BMAX B5A Pro fast fan spin + power led but not starting
  • dbuergi
    • Jul 2024
    • 200
    • Deutschland
    • tinkering, gym, basketball
    since i can exclude a bios fault i'm looking for a hardware problem on this one. I got this mini pc with no power and a blown up mosfet with damaged ground bad. I cleaned everything and drilled the area until the short was gone and i was able to rebuild everything.
    When i plug in the power supply the power led turns directly on and i get the fan on full speed but nothing else. I can power the board off with the button.
    The coils don't show any voltages and other measurements are marked on the picture.
    There are no hotspot on the board and with voltage injection of 1v and 1a on the big coils i get 1v and 0,6a output and the CPU is getting warm.
    On the EN pin of the RT3663BM PWM chip i only get 0,3v so maybe there is something wrong with the enable signal? Shouldn't it be 3,3v? So maybe anything i can try or should i replace the RT3663?
  • devicefixer
    • Feb 2026
    • 30
    • China
    Click image for larger version  Name:	25540.jpg Views:	56 Size:	1.31 MB ID:	3863516
    I feel like you really need to try and track down a schematic or boardview for this exact motherboard. You drilled into the board, so we have to determine if there were any internal traces running through the layers of that burned area.
    If there were internal traces, how many? If it only involved a few traces and they don't route directly into the inner layers of the main chip (CPU/PCH), this board is still salvageable, but it will definitely require running jumper wires.
    My advice is to stop guessing. Sticking to a standard, logical troubleshooting sequence will actually be much faster. Check the schematic to see exactly which traces passed through that drilled zone and what components they connected to. Run jumper wires to reconstruct those lines first to completely rule out any broken trace issues .
    Once you've ruled out broken traces, look at the schematic to see what that blown MOSFET was actually responsible for. Is it critical? If it's for a minor, non-essential circuit, you might be able to ignore it. But if it's an important rail, you need to mount a replacement MOSFET—either in the original spot or secured somewhere empty on the board—and run jumper wires from its pins to the corresponding components.
    After doing that, the physical reconstruction is basically done. If it still doesn't POST or give a display after these repairs, then you move on to checking your power sequence to see if all the rails are coming up. Just take it step by step.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • zlr8r
      Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
      by zlr8r
      hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
      Ill try and give as much info as I can.
      Dell Inspiron 17 (7786) Laptop
      Service Tag: 5J0NHT2
      Bios: 1.9.0
      When I received this , it would only flicker on the KB backlight for a second, then off and on.
      Then it started getting weirder!
      Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
      12-12-2023, 09:31 PM
    • justice171
      Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
      by justice171
      I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
      Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
      1. Verified that all critical voltages are present:
        • 3.3V and 5V are always present if DC is plugged.
        • 1.8V on the BIOS chip is present.
      2. Checked the power button functionality:
        • When pressed, the voltage drops to 0V, indicating the button is functional.
      3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
        • Confirmed connectivity is intact, ruling out issues
      11-26-2024, 12:39 AM
