Asus A7N8X Deluxe v2.0 (again)
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    Having reviewed prior posts as with;
    https://www.badcaps.net/forum/showthread.php?t=2876 and
    https://www.badcaps.net/forum/printthread.php?t=5017
    Is it not strange to have 6.3V caps on the VRM I/P?
    It was my belief there were no 3.3V CPU VRMs on mobos.
    Should it not be the case, these caps should be 10V 3300uF?
    It may be size constraints, e.g. 10mm diameter led to these
    being installed?
    What are the opinions of forum members?
    Thx
  • kikkoman
    • Jul 2007
    • 691
    Re: Asus A7N8X Deluxe v2.0 (again)
    you're right, there are no 3.3V VRMs (at least not in the ATX era) but 5V ones.
    The A7N8X was one of the last boards that used these, and about every post-Skt462 board used 12V.
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • i4004
      • Oct 2006
      • 2029
      why?
      what is the voltage on them?
      is it more than 6.3v?
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        they are on +5
        10v caps are only used to get slightly lower esr in a cheap part.
        • hkivan
          • Mar 2006
          • 122
          majority of mobo use 10V caps on the +5V VRM in
          That was very common for using +5V rail VRM in during Ante- P4 & K8 time.
          PSUs were also strong in +5V rail at that time.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            hkivan, your observation is correct.
            And kc8adu has the correct reason why.
            They don't use 10v for the voltage they use them for the lower ESR at the same uF.
            But ESR has more to do with can size than the rated voltage so sometimes their choices were silly.
            Mann-Made Global Warming.
            - Dr Seuss
            • JEWilson
              • Sep 2007
              • 369
              Recapped this today
              Was a bit of squeeze getting the 12.5mm dia Pana FMs in!
              Due care and attention required for the soldering.
              It's a bit tricky - like my experience with Jetway 830 CF v3.0
              https://www.badcaps.net/forum/showpo...30&postcount=2
              • i4004
                • Oct 2006
                • 2029
                could you post some pix of 12.5mm caps being put to 10mm placeholder?
                • JEWilson
                  • Sep 2007
                  • 369
                  Sorry...
                  Don't have a camera with sufficient quality (only a webcam).
                  Perhaps, instead use your imagination, it's not pretty!
                  But then it doesn't need to be - it's not a beauty contest.
                  • i4004
                    • Oct 2006
                    • 2029
                    every cap pointing to its own direction?
                    hehe...
                    • JEWilson
                      • Sep 2007
                      • 369
                      In actual fact, not quite as bad as that thx
                      If you refer to the pics in the former posts re - this mobo
                      The I/P side of the VRM has cap nearest to audio connector raised
                      above theTaigMag HA-003 transformer package for the LAN
                      and bound to its neighbour cap.
                      Upon reflection it might be better to dog leg this back toward
                      the AGP connector - dunno.
                      Those other two will fit no problem at 12.5mm.
                      Similar issue with the O/P side of the VRM.
                      The cap nearest the parallel port has had to be angled toward
                      the connector at 65-75 degrees.
                      The other four caps will fit no problem at 12.5mm.
                      Again, other forum members may suggest a CapXon 330uF 10mm dia would
                      have been a better selection in those positions where it ain't so
                      pretty.
                      Not really that bothered to be honest
                      • i4004
                        • Oct 2006
                        • 2029
                        it's bigger issue when you have 2 rows of caps(better to say columns, when mobo stands up)
                        • JEWilson
                          • Sep 2007
                          • 369
                          Well...
                          To follow up so to speak.
                          After the recap, I powered up this mobo.
                          Much to my surprise a number of caps vented!
                          If I had double checked as I should have, I would have
                          noticed the postive terminal for a cap has a silk screen decal as
                          is used commonly for the negative terminal.
                          Net result. Replace all the caps on the mobo!
                          Valuable lesson learned.
                          Is this specific to Asus mobos?
                          Also the O/P VRM caps appear to be ok
                          I haven't tested these yet or in fact, taken them out.
                          Should I replace them?
                          Thanks for any advice
                          • Newbie2
                            • Sep 2005
                            • 885
                            Originally posted by JEWilson
                            Well...
                            Does your motherboard POST?
                            ASUS motherboards can be quite confusing at first. What we think of "negative is marked by white" is the opposite on ASUS motherboards. You must of seen a good capacitor-popping show with smelly smoke.
                            Look at how the original capacitors are oriented in polarity before replacing them.
                            My gaming PC:
                            AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                            ASUS M4A77TD AMD 770 AM3 Motherboard
                            PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                            G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                            TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                            WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                            ASUS Xonar DG 5.1 Channel PCI sound card
                            Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                            Antec Three Hundred Mid-Tower Case
                            Microsoft Windows 10 Pro 64-bit
                            Microsoft Windows 7 Ultimate SP1 64-bit
                            • JEWilson
                              • Sep 2007
                              • 369
                              Y
                              The mobo does POST (after the recap recap)
                              I am presently testing some memory in it.
                              Nothing appears to be damaged. Might have been lucky.
                              Thx
                                ASUS ZenBook UX490UA-77DHDAB1 Notebook 3 Deluxe Specification for Upgrade or Repair
                                This specification for the ASUS ZenBook UX490UA-77DHDAB1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX490UA-77DHDAB1 boardview and UX490UA-77DHDAB1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-06-2024, 09:37 AM
                                ASUS ZenBook UX490UA Notebook 3 Deluxe Specification for Upgrade or Repair
                                This specification for the ASUS ZenBook UX490UA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX490UA boardview and UX490UA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ASUS ZenBook...
                                09-06-2024, 08:29 AM
                                ASUS ZenBook UX490UA-IH74-BL Notebook 3 Deluxe Specification for Upgrade or Repair
                                This specification for the ASUS ZenBook UX490UA-IH74-BL Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX490UA-IH74-BL boardview and UX490UA-IH74-BL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                09-06-2024, 06:48 AM
                                09-06-2024, 06:30 AM
