Pentium III FC board with OST I.Q caps. Not having stability problems yet, but four of them behind the CPU area (3300uF 6.3V) are bulging out the top. Fortunately I have a new spare MB, just need to swap out boards and see if I can find replacements to try the repair. Heat is probably a consideration here as it stays on in an office where the A/C is turned off over the weekend...
BioStar M6VLQ
Re: BioStar M6VLQ
Wondering when somebody would post about Biostar board... Theystill use OST RL* caps. As for replacements, try http://niccomp.com
by selectivetaoHello fellows,
I am putting a feeler out for a schematic (or ideally boardview) for the Biostar B660-T Silver motherboard.
I had let my guard down and decided to trust the Biostar supplied Windows based BIOS flash tool, only to find that the system would not POST upon restart.
no problem I thought - I would just flash using my trusty CH341 and be on my merry way.
Upon inspecting the board and locating its Winbond NOR, I found it in a rather precarious spot nestled between the RAM slots and PCIe slot and right next to a rather meltable-looking...-
12-13-2024, 09:37 PM -
Biostar GeForce 6100 AM2 (CRU51-M2) Schematic
Biostar GeForce 6100 AM2 Ver. 1.x is a motherboard based on the Nvidia nForce 410 (GeForce 6100) chipset....-
Channel: Schematics and Boardviews
10-31-2024, 02:29 PM -
by slybundataken from my thread about car alarm siren here: https://www.badcaps.net/forum/troubl...rm-siren-issue
there are 2 caps which im looking to get replacements for.
Branded as Gemcon
single 100uf 16v 6.5mm x 11.5mm
single 100uf 50v 8mm x 11.5mm
lead spacing is around 3mm
there is space for 16mm tall caps
rs components is good place for me to go since its close by, what replacements do you suggest and do these need to be low esr?
the caps have...-
by aatech1Hello,
I’m looking for the boardview file for the Biostar A320MH Ver. 6.7 motherboard.
Preferred format: OpenBoardView-compatible (.fz, .cad, or .brd).
I already saw that some revisions (like Ver. 6.0) are around, but I specifically need Ver. 6.7 if possible.
Thanks in advance to anyone who can share or guide me to it!-
08-31-2025, 06:26 AM -
by valente222Hello friends, I just received this equipment, it has a strange hum on the board. The computer works fine, outputs an image and starts Windows. But the problem is when charging the battery, a constant loop to charge. In short, it never charges the battery. When the charger is connected, the stability of the CPU is stressed and it seems that the coils make that electrical sound louder. This board is modern and I don't have a schematic. I have checked with a microscope and the pcb is completely new. Has anyone had this happen to them before? defect in driver ic?...
- Loading...
