Jet Way with bad caps.
  • Doramius
    • Nov 2007
    • 25
    Well, if I didn't learn my lesson the first time.....
    This isn't quite in response to my first thread, as this is a completely different motherboard......kind of.
    I had a previous issue with a Machspeed board with the thread here: https://www.badcaps.net/forum/showth...ight=machspeed
    I got the same model motherboard from Jet Way. So I have 2 PCs running this model motherboard, although the "brand name" is different. however, the issues I'm having are also completely the same. I'm going to push more on getting this board replaced by the manufacturer, but if they don't, you can count on me adding quite a bit more to this thread. I will add pictures as soon as I can, though. I just haven't had a chance to take them. Maybe tomorrow.
  • Doramius
    • Nov 2007
    • 25
    Re: Jet Way with bad caps.
    Sorry for the delay in getting the pics.
    Here are the boards side by side.
    Can you tell the difference? Other than color, the ONLY difference is the BIOS. The stock BIOS for the MS, came with v5, while the JW came with v6.1. However, I updated the flash on the MS to 6.1, meaning they are still the same board. The MS was boasting OC capabilities, yet the JW had the exact same capability. Just a rebrand of the same board.
    Anyway, here are the bad Caps on the JW board.
    If you checked out my MS thread, you'll notice they are the exact same position of caps to blow. An old bowling instructor of mine, years ago, said if you throw the ball in the same place twice, you won't score anything the second time around."
    I got the RMA, but they are charging me $10 for return postage. Some 1 year warranty. Many other companies I've used ship it back without charge, as part of the warranty service.
    We'll see how this goes, and what it looks like when it's returned.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Those are Sacon FZ.
      Usually seen on video cards.
      The are total crap.
      Mann-Made Global Warming.
      - Dr Seuss
      • linuxguru
        • Apr 2005
        • 1564
        These are the Nichicon HD knockoffs in appearance only - nowhere close in quality.
        • Doramius
          • Nov 2007
          • 25
          They are pretty crappy capacitors. They are the only ones that seem to fail on these boards.
          Through personal use, I've found that the board is quite stable.....EXCEPT...once these capacitors blow. It's a shame, these really are good boards. That's what you get when you try to cut costs.
            master hoarder
            • May 2008
            • 12175
            It's not worth returning it becuase they will probably send you a board with the same crap caps. And chances are (like 100%) that even the new motherboard will fail. So just recap it instead and be done with it. Make sure to replace every FZ cap, though (maybe except for the really small ones).
            • Doramius
              • Nov 2007
              • 25
              That's part of the whole reason why I am returning this board. I want to see what they'll actually do. Your prediction is about the same as mine. If it is, I'll be sure to post about it. I'm really not happy with the company for the customer service and the quality of materials. I'm hoping to at least get more info on their practices and allow people to realize they are just a crappy company overall and to just avoid their products.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Email them a link to the thread.
                You'll probably get all Rubycons.
                - Dr Seuss
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  idk
                  i had a jetway covered in evercon- not a single good cap
                  total crap!
                  sigpic
                  (Insert witty quote here)
                    by momaka
                    03-12-2025, 03:42 PM
                  • eryjus
                    by eryjus
                    05-10-2023, 11:21 AM
                  • Paxman_Swede
                    by Paxman_Swede
                    Hello!
                    01-14-2025, 09:51 AM
                  • captain150
                    by captain150
                    03-16-2025, 07:34 PM
                  • Foetuss
                    Gigabyte GA-6OXT :: caps question
                    by Foetuss
                    Good evening
                    I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                    Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                    But I was also suprised about the bigger boys, which are 330µF 25V.
                    Could it be they used 25V caps because they were cheaper / available at that time?...
                    02-11-2025, 12:22 PM
