Dell XPS 720 H2C
  • compirate
    • Jan 2015
    • 15
    Dell XPS 720 H2C
    I've got a Dell XPS 720 H2C where the motherboard doesn't even post, not even one beep. From what I've read these boards are trouble, hoping just the caps. None show any visible sign of trouble.
    Here's the list of what it has:
    27- 220uF 16v 6.3x11 Rubycon ZLH A0734/5 .22 540
    4 - 680uF 16v 10x12.5 Chemicon KZG 7(T)9X 0.026 1540
    5 - 2200uF 6.3v 10x20 Chemicon KZJ 7(7)9Q .011 2920
    4 - 1800uF 6.3v 8x21 Panasonic FL 79IIEA .016 1870
    3 - 560uF 4v 8x12.5 Sanyo 732SEPC5604
    6 - 4.7uF 50v 5x12 Rubycon NXA bi-polar A0734
    1 - 330uF 16v 10x13 Chemicon C73033016V
    10- 560uF 4v 8x8 Chemicon C78L5604V
    1 - little teeny tiny cramped in hidden one
    From reading here, I should replace anything 680 and higher.
    I've been able to find compatible replacements (I think) for most:
    2200uF - UHN0J222MPD
    1800uF - UHM0J182MPD6
    680uF - UHM1C681MPD
    The 680's aren't available anywhere that I can find right now so my question is (it's about time he got to it!) how far out of spec can you go? I realize lower ohm, higher ripple is good but:
    Mine Badcaps Store
    KZG HZ
    .026 .012
    1540 2280
    In the attached picture, at the bottom where it says '680uF', that connector is for the cooling pump, the connector to the right is the card fan. The connector on the left edge between the 4 220uf is the hard drive fan connector.
    Oops, missed one! North end of east ram connectors, 220uF
    master hoarder
    • May 2008
    • 12175
    Re: Dell XPS 720 H2C
    You can go as much out of spec as the height and width of each capacitor spot allows. In my experience, even 2x to 3x the capacitance was never a problem, and just about every motherboard and video card I have recapped I did so with "non-standard" replacement caps (i.e. whatever I had on hand, which is usually large caps from Xbox 360s). If you use Nichicon HM, HN, and HZ with that logic, you will more than meet the ESR and ripple current requirements of the circuit.
    Another alternative would be to use polymer caps. 470 uF @ 16V might do just fine. I don't see any other large 16V caps on that motherboard, so I assume those 680uF 16V KZGs are for the CPU VRM high side (and it appears so from the picture you posted). On the power supply, what are the colors of the wires going to that connector that pluggs in at the bottom-right of the motherboard?
    • compirate
      • Jan 2015
      • 15
      Thank you for the reply!
      The power connectors are unique to Dells :
      The power supply is either a 750W or 1000W
      Upper left connector, left upper pin is #24, right #12:
      1 +3.3 VDC Orange
      2 +3.3 VDC/SE Orange
      3 COM Black
      4 +5 VDC Red
      5 COM Black
      6 +5 VDC Red
      7 COM Black
      8 POK Gray
      9 +5 VFP Purple
      10 +12 VD DC/SE Yellow/White
      11 +12 VD DC Yellow/White
      12 +3.3 VDC Orange
      13 +3.3 VDC Orange
      14 -12 VDC Blue
      15 COM Black
      16 PS_ON Green
      17 COM Black
      18 COM Black
      19 COM Black
      20 N/C
      21 +5 VDC/SE Red
      22 +5 VDC Red
      23 +5 VDC Red
      24 COM Black
      Lower right connector, upper left #20, right #10
      1 +12 VC DC Blue/White
      2 +12 VC DC Blue/White
      3 COM Black
      4 COM Black
      5 +12 VA DC/SE Yellow
      6 +12 VA DC Yellow
      7 COM Black
      8 COM Black
      9 +12 VB DC/SE White
      10 +12 VB DC White
      11 +12 VC DC/SE Blue/White
      12 COM Black
      13 COM Black
      14 COM Black
      15 +12 VA DC Yellow
      16 COM Black
      17 COM Black
      18 COM Black
      19 +12 VB DC White
      20 NC
      Attached is a line drawing of the motherboard.
        master hoarder
        • May 2008
        • 12175
        So it looks like the lower connector is indeed for powering the CPU, since it has only 12V rails going to it. In that case, those 680 uF 16V KZGs should be for the CPU VRM high side. Most regular motherboards usually employ four 1000-1500 uF caps for that. So if you can't find suitable 680 uF caps, you can go with 820 uF, 1000 uF, 1200 uF, or 1500 uF - that is, as long as cap height is not an issues, because those larger capacity caps will also be bigger. Another tip I'll give you here is that on Mouser (and possibly also Digikey), less popular capacities like 1200 uF can sometimes be cheaper than both 820 uF and 1000 uF caps.
        Here are a few choices that could work for your 16V 680 uF KZG:
        (perfect match)
        https://www.badcaps.net/store/produc...roducts_id=178
        (1000 uF)
        https://www.badcaps.net/store/produc...roducts_id=174
        (1500 uF)
        https://www.badcaps.net/store/produc...roducts_id=139
        (820 uF polymers)
        https://www.badcaps.net/store/produc...roducts_id=135
        • compirate
          • Jan 2015
          • 15
          Sorry for the delay, thanks for the reply. Now to order the parts and cross my fingers!
          • compirate
            • Jan 2015
            • 15
            Yea! Parts finally showed up (1/23). Came from Carrollton, Tx to Capitol Heights, Md to Lexington Park, Md, back to Capitol Heights then to me! Only an extra 180 miles trip for them Now to clear off this workbench and fire up the ol' soldering iron!
            • compirate
              • Jan 2015
              • 15
              Well that didn't do it
              still stuck posting at "initializing power management" (post error 10h), if i read this post code card correctly - shows last successful code). Wish I knew how to fix that
                master hoarder
                • May 2008
                • 12175
                Sorry to hear it didn't work out. :\
                But that's electronics repair for you - sometimes it works and other times it doesn't and you have to troubleshoot it more.
                If you want to troubleshoot it more, I guess the next item to check would be all of the power rails. Besides the 4 toroidal coils next to the CPU socket, there are three more - one by the RAM modules (lower-left of your picture), another by the SATA ports, and one more next to the Northbridge (?) right in the center of the picture above. Those coils indicate buck-type power rails and they are the most likely to have a problem if the board had bad caps. You can also see two TO-252 MOSFETs next to each coil.
                If you have a multimeter, the easiest way to check these rails is to measure the voltage they are outputting. One of the two MOSFETs next to each coil will have its tab connected to that power rail (but not both). For this reason, check the voltage on the tabs of both MOSFETs for each rail, and post what results you get here.
                The coil next to the RAM slots is likely going to be for the RAM, so probably should see 1.8V. The coil next to the SATA slots could be for the Northbridge or the Southbridge, so I can't say exactly what voltage to expect, but we can figure out if its right or not by knowing what chipsets the motherboard uses and checking those chipets' datasheets. Finally, the coil in the center of the picture next to the Northbridge is likely for the Northbridge only. Probably around 1 to 1.2V.
                • c_hegge
                  • Sep 2009
                  • 5219
                  These boards do have nvidia bumpgate chipsets. That's also a possibility.
                  • bcgrogbc
                    • Jun 2015
                    • 8
                    So were the UHM0J182MPD6 a good replacement for the 1800uF 6.3v 8x21 Panasonic FL?
                      master hoarder
                      • May 2008
                      • 12175
                      ^ Should be.
                      HM and FL are about equivalent.
                      • c_hegge
                        • Sep 2009
                        • 5219
                        Yup. I don't think the caps were ever the problem. It's usually the chipsets that go wrong with these boards, as there are known manufacturing defects with them.
                        • HTR-Informatique
                          Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                          by HTR-Informatique
                          YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                          I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                          On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                          I also changed the screen because the PC fell and the screen was broken.
                          I changed the battery with a new and original battery.
                          I also had corrosion/oxidation on the...
                          02-09-2025, 06:51 AM
                        • Bowline
                          by Bowline
                          06-11-2025, 10:13 AM
                        • jake-b
                          dell e6540 boots to black screen (no dell logo)
                          by jake-b
                          good morning all,
                          i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
                          01-08-2024, 10:29 AM
                        • Swedishpower
                          Dell G3 15 3500 black screen
                          by Swedishpower
                          Hello
                          I have search everywhere for a solution for my problem, but cant find it anywhere.
                          When I was away to trow some garbage i always look in the electronic bin.
                          and this time i find a laptop.
                          Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
                          the lamp for charmig is white.
                          Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
                          but no Dell logo.
                          I tryed with a hdmi cable to another screen, still black.
                          I started to search solution and tryed...
                          07-06-2025, 06:18 AM
                        • hcinne
                          Dell G15 ryzen edition black screen 2 amber 1 white
                          by hcinne
                          I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                          07-23-2024, 07:56 AM
