I got two of these for my bro's family
They work ok excepting they are stock specified with;
1. 2 of PC2700 256MB dual channel
2. 1 of PIV 2.8GHz non-HT CPU
I need the lowdown on what is possible with these PCs in terms
of an easy upgrade. The Dell support site is useless any
only states, CPU up 3.2GHz with HT support (no steppings) as
well as FSB 800MHz (can run PC3200 in dual channel)
I believe the mobo is Intel 865GV (with graphics port)
These won't be used for games.
So...
I got an updated BIOS from the Dell website as well as drivers but don't
know how to decompress the image and read with Pheonix BIOS editor
to check for cpu codes as well as to update cpu codes as required.
Also, if I opt for a CPU upgrade I suspect a new HSF will be in order.
Next, PSU. These are Dell 250W and I believe are proprietary.
Can a member confirm this to be the case?
Could I took a 400W PSU, recap and mod it to run with this system?
In terms of a recap, are these suspect to bad caps?
Thanks in advance for any/all info supplied.
So...
