Epox 8RGA+ Newbie's Greetings
  • ChaoZ
    • Oct 2007
    • 37
    Hi Guys
    You sure have one helluva website running here, with very knowledgable members.
    First of all, I would like to thank the authors of the various articles and posts which made my first recap experience successful -> unexpected joy for the electronic-noob.
    I was given a 4 years old EPOX 8RGA+ with NF2 Integrated Graphics. I tried fixing up everything on the board, giving active cooling to everything.
    I have no problem using regular Athlon 1800/2400+, but when I matched it up with a Barton. The increased voltage will incurred system hang-ups.
    Tried everything from software patches/bios settings/old drivers to additional cooling, nothing helped at all.
    I swore I saw no bad caps, till I kept reading about the particular row of capacitors, running parallel, above the processor socket.
    - 06 x Teapos 3300uf 6.3V
    (From right to left)
    One having a slight bloat
    4 had blown bottoms(geez... these ones got me)
    the last one on the left seems fine
    Went to search for replacements but end up with either '12.5mm 4700uf 16v FC' or the exact replacements using Teapo SD(Cyan Blue).
    Had a hard time, searching for them. Higher capacitance or out of size or dodgy brands. Took the Teapos finally(I know, not the best, but they fit), and went ahead with the replacements. LOL, had a hard time with my 18W iron + pliers + sharp-pin, till I went for the big guy -> HAMMER drill with a PCB drillbit.
    Botchy job but the board boots up
    Board is running good, no system hangups even with my fingers running around the caps(this is how i detect bad ones :p)
    Temperature actually went down by 5 degrees, I dont believe it either - perhaps due to the lesser power loss of the defective caps.
    Tried overclocking but still the same(due to limitation of NF2-GT chipset). No performance gain but 1000% stability gain.
    Thank you guys!
    Joshua
  • gonzo0815
    • Feb 2006
    • 1600
    Re: Epox 8RGA+ Newbie's Greetings
    Uhhhh drilling is a very hot topic here lucky you that the board is running fine again.
    Any way, regarding the caps, 3300uF 6.3v @10mm is widely available from any brand (e.g. Panasonic FC, FM, Samxon GD, GC, etc.)
    On the Epox there is no need in increasing capacitance, as they put enough on their boards.
    Any way, if it worked out for, it does not hurt.
    • severach
      • Aug 2007
      • 1055
      When you start testing bad caps with a cap meter you'll find there's no such thing as a slight bloat. You're lucky because there was at least something visible to help determine which caps were bad even if you didn't happen to know what too look for. I've seen capacitors with a slight slight slight bloat that are showing 10% of the printed value.
      Didn't anyone ever tell you not to take a knife to a gun fight. The big guy 140W Weller 8200 I use on the RoHS boards soldered with SAC305 outputs almost 10x the power.
      sig files are for morons
      • stretch0069
        Screwed Up Super Moderator
        • Oct 2003
        • 2658
        • oooo ess aaaaaaaaa
        mikee passes out........
        "Its all about the boom....."
        Guns kill people like spoons made Rosie O'Donnell fat.
        We now return you to your regularly scheduled drinking.
        "Fear accompanies the possibility of death.....calm shepherds its certainty"
        Originally posted by Topcat
        AWD is just training wheels for RWD.
        • linuxguru
          • Apr 2005
          • 1564
          The hotter CPU temps on the boards with bad caps is usually due to the large voltage ripple on Vcore due to lower capacitances and higher ESRs on the bad caps at the VRM output. The CPU power dissipation rises at least quadratically (maybe even more) with the Vcore voltage - causing the temperature spike, which will eventually lead to CPU failure.
          What saves CPUs from failing even more frequently is the built-in thermal throttling and BIOS-supported power-management modes on some boards. That, and the VRM FETs blowing open or desoldering themselves off the board. If the FETs blow short, there's no way for the CPU to avoid getting cooked.
          • starfury1
            • May 2006
            • 1256
            Men have been hung round these here parts for even mentioning drill bit and MB in the same breath....
            learn the needle method and get a bigger iron for the job if you intend on doing recapping
            Seems the Barton was the straw that broke the "already weakened" camel's back
            Its sad really,
            I often wonder how many people have been down this path and then never found out it was a hardware problem not software.
            How many time Bill Gates got blamed for something which really wasn't his fault (this time)
            Well hope it all staying working for you, but if everything is as it *should be,
            it should stay working
            Cheers and Welcome
            (*like you haven't screwed the via's used the right caps and your solder work is good etc)
            • kiddznet
              • Jul 2010
              • 176
              Hi, newbie here as well
              I like the "get a bigger iron' comment. My iron just wont melt them little suckers tabs out of a Mobo
              How BIG an iron is good for the job?
              939 DualCore AMD Opteron, 1800 MHz (9 x 200)
              Abit AN8 / Fatal1ty AN8 SLI Series
              3072 MB (PC3200 DDR SDRAM)
              ATI Radeon HD 4300/4500 Series (1024 MB
              Lian LI Aluminium mesh case
              • Scenic
                o.O
                • Sep 2007
                • 2642
                try adding solder (preferably leaded.. lower melting point) with flux to the joints first..
                i usually try it first with that method and my 35W iron.. if that's not hot enough (big ground plates on the board) i get out the bigger toys
                • kiddznet
                  • Jul 2010
                  • 176
                  There is a clip on Yootoob somewhere, showing Indian workers melting off ( and putting back on!) components easily with what looks like a small thimble sized electric heated solder filled tub.
                  • kiddznet
                    • Jul 2010
                    • 176
                    Well I got a good iron and replaced a few bulging caps in an old 478 GA board
                    I used Samxon, good cap right?
                    Oh, the joy of hearing the speaker wailing when the board was lit up!
                    In went the ram and away it sped!
                    Thank you for this forum, very encouraging to an old fella.
                    • kiddznet
                      • Jul 2010
                      • 176
                      I am now looking at an EPOX EP4DAI P4 478 board that has several domed 3300 uf 6.5v Teapos
                      Looks like ten in all on the board, pretty cramped line of them beside the CPU. What can I use that is a the same diameter ?. My boy and I want to fiddle with this board and make it go fast, hee hee...
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        You can use* Samxon, GD or GC
                        Rubycon, MBZ or MCZ
                        Sanyo MV-WG
                        Nichicon HM, HN
                        Listed good/better
                        Btw, welcome to the forums and I'm glad to hear you fixed that other board
                        *Also there are more suitable caps you can choose, this is just a small list from memory....
                        • kiddznet
                          • Jul 2010
                          • 176
                          Well I've got me a Duratech 80W chisel tip bad boy
                          Man them caps just FALL out like teeth!
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            As long as all the nearby SMD parts don't "fall out like teeth" too, more power to ya!
                            My teeth don't come out all that easy.
                            Maybe a dental appointment is in order?
                            hehehehe
                            Mann-Made Global Warming.
                            - Dr Seuss
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              I have a 60W iron with a HUGE tip (dunno if it can even be called a tip) which was originally intended for soldering pipes, cases and stuff like that. Takes FOREVER to warm up, but once it does, it makes an easy job of removing those pesky surface mount MOSFETs. Even easier than my fancy new hot air rework station.
                              A working TV? How boring!
                              • shovenose
                                Send Doge Memes
                                • Aug 2010
                                • 6575
                                so can a 25w be successfully used for something like this? it only cost like $20 and it seems good enough for soldering components on but ive never tried a recap with it. would it work?
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  No.
                                  50w-60w minimum if you aren't experienced with mobo's.
                                  Motherboards are thick and that sucks the heat out of the iron faster than a low watt iron can keep up.
                                  You would end up with the iron on the joint for a long time and rather than melting the solder it will slowly heat up the whole board.
                                  An iron with some umpth will melt the solder quick so you can get off the joint before the rest of the board heats up.
                                  Frys electronics has a starter 60 watt for 15 bucks.
                                  http://www.frys.com/product/3317532?...H:MAIN_RSLT_PG
                                  I got one when I was away from home and ended up having to solder something.
                                  They aren't deluxe but they aren't too bad either.
                                  - Dr Seuss
                                    • 31020
                                    no.
                                    because i have a 48w iron that can only just manage on some boards.
                                    • pegdizzler
                                      • Aug 2010
                                      • 19
                                      Interesting that everyone is recommending high wattage irons. I'd like get a hotter guy eventually for "large part" removal.
                                      I use a 40W Weller iron with the small temp-adjusting station. Tip is a very miniature Weller pointy tip, cap is usually free by "rocking" it back and forth 3-4 times. New here as well, wish I would have taken pictures so far before I found this board!
                                      • kiddznet
                                        • Jul 2010
                                        • 176
                                        I find I'm using the 80watt "badboy" for most everything
                                        Trim the cap leads before soldering, bit of flux on the joint. apply iron with a good tinned surface and the solder flows neatly well into the hole, no need to for solder wire, which is good for me as I have one pretty well useless hand.
                                        • kotel studios
                                          Epox EP 85 MVP3C-M - 3.54v Vcore regardless of jumpers
                                          by kotel studios
                                          Recently I got an Epox EP-85 MVP3C-M board from scrap. After fixing the broken caps I powered it on without CPU and the jumpers set to 60Mhz FSB and 2x multiplier.
                                          Sadly, Vcc3 was stuck at 3.54v regardless of jumpers. Vcc2 (Vi/o I think) was also the same voltage.
                                          So, I've returned to the original configuration I got the board in - 100Mhz FSB and 4x multiplier. Voltages haven't changed at all.
                                          What I've tried so far:
                                          replace the original N-MOSFETs with beefier 60V ones for testing
                                          Resolder the resistors near the Vcore Jumper block
                                          Short Vcore...
                                          05-25-2025, 01:46 AM
                                        • kotel studios
                                          Epox EP 8K3A+/8K3A - need specs of 2 caps in DDR1 VRM arena
                                          by kotel studios
                                          Is there anybody here who could tell me what are the two caps marked bellow? Or atleast send me a picture of those two caps from their board. Size wise I think those will be 2200uF10v, the same as in the CPU VRM, but not sure....
                                          01-18-2025, 08:54 AM
                                        • bigbeark
                                          EPOX EP-MGF6100-M No USB Sound
                                          by bigbeark
                                          This is a Socket AM2 Nvdia board with GeForce 6100 chipset.
                                          The Onboard sound does not work if I use USB headphones but does work if I use the mini RCA jack. I did use the USB ports on the actual motherboard.
                                          Made me wonder how USB talks to the audio chip in every other motherboard but not this one. I do find the audio a bit weak. I could replace the small caps near the audio port stack
                                          but I don't expect it to fix the USB sound.
                                          Any ideas on how to fix this? I could just add a PCI audio card but it's nice to have front-panel plug in sound.
                                          02-25-2021, 11:05 PM
                                        • thanghn90
                                          Dell Precision 3450 SFF D15S004
                                          by thanghn90
                                          - Model: Dell Precision 3450 Small Form Factor, D15S004
                                          - Service tag: JT11VH3
                                          - Board model number: TBC0521 CG4MW
                                          - Request: unlock BIOS admin password.
                                          - Reason: 8FC8 code suffix - no public password generator. Full code: JT11VH3-8FC8
                                          I've been searching on 8FC8 BIOS password unlock for a while, and looks like aside from paid service, there is a trick to modify the BIOS dump. However, the unlock script/zip file is long gone, and the instruction is clearly aimed for the more advanced folks.
                                          If you can help providing the "master" password...
                                          09-04-2024, 11:01 AM
                                        • nexttothemoon
                                          Need some help as I'm having possible bad cap issues with an Epox 8RDA3+ mobo.
                                          by nexttothemoon
                                          Ok... my first post here so go easy please.
                                          I had an Epox 8RDA3+ mobo with an Athlon XP 2500+ in a computer that I've used just for basic net surfing, playing music, Excel, Word etc. It was never really a gaming PC so it's always been good enough which is why I've never really upgraded.
                                          Anyway... late last year it started getting sudden restarts and BSOD's and random error messages (that I can remember).
                                          I didn't know what the problem was so I did a bit of online research and figured it must have been the mobo or CPU or PSU. I didn't want to spend...
                                          03-09-2011, 09:51 PM
