Minisforum G7 PT 7945 direct power on, fast fan spin but no display
  • dbuergi
    • Jul 2024
    • 200
    • Deutschland
    • tinkering, gym, basketball
    since i already flashed the bios chip without any success there must be something else wrong and i hope you can help me to solve this fault.
    When i insert the power connector the PC starts and the CPU fan blasts at full speed. GPU is not doing anything.
    I have all voltages present and no shorts.
    When i press the power button the CPU reaches 90C in some seconds and the PC turns off / in standby. The PCU starts to make cheeping noise during this process. As mentioned i rewrote the bios chip, checked bios battery, made a reset and cleaned RAM contacts.
    Can this fault be caused by a faulty ITE IT8613E? And if so it is possible to replace / program it?
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • dbuergi
    BMAX B5A Pro fast fan spin + power led but not starting
    by dbuergi
    since i can exclude a bios fault i'm looking for a hardware problem on this one. I got this mini pc with no power and a blown up mosfet with damaged ground bad. I cleaned everything and drilled the area until the short was gone and i was able to rebuild everything.
    When i plug in the power supply the power led turns directly on and i get the fan on full speed but nothing else. I can power the board off with the button.
    The coils don't show any voltages and other measurements are marked on the picture.
    There are no hotspot on the board and with voltage injection...
    04-27-2026, 08:04 AM
  • PantherDave
    by PantherDave
    Hi all!
    05-29-2024, 02:01 PM
  • GLISIT
    by GLISIT
    01-16-2025, 02:29 PM
  • justice171
    Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
    by justice171
    I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
    Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
    1. Verified that all critical voltages are present:
      • 3.3V and 5V are always present if DC is plugged.
      • 1.8V on the BIOS chip is present.
    2. Checked the power button functionality:
      • When pressed, the voltage drops to 0V, indicating the button is functional.
    3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
      • Confirmed connectivity is intact, ruling out issues
    11-26-2024, 12:39 AM
