Dell Motherboard replaced caps still no boot
  • mikephilly
    • Nov 2008
    I replaced a few Dell optiplex motherboards and I was able to fix most of them however I have 2 that still don't work. I replaced all the recommended capacitors on both boards. I triple checked my work and there are no obvious problems.
    Board 1. is displaying a green light on the power button but I get no video. i tried resetting the cmos, adding an 2nd agp video card in the machine, swapping the processor, memory... if I put a good board in this same PC it boots with no problem.
    Board 2. is displaying a solid yellow light on the power button and wont boot. i tried resetting the cmos, swapping the processor, memory... if I put a good board in this same PC it boots with no problem.
    Any ideas of other things I can look for?
  • Fiber
    • Nov 2008
    Re: Dell Motherboard replaced caps still no boot
    If the soldering is right, cap position, then they might have just died of the bad caps, bad caps can destroy other components. Look for other components on the board that could have been fried.
    • gdement
      • Jan 2007
      • 690
      If you don't know the history, then this could be a bad flashed BIOS.
      • Fizzycapola
        • Oct 2006
        • 423
        If the special graphics port is dead, as happens sometimes, you won't see a display.
        Rubycon Rubycon Rubycon
        • Fizzycapola
          • Oct 2006
          • 423
          have u tried a pci graphics card?
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            maybe one of the small caps is fried
            sigpic
            (Insert witty quote here)
            • mikephilly
              • Nov 2008
              I did try the PCI graphics card and it did not work. Is there any way to resolve the graphics port problem or a bad flashed bios? What is the quickest way to determine which small cap is fried? Are there any typical ones in certain areas? There are so many and none look raised.
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                look for ones around the northbridge (larger chipset, might have a heatsink on it). get out a multimeter and see. another possibility could be a bad cap that you already replaced damaged another part on the board (MOSFETs, chipsets, etc.)
                i know a small cap will do that to a board (I had an abit k7-RAID that a friend gave me that had only one bad cap and it was a tiny one (<1000 uf))
                Hope this helps
                Larry the teenage computer surgeon
                sigpic
                • mikephilly
                  • Nov 2008
                  I am still unable to get these boards going and now i have another one to add. Its a GX280 with a racing fan and I have replaced all the caps. Has anyone run into the GX280 racing fan issue?
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Electrolytic caps have no oil so I think 'fried' is the wrong word.
                    'Boiled' is probably more correct for electrolytics with 'fried' being reserved for use with PIO (paper in oil) caps.
                    I am of course just being silly.
                    Mann-Made Global Warming.
                    - Dr Seuss
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      mikephilly
                      If you have identical boards with removable BIOS chips you can 'borrow' the chip from a working board to test a board with a questionable BIOS.
                      Take ALL anti-static precautions when doing that or you may end up with two dead boards.
                      - Dr Seuss
                      • seanc
                        • Nov 2008
                        • 1319
                        I have one of these - no idea what it's problem is. Nice machine but it had to be taken out of service due to sounding like a jet engine 24x7.
                        • lightingguy32
                          • Feb 2008
                          • 14
                          Board #2 has a bad PSU, this is a common issue with the Early GX280, and early GX620s, I just did my summer triage of all machines in a lab that are GX620s, and more then half have had PSUs replaced, this year we are replacing one more.
                          • midibob
                            • Nov 2008
                            • 285
                            When you say you've replaced 'all' the caps do you actually mean all?
                            I've mentioned this before in other threads but I've seen non booting issues caused by the 220uF tiddlers drying up and going open circuit (in 620's anyway). Always worth checking.
                            Midibob
                            • Computer-Tech
                              • Aug 2009
                              • 6
                              Mike,
                              When you reCapped the Dell Optiplex - did you nick the video trace that is around the pad of cpacitor C259? The trace is a hair like trace (one of the squiggly traces) that comes really close to the pad...
                              When I get a motherboard that does not display video on preliminary BIOS Boot (I always pre boot the motherboard before working on it - it also tells me if it is an easy fix, or more detailed) - I always pop in a new 1500 uF 6.3V Cap in this location. 90% of the time the video comes up and I proceed to analyze the motherboard. Then I recap and again re-test.
                              When I get a motherboard in that has been recapped and has no video - I immediately fire up the surgical microscope and most of the time find a broken trace.
                              Incidentally, I know the surgical microscope is over-kill (and if you can find one for $700, like I did - I recommend you buy it) it really beats the illuminated 7 diopter maginifier. Hairs look like 2x4's - so I find any and all hairline trace fractures and trace problems really fast.
                              My only problem is the soldering tips. I have two that are filed down to needle sharpness (but they still look like #2 pencils under the microscope), oh well ya can't have everything.
                              Looking at supposedly good solder joints that look like lunar craters takes a little getting used to.
                              I do over 100 motherboards a week, so I need all the help I can get. Not spending a lot of time chasing down broken traces is an invaluable time saver
                              Incidentally, the Green light, means that the board is passing Power On checks - but the video is not part of the power on test. The fact that you cannot get an AGP card to work also seems to confirm the nicked trace diagnosis.
                              The 2nd Computer:
                              Are you getting a single Amber Lamp? Which (lamp #1 is the one that has a green/amber LED, Lamp #2 is the one that just has an amber LED - the one on the left is Lamp #2).
                              Patiently awaiting your repoly..
                              Dave Mason
                              Computer-Tech@phoenixcomputerlabs.com
                              • joesmoe91
                                Dell Precision 5530 15" died to blown chip. Replaced chip and now only get momentary fans, lights, no screen or boot
                                by joesmoe91
                                My Dell Precision 5530 turned off suddenly when I was running Matlab and wouldn't turn on, show any lights, fans, and/or any signs of activity at all. I opened the case, removed the battery and looked at the board with a thermal camera while the AC adapter was connected. I saw that PU1252 was >120C so figured the chip had died on me Got the part number off the attached schematic (see Mouser link below) and replaced the chip. After replacing the chip the board (connected to AC adapter) was able to briefly power on, spin the fans a little bit, and turn on the front led lights....
                                02-22-2024, 07:38 PM
                              • Geeker007
                                9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
                                by Geeker007
                                Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
                                I am new to electronics repair, so my queries could be naive but I am ready to learn.
                                So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
                                01-28-2025, 03:31 PM
                              • Julian Bailey
                                Dell Latitude 5350 Ultra 7 Motherboard
                                by Julian Bailey
                                Hi
                                I have a Dell Latitude 5350 Ultra 7 Motherboard I am trying to repair that has a blown chip.
                                The chip is marked as eHOLH similar to the one I have pictured.
                                Any ideas what it does and what the pin outs are as 3 tracks have gone and need to find out what / where they went / did etc.
                                Dell PN of the motherboard is 08DCGW.
                                Below is the area I am trying to repair:
                                Does anyone have a picture of this motherboard in this area they could take and upload?
                                Cheers...
                                07-03-2025, 11:25 PM
                              • Bonaventure Vigil
                                Variable DC Power Supply cannot boot motherboard
                                by Bonaventure Vigil
                                Hi there,
                                Guys anyone here can help me. During troubleshoot the motherboard, my 1st and new psu unable to boot the motherboard. Even though i set the 20V, my old Compaq CQ42 motherboard had the led white light at charging port. When press on button, the led blinking to red and gone back to white state. But i change the oem hp compaq adapter which is i measure 19.45V. Using that can boot the motherboard and fan spinning. Then i reconnect psu and tried set the 19.45V, still blinking red. Anyone know what happen? Is it psu not compatible? All is check and voltage is there....
                                10-17-2024, 12:16 AM
                              • Bowline
                                by Bowline
                                06-11-2025, 10:13 AM
