Hi everyone, I need some insight as to what's causing this problem.
I was repairing an HP EliteDesk 800 G3 SFF that powers on but doesn't POST. I figured it was a corrupted BIOS, so I tried HP's BIOS/EC recovery first, but no luck—I couldn't even get the "Sure Start" screen to appear.
So here is the exact sequence of what I did:
I had another working unit, so I figured I would lift the BIOS flash first and transplant it as a diagnosis to see if I could get the broken unit to POST. But nothing happened. Upon hitting the power button, the fan would just spin. I left it overnight and still got nothing.
Then, I noticed another flash chip on the board and tried transferring that as well, but still got nothing. So I removed everything and installed those chips back onto that first donor unit. The exact moment those chips were reinstalled back into it, that supposed working donor stopped working entirely and started having the exact same symptoms as the first machine. From there, it developed into a weird cycle: it would turn itself on automatically upon connecting the power, and after a minute or so, it would turn off and then turn back on again.
I dumped both of the BIOS files from the machines and ran them against MEAnalyzer
Because of that, I ended up getting another working donor unit. From this new donor, I removed the two flash chips—the 8MB one and the 16MB one. I dumped the contents multiple times and verified them multiple times to ensure I got a good dump. I then reinstalled those chips right back onto this second donor to ensure I didn't break it as well (and thankfully, it still worked), and then wrote the dump onto the unit under repair. Still nothing—same issue.
Then, after multiple rounds of testing—checking voltages, components, and continuity, and re-flashing the chips—it finally developed into a 5.2 error, which HP says means "EC cannot find a valid firmware."
I'm at a loss here. I measured everything I could think of and cross-checked it against the working unit.
Maybe one of you guys can point me in the right direction.
