Abit BP6
  • rs1n
    • Jan 2016
    • 12
    Abit BP6
    Does anyone still use this board? I resurrected mine not too long ago and replaced the 2x466MHz processors with 2x366MHz processors, overclocked to 550MHz (woohoo 100MHz front-side bus!). I only had to replace a single capacitor (which I did a long while ago) and the board seems to still be running stable (prime95 ran several days with no issues, and Quake 3 run in SMP mode with bots fighting themselves for several days nonstop without crashes). I am wondering if I need to replace the other caps (no bulge, no leaks, etc). I also read the bp6.com site, but their admin seems to be forever missing in action and the board seems almost dead. (It sucks that they require membership in order to download any files, too).
    Just curious if anyone else here recently resurrected their Abit BP6 and had to do any modifications to get stability.
    Thanks,
    rs1n
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Abit BP6
    replace all caps.
    there is one that needs upgrade on some bp6 for stability issues.number escapes me right now.should be permanently burned in as i fixed so many of these LOL!
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      Re: Abit BP6
      IIRC its EC10. orignal value is 100uF, I stick a 470uF in its place. Wow did that bring back some memories, I havent seen a BP6 for probably close to a decade.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • rs1n
        • Jan 2016
        • 12
        Re: Abit BP6
        Yeah, I replaced EC10 with a Rubycon 470uF 16V. The system had been running quite stable (Prime95 went for a whole week without crashing) and I left Quake 3 running with a bunch of bots for several days and also no crash. So, I wrote "had been running" because the PSU just went out. I found a bulged cap; might be worthwhile to repair the PSU since the ones with -5V rails are hard to come by these days (not that I have any ISA cards anymore). At the same time, one of my 256MB sticks of ECC RAM (used in non-ECC mode) apparently died, too.
        So now I'm down to 640MB RAM (replaced with a 128MB stick) and a PSU that has no -5V rail. Nevertheless, after more memtest86, prime95, and quake3 testing, the system seems to be running fine again.
        • rs1n
          • Jan 2016
          • 12
          Re: Abit BP6
          Oh yeah, now I remember why I registered! :-) How do I know that the Rubycon cap I bought is not a fake? Is there some easy way to tell? I can post a pic if need be.
          • ChaosLegionnaire
            HC Overclocker
            • Jul 2012
            • 3266
            • Singapore
            Re: Abit BP6
            yea post a pic of the font on both sides of the cap, i.e. the capacitance and voltage rating and the date code. also post a pic of the top (vent) of the cap as well as the bottom (the bung). most of the time, the wrong bung is a dead giveaway of a fake... so we need at least 4 pics in total.
            and nice to see u fixed up some good ol' stuff and brought it back from the ashes. to paraphrase a quote by master yoda,"seeing a bp6 alive, brings warm feelings to my heart!"
            • rs1n
              • Jan 2016
              • 12
              Re: Abit BP6
              Here is a small gallery of the caps: http://postimg.org/gallery/lzfnim44/
              Not that price is any accurate gauge (since anyone can charge higher prices for name brand caps), but I did pay $2.50 for four of them.
              This was the first PC I built myself, so I have a strong attachment to this motherboard. :-)
                master hoarder
                • May 2008
                • 12175
                Re: Abit BP6
                Pics would be useful, but also tell us where you got it. eBay is full of counterfeits. Some small local stores could be as well, if they sourced their caps from eBay or some other equally shady place.
                *edit*
                Those Rubycon caps are rated for 85C only (i.e. general purpose) - they have no business doing anything on a motherboard. Perhaps only good for testing a motherboard that has totally blown caps.
                • Foetuss
                  Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                  by Foetuss
                  Hi all
                  Hope this is in the correct place.
                  I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                  Could use some double checking to see if I'm not doing something stupid .
                  Pictures of the boards are attached.
                  What I will be replacing with what : (planned)
                  Soltek Golden ::
                  4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                  6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                  01-18-2025, 11:44 AM
                • ziplock
                  Abit BE6-II motherboard
                  by ziplock
                  Greetings,
                  I have an Abit BE6-II motherboard that posts sporadically with the bare minimum components installed - CPU, RAM, PSU, and a Keyboard. I know it posts when the speaker beeps. Re-seating the components has no effect.
                  I thought the sporadic posting might be capacitor related. Upon inspection, non of the caps are bulged or leaking and they are all original. So, I pulled them ALL. While the ESR is OK, over half of them are leaking current between 1 and 2 mA. The biggest offenders are way out of spec, like a 1500uf / 6.3V measuring 2600uF and many of the 820uF caps...
                  04-20-2025, 02:09 PM
                • valente222
                  LAPTOP HP 15-DY2059LA / i3-12gen has stability problems in vccpu coils, BUZZING SOUND. ¿Coil whine?
                  by valente222
                  Hello friends, I just received this equipment, it has a strange hum on the board. The computer works fine, outputs an image and starts Windows. But the problem is when charging the battery, a constant loop to charge. In short, it never charges the battery. When the charger is connected, the stability of the CPU is stressed and it seems that the coils make that electrical sound louder. This board is modern and I don't have a schematic. I have checked with a microscope and the pcb is completely new. Has anyone had this happen to them before? defect in driver ic?...
                  11-18-2024, 03:21 PM
                  ABit IP35 Pro Motherboard Schematic
                  ABit IP35 ProABit IP35 Pro Motherboard Schematic
                  A motherboard based on the Intel P35 Bearlake-P+ RAID chipset....
                  10-31-2024, 02:06 PM
                • tbalint3
                  Abit ST6-Raid repair
                  by tbalint3
                  Hello All,
                  I am trying to repair an old Abit ST6-R motherboard.
                  The symptoms are the following:
                  I got it in a non-working state. I was told that it sometimes turned on, but many times just the CPU fan was spinning and no other signs of life, the board didn't POST, and now it doesn't POST at all.
                  It was full of bulged electrolytic capacitors, so I replaced all of them with new Low-ESR ones, but it didn't solve the problem.
                  If I install a CPU in the S370 socket, only the fans are spinning and no POST. There are no beep codes even if the RAM DIMMs...
                  09-01-2024, 10:03 AM
