Sharing a component-level repair log on an ASUS GeForce RTX 4060 Dual OC that came across the bench with liquid damage and a hard power fault. Initial Assessment & Cold Rail Measurements
(Bench photos of the trace jumper and reworked stage attached below)
- Symptom: Card caused the ATX host bench power supply to trip over-current protection (OCP) immediately upon power-up.
- Visual Inspection: Evidence of localized water ingress and corrosion around the main input stage and power delivery circuitry, with a physically blown PCB trace near the 12V input filter section.
- Cold Resistance Sweep:
- Main 12V PCIe power rail measured 1.8 Ω to ground—indicating a severe short circuit rather than normal input filtering impedance.
- Tracing the 12V Short:
- A 1.8 Ω measurement on the main 12V rail typically points to a punctured high-side MOSFET (bridging the 12V input directly into the low-resistance VCore/VRAM core phase inductors).
- Isolated the short down to the high-side MOSFET on the affected phase.
- Desoldering the failed FET confirmed the diagnosis: off-board testing of the transistor showed drain-to-source punch-through, and the 12V rail resistance to ground on the board immediately bounced out of the shorted state.
- Decoupling MLCC Cleanup:
- The localized water intrusion also compromised several ceramic decoupling capacitors (MLCCs) on the associated rail.
- Removed the corroded and thermally degraded MLCCs, cleaned the solder pads, and populated fresh replacement capacitors.
- Trace Repair:
- Cleaned and prepped the severed 12V trace where the initial fault current had blown the copper open.
- Bridged the broken section with enamel-insulated jumper wire, securely tied into the source copper pads, and sealed with UV conformal solder mask.
- Power Stage Replacement:
- Installed a replacement high-side MOSFET on the cleaned pads and verified that gate-to-source and drain-to-source resistances were within spec across all phases.
- Cold Resistance Check Post-Rework:
- 12V rail measured back in normal high-resistance territory (no direct continuity to ground).
- Phase inductors and secondary rails showed expected baseline readings.
- Bench Power-Up:
- Powered up on the bench supply via a test riser; current draw normalized with no rail collapse or over-current tripping.
- The card initialized cleanly, outputted video, and passed stress-testing without thermal runaway on the rebuilt phase.
