Dell Dimension 8300.... HN(M) again!
  • hardwareguy
    • Jun 2006
    • 405
    Got a Dell in the shop tonight, originally came in for spyware gut I noticed it's instability wasn't just a bad case of Vundo (a smitfraud variant).....
    It's the infamous skinny 820uF 6.3V HN(M) again....popped. There are four of these things and five yellow K vent Fujitsu polymer caps that are 4V, 560uF. I think I'll just add the rest of the polymers or something really similar.
    Looks like an i865P chipset.... It has dual channel DDR and an AGP slot. The GeForce FX 5200 had no bad caps.... all Sanyos.
  • bgavin
    • Jan 2007
    • 1355
    Re: Dell Dimension 8300.... HN(M) again!
    Yep. I have nothing but bad results with those HN populated boards. I replace them all as a matter of course. Every 'lytic from 470uF and up gets replaced.
    Vundo seems to be rampant at the moment. It is a nasty little bug to shed, plus the removal tool runs a LONG time.
    • Bookworm
      • Nov 2007
      • 123
      I do Vundo removals mostly by hand. That's often faster.
      • hardwareguy
        • Jun 2006
        • 405
        Recapped with some Nichicon 560uF polymers.... erratic behavior is fixed.
        Time to reformat this SOB.... it's got more issues than Vundo. Little bugs here and there that only a reformat can squash without wasting my time.
        • Wizard
          • Mar 2008
          • 2296
          Same here except I have this done with rubycon caps and solid wires last year. Here's this pic. Yes I own this 8300. I know this would be bit of a issue with the flying solid wires bec these six caps were fat. The solder connections were made with hooked together wires not lapped. 12.5mm instead of 10mm I needed badly.
          What do you think? Works well even you see this way as suboptimal, all I need is to get right caps then I can straighten this out later.
          http://www3.sympatico.ca/jpero/allpar_forum/dim8300.jpg
          Cheers, Wizard
          • gonzo0815
            • Feb 2006
            • 1600
            I don`t see a problem with your mounting technique. May be the capacitors pick up more heat from the mosfets, but probably the thick copper layer around them will conduct the same amount of heat or even more to the capacitor leads.
            • Wizard
              • Mar 2008
              • 2296
              Thanks, good to know. I am aware of this, there are air space under these caps so there is no issues with heat.
              By the way the heatsink is incorrect. This heatsink uses blower that blows the air straight back out thru the rear vent. I need to locate correct heatsink and shound on ebay.
              Cheers, Wizard
              • hardwareguy
                • Jun 2006
                • 405
                That should be just fine....that HUGE trace soaks up a LOT of heat. Yeah....you need the HS that is flipped 90 degrees..... there is a dual heatpipe variant, grab that one!
                The customer has not called back to complain.... and their neighbor reports that they are very pleased so that makes me happy.
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • TMTGTR
                  Need Advice On Which Caps To Buy For Dell Dimension 8300 Motherboard
                  by TMTGTR
                  The Symptom:
                  I own a Dell Dimension 8300 motherboard that will post and get to the black (XP pro 32bit) “We're Sorry Windows did not load” Screen.
                  When restarting any option i.e. “Normal” “Safe Mode” etc. Computer re-boots to same screen. I checked RAM with memtest –OK Checked O/S Drive with Victoria -OK
                  Upon Inspection:
                  I did a physical examination and see that the 6 caps by the CPU are all bulging in various degrees. (See Pics Below).
                  I found a YouTube vid with a guy who replaced these 6 caps and the computer works fine....
                  05-24-2022, 06:26 PM
                • kahlil88
                  Displaced tiny resistors on Dell Dimension 8300 board
                  by kahlil88
                  Had some difficulty removing the caps off my Dimension 8300 board. My cheap soldering iron just couldn't seem to melt the solder so I flipped over the board and used hot air. They all popped out fine but halfway thru wicking up the remaining solder, I noticed several tiny resistors near the CPU had been bumped out of place! ...
                  08-29-2022, 05:46 AM
                • SwedishDiesel
                  Dell Dimension PSU Compatibility - B110 PSU in 4550
                  by SwedishDiesel
                  Howdy folks,
                  I've risen from the grave to ask more questions about old obsolete Dells.
                  I've acquired a Dell Dimension 4550 which is in need of a PSU - I've several PSUs from Dell Dimension B110s, and I'm wondering if one of them could be used. The PSUs and the 4550 use a 20-pin connector and a 4-pin connector.
                  The issue is, I've been told that Dell really likes using proprietary hardware, and there were concerns about damage being caused by an incompatible supply. Because of this I'm assuming it's not just a simple plug-and-play and that there's more...
                  12-18-2022, 06:58 PM
                  HP Compaq Elite 8300 Compaq Elite 8300 i5-3470 Specification for Upgrade or Repair
                  This specification for the HP Compaq Elite 8300 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite 8300 boardview and Compaq Elite 8300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  09-12-2024, 03:28 PM
