Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
MSI MS-6309 N1996, need to replace 2 caps
  • Bassquake
    • Aug 2009
    • 19
    Heres a pic of the two green ones, they say Chhsi WG(M) 1500uf 10V.
    Theres no performance changes, but I worry theyre gonna pop all over the graphics card!
    Anyone recommend what to replace them with? Im from the UK and cant seem to see Maplin having any on their site.
  • yanz
    • Nov 2004
    • 910
    Re: MSI MS-6309 N1996, need to replace 2 caps
    you should recap it. the sooner, the better, while all is still ok. panasonic FM/FJ, chemicon KZE, rubycon MBZ/MCZ, is what i would recommend. but it depends on what available to you..
    • Bassquake
      • Aug 2009
      • 19
      Yeh I think I will.
      Ive found Samwha makes of those caps on ebay. Will that be ok?
      • yanz
        • Nov 2004
        • 910
        We only recommend japanese caps, or at least samxon caps, for recapping. I think if you try harder, you can find some from respectable online seller.
        https://www.badcaps.net/forum/showthread.php?t=2280 (Where can I buy replacement capacitors?)
        https://www.badcaps.net/forum/showthread.php?t=588 (The Good Capacitors Photo Thread)
        (I get all my caps locally, so i cant recommend you where you can buy them online.)
        • Bassquake
          • Aug 2009
          • 19
          Jus ordered some Rubicon ones off ebay. Gonna take a week to get here seeing as its coming from Hong Kong.
          Will update when alls (hopefully) gone to plan!
          • ant3202
            • Jun 2006
            • 275
            • Singapore
            glad you did not choose samwha caps
            • Bassquake
              • Aug 2009
              • 19
              Took about 3 weeks to get to me, but they finally came and Ive replaced them and all seems ok (fingers crossed)! Thanks for all the help. Cheers.
              Heres the finished job:
                by momaka
                03-12-2025, 03:42 PM
              • Paxman_Swede
                by Paxman_Swede
                Hello!
                01-14-2025, 09:51 AM
              • edith
                Caps and how to find one to replace
                by edith
                Hello everyone I have a question. I have a laptop and his schematic. Can anyone tell me how to measure or any way to understand specific of caps so i can buy new one?
                Also in case how can I understand if some caps of some dead Mobo i have, are ok to be replaced in my new motherboard which im trying to fix?
                Thank you!
                06-11-2023, 05:00 PM
              • madscientist750
                Replacing electrolytic caps by solid caps on old motherboards
                by madscientist750
                I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                10-19-2025, 06:10 AM
              • Mattz_GT
                Which caps to replace: ECS P4M800Pro-M V1.0A
                by Mattz_GT
                It's feeling like this board has a case of badcaps, instability and reboots - and not wanting to necro a a very old thread, it seems the 680uF 4V are highly suspect.
                I don't really want to blanket recap everything, but maybe the others around that area could do with being changed?
                Equipment: I have a temperature controlled soldering station, read the bit where it says set to 400F, don't think I would have gone that high without reading that.
                Spring plunger solder sucker, and some desolder braid... and a bit of good old leaded 60/40.
                PS. Additional diagnostic,...
                01-22-2025, 12:12 PM
