macbook pro a2141 20v 0.04A
  • som_b1
    • May 2024
    • 21
    • Ukraine
    Hi. Help!!! I'm at a dead end. I removed the faulty SSD,
    removed the U9580,
    removed all the coils that power the SSD,
    removed the U9500,
    replaced others the cd3217,
    reflashed other the U2980
    and still on the board 20V 0.04A.
    There is no DFU!!!
    here are the measurements on the board:
    -P1V8_SLPS2R = 1.8V
    -PP1V1_SLPS2R = 1.1V
    -PP0V8_SLPS2R = 0.8V
    -LDO_RTC = 1.5V
    -PMU_SYS_ALIVE = 1.78V
    -PPVBUS_USBC_XA (B105 U3100) = 19–20V
    -PP3V3_G3H_RTC_X (near U3100) = 3.3V​
    -USBC_XA_USB_TOP_P = 2.3V
    -USBC_XA_USB_TOP_N = 3.3V​
    -TBT_X_SPI_CLK ≈ 0.15V
    -TSPI_MOSI ≈ 0.35V​ other pins on u2890 3.3v? ub090 equally
  • som_b1
    • May 2024
    • 21
    • Ukraine
    Don't have 5v on both sides maiboard (cd3217 does not do 5v).
    • PITERPENY
      • Jul 2023
      • 527
      • Ukraine
      • microelektronics
      did you manage to solve the problem?
      • som_b1
        • May 2024
        • 21
        • Ukraine
        hello. I got to the point that the reason is in the SSD. I removed everything, I don't have a donor yet and this board is on pause. When I do, I will definitely update
        • sofles
          Macbook Pro 16" A2141 screen artefacts, kernel panic
          by sofles
          Hi there.
          I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
          I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
          Now situation looks like this, If...
          02-05-2025, 05:05 AM
        • PITERPENY
          Macbook pro 16" A2141 not updated
          by PITERPENY
          Hi. I've encountered this problem for the first time. I need help. Has anyone encountered it before and how did you solve it? Only MacOS Catalina can be installed on a MacBook via online recovery, and the Mac works fine (although it's also running slowly). But when I try to update the MacBook, it constantly crashes, and nothing else works except Catalina. Attempts to install Venture or Monterey Jack from an external drive are also impossible. I tried DFU recovery, but I can still only install Catalina and can't update, even though the system offers to update to Tahoe. It's impossible to run any...
          04-19-2026, 12:41 PM
        • TechSplendid
          MacBook A2442 not powering on – suspecting CD3217, but replacement didn’t help
          by TechSplendid
          Hi All,
          I'm working on a MacBook Pro A2442 (14", 2021) that's not powering on. On two out of three USB-C ports, I get 5V and the current briefly ramps up to around 0.210A before dropping to 0.036A. On the third port (JF600), I only get 0.0045A and it stays there.
          Initially, I suspected a faulty CD3217 on that port, especially since I noticed signs of previous liquid damage near the JF600 USB connector. I replaced the CD3217 with an UF400 (from an A2442 donor board from the same location). According to the supplier, this should be a compatible version, but the behavior...
          04-09-2025, 02:13 AM
        • Arshad alam4659
          MACBOOK PRO A2141 SSD SHORT
          by Arshad alam4659
          I HAVE A MACBOOK PRO A2141 820-01700 THIS BOARD IS PP2V5_NAND_SSD1 SHORT TO GROUND THEN I CHECK ONE SIDE U8600 IS SHORT THIS SIDE IS ONLY ONE CHIP U8600 OTHER SIDE
          PP2V5_NAND_SSD1 IS OK AND U9100 U9200 U9300 U9400 IS ALSO OK Will removing the U8600 fix the board or will I have to install a new one
          Link to boardview --> https://www.badcaps.net/forum/troubl...91#post1449091
          10-01-2024, 08:26 AM
        • JONNY0998
          MacBook Pro A2338 M1 – No power CD3217 suspected: 5V/20V cycling,
          by JONNY0998
          Hi guys, sorry for my bad English and my lack of experience, I'm a beginner. I'm working on this A2338 M1 board with the following behavior:
          5V ↔ 20V, 0.20A in a continuous cycle.
          It never stays at a stable 20V.
          At first, it seemed to depend on the connector orientation, but later the issue became constant. I don't know how, but once it successfully negotiated 20V at 2.0A without any intervention. However, when I tried to power it on, it returned to the initial behavior.
          I've already tried connecting it to another MacBook using Apple Configurator,...
          04-26-2026, 04:28 PM
