MS-6728 v1.0 865PE-NEO2-LS
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    Want to use this as a media centre.
    This was power up over a year ago and appeared ok.
    At that time, I updated the BIOS.
    Got round to testing it again just recently.
    The mobo is dead - will not POST. Rather, it posted only once
    and has done nothing else other than power up, do a CPU
    reset and then nothing. The mobo will do a reset as my
    PCI diag. card indicates this is the case. Also, all of the
    voltages on the Diag. card report ok.
    Measured the ESR of the caps
    BOM below;
    3 of Violet 1500 uF 16.0 V Rubycon MBZ 105 deg C - H 20.0 mm x Dia 10 mm +12V rail I/P VRM
    1 of Violet 1500 uF 16.0 V Rubycon MBZ 105 deg C - H 20.0 mm x Dia 10 mm +12V RS232
    8 of Black 1500 uF 6.3 V Panasonic FJ 105 deg C - H 20.0 mm x Dia 7.5 mm +3.3V O/P VRM
    10 of Black 1000 uF 6.3 V Panasonic FJZ 105 deg C - H 18.0 mm x Dia 7.5 mm +3.3V
    4 of Green 470 uF 10.0 V UCC KZE 105 deg C - H 13.0 mm x Dia 7.5 mm +5.0V
    2 of Brown 1000 uF 10.0 V UCC KZG 105 deg C - H 15.0 mm x Dia 8.0 mm +5.0V
    4 of Brown 470 uF 6.3 V UCC KMG 105 deg C - H 10.0 mm x Dia 5.0 mm +3.3V
    2 of Black 100 uF 6.3 V G-Luxon 105 deg C - H 10.0 mm x Dia 3.0 mm +3.3V
    All appear ok but;
    All of the FJ all read ESR of 0 but appear to charge up ok i.e. will go beep and
    go o/c if I apply the leads of my MMeter on continuity.
    However, one of the KMG and one of the G-Luxon which are close to
    the n/bridge HSF have highish ESR of 0.65 and 0.32 respectively.
    This may account for heat as the others, only reads between 0.02 - 0.08
    and 0.01 respectively.
    Further, one of the KMG and one of the FJZ will not charge, they remain
    s/c. I believe these may require replacement as being the above are
    bullk capacitance lytics for the rails, they must have a load to power.
    Also, the FJZ cap reads 0 ESR, the KMG 0.03.
    Q - I have tried to get a datasheet on the FJZ in a separate post.
    In the first instance, I want to replace all of the FJZ on the board
    as well as the KMGs and the G-Luxons
    Would this be the correct action to follow?
    Thanks in adv. for any constructive comments and criticism(s).
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: MS-6728 v1.0 865PE-NEO2-LS
    those are gone. why are you worrying about datasheet? just replace with the lowest esr caps you can find.
    • JEWilson
      • Sep 2007
      • 369
      Will,
      Thanks.
      Just wanted to test the water (sorry... couldn't resist ouch! done it again)
      Have just looked at the other post with the hull tester. Only kidding.
      Yep - I have a bunch of FMs - 6.3V 1000uF - there a little fatter round
      the waist but will do for the FJZ. They will do from a pre-emptive point of view.
      As a matter of course, will replace the faulty items as well.
      Have got FM 220uF 10V and FM 470uF 10V - they'll do.
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        well i looked for the datasheet but so little about these caps anyway, nothing from panasonic. i have a hunch these would be very low esr.
          HP EliteDesk 705 G3 EliteDesk 700 PRO 1500 Specification for Upgrade or Repair
          This specification for the HP EliteDesk 705 G3 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 705 G3 boardview and EliteDesk 705 G3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
          09-12-2024, 02:15 PM
          HP EliteDesk 705 G3 EliteDesk 705 PRO 1500 Specification for Upgrade or Repair
          09-12-2024, 02:00 PM
