitors integrated on to the top of the BGA. One or more of these should be 3VSB. Do you see a short there? If so read the resistance, then read the resistance at other points on the 3VSB rail. If you see the lowest resistance at the PCH then either it, or a MLCC capacitor very close to it, are likely to be short.
                  If you can't see the difference with resistance range on your multimeter, then re-apply voltage from your bench PSU and try this other way.
                  Set your multimeter to voltage, again you need a decent multimeter. Now open the board view I posted and find a 3VSB LDO that gets hot. Now on the boardview click on the LDO 3VSB pin and it will go red.
                  Highlighted in yellow you will now see all the other points on the motherboard that are connected directly to 3VSB.
                  Now measure the voltage from 3VSB on the LDO that gets hot to a ground pin on the same LDO. I would assume this is where you are injecting voltage from your bench PSU. Make a note of the reading.
                  Now work your way around the board using the board view. For each component measure the voltage from 3VSB pin to ground pin on the same component. If the component does not have a ground pin, then obviously it can not short to ground, so skip that component, it isn't the problem.
                  Take your time and work methodically around the board. Whichever component reads the lowest voltage from 3VSB pin to ground pin on the same component, is the short circuit one.
                  • piernov
                    • Jan 2016
                    • 4437
                    • France
                    PCH die should not get warm when injecting on a 3.3V rail. No point in wasting time.
                    • dicky96
                      Sun Seeker
                      • Mar 2017
                      • 1825
                      • Spain
                      Then I stand corrected
                      • dicky96
                        Sun Seeker
                        • Mar 2017
                        • 1825
                        • Spain
                        Yes for sure you are correct Piernov
                        I didn't think it through properly, if the 3.3V rail is the standby, then it isn't going to draw very much current under normal conditions so the PCH should not get warm by powering that rail
                        • suzukiyota
                          • Feb 2021
                          • 6
                          • Japan
                          When I inject 3V to the board, it is taking 4.7 amps from power supply. And power supply voltage drops to 2.3 volt.
                          The multimeter currently I have cannot read fine resolution. It can read 0.1 ohm.
                          I’m not injecting voltage to the LDO, because LDO is not in 3VSB power rail, and there’s no ground pin on LDO. From LDO 3VSB_ATX (3VSB_ATX is not shorted to ground, only 3VSB is) goes to MOSFET (PQ301 on board view) and that MOSFET is connected to 3VSB power rail, so I’m injecting voltage to 3VSB pin on the MOSFET.
                          So I guess my only option is to check voltage from each component. To detect the voltage difference, do I need a fine resolution multimeter?
                          • dicky96
                            Sun Seeker
                            • Mar 2017
                            • 1825
                            • Spain
                            The more sensitive/higher resolution your meter the better, but using the voltage drop method this is less important- because with this method ohms law is working in your favour
                            Take the example of a cheap multimeter such as the AN870
                            https://www.aliexpress.com/item/1005...archweb201603_
                            The lowest resistance range is 199.99R and it can resolve to 0.01R
                            The lowest voltage range is 19.999mV and it can resolve to 00.001mV
                            On your PCB
                            The ‘short circuit’ resistance is 2.3V & 4.7A = 0.49R
                            Ohms per volt = 0.49R / 2.3V = 0.21R and meter reads to 0.01R
                            Resolution is 0.49R / 0.01R = 49
                            Voltage range can read to 0.000001V (00.001mV)
                            Resistance is 0.49R
                            ‘short circuit’ Volts per ohm is 2.3V / 0.49R = 4.694 V
                            Resolution is 2.3V x 0.000001V = 2,300,000
                            So using the voltage drop method, your meter has about 50,000 times the resolution than it would have in the resistance method
                            Also three other factors are in your favour:
                            1. The more current you can get into the short circuit, the higher the voltage drop, therefore the higher resolution of your meter
                            2. Because your multimeter is drawing no current (or as near as damn it) the resistance of your meter probes is not relevant, and you don't need four wire probes as you would with a milli-ohm or better resistance meter
                            3. The only current path on which you will see decreasing voltages is the path towards the short circuit, circuit traces branching away from that path will show no voltage drop as there is no current passing through them. Using this knowledge it, you can often trace which direction the current is flowing by measuring the voltage at different points on a circuit trace. You can't easily detect the same using resistance mode as almost no current is flowing from your meter.
                            • GLISIT
                              by GLISIT
                              01-16-2025, 02:29 PM
                            • Tynan Dill
                              by Tynan Dill
                              Assuming...
                              11-22-2024, 01:46 PM
                            • PantherDave
                              by PantherDave
                              Hi all!
                              05-29-2024, 02:01 PM
                            • ShadowAi
                              ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                              by ShadowAi
                              Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                              Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                              After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                              03-15-2024, 10:46 AM
                            • meraklinetx
                              Asus Z97-a power cycle, no boot no cpu voltage
                              by meraklinetx
                              Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                              05-10-2023, 06:08 AM
