Hi everyone, I'm trying to repair an old Mac Mini from 2012. From a purely economic standpoint, it's obviously not worth it, but I'm more interested in the learning experience. The board is an 820-2366-C, and I haven't been able to find any schematics or .brd-files for it. When I connect it to the power supply, the fan runs at maximum speed, but nothing else happens. No beep, no LEDs. The power supply voltage is stable at the input connector. I'm measuring several shorts at SMD capacitors, but I can't pinpoint where the short is. A borrowed thermal imaging camera shows no abnormalities. What's the best way to proceed?
Repair MacMini 2012 for practice
Tags: None
I still have mine also. It has been running Catalina v10.15.x lately
It's the Intel-i5 model. A few years ago, I finally upgraded the ram to 8gb (still in dual channel)
I upgraded it's main-drive to a SATA-3/600 SSD within a few months of owning it back then. The old 500gb spinning-HDD went into a small USB-3.0 external-enclosure for Time Machine backups.
Surprisingly, Apple included Mac-Mini_6,1 in their CA-2023 updates. -
The fan spinning at maximum speed simply means the motherboard isn't functioning properly—the most basic operating conditions for the circuits haven't been met. This is the fundamental operating principle and power sequence for all computers. You should try the following steps:Hi everyone, I'm trying to repair an old Mac Mini from 2012. From a purely economic standpoint, it's obviously not worth it, but I'm more interested in the learning experience. The board is an 820-2366-C, and I haven't been able to find any schematics or .brd-files for it. When I connect it to the power supply, the fan runs at maximum speed, but nothing else happens. No beep, no LEDs. The power supply voltage is stable at the input connector. I'm measuring several shorts at SMD capacitors, but I can't pinpoint where the short is. A borrowed thermal imaging camera shows no abnormalities. What's the best way to proceed?
1. Check the isolation/protection circuit: You said the input voltage is stable, but is it passing through the isolation MOSFETs? Find the main current sensing resistor and measure the voltage there. If PPBUS_G3H is not present or too low, your DC-in MOSFETs are not opening.
2. Check the SMC power supply: This is the "Always On" 3.42V rail. If this is missing or shorted, the SMC won't initialize properly. Measure the inductor for this specific circuit.
3. Check the 3V/5V standby voltages: Measure the resistance to ground and the voltage on the large inductors (coils) for the 3.3V and 5V rails. A short on the 3.3V line is extremely common and will prevent the board from waking up.
If all these checks come back normal, then the CPU side might be dead. However, the vast majority of issues lie in the preceding power supply stages. You need to measure their resistance to ground to rule them out step by step.
As for using a thermal imaging camera... well... that's mostly for finding direct shorts. In my experience, very few people use thermal cameras for computer motherboard repair unless it's a tiny, hard-to-detect short. It's used a lot more in mobile phone repair nowadays.
Our boardview, bios, and schematic bot.Comment
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
i know that in linear power supply the noise will be very low comparing to SMPS supply.... -
by AmardilloLecroy power supply - this power supply is prone to failures. I have repaired mine a couple of times before. The problems with this power supply range from shorted out power mosfet, the green module pwm driver, aging EMI filter, shorted snubber etc.
I once dismantled a custom component that I cannot identify, no way of knowing if it was the cause, and thus I have no way of checking it. However the power supply can still power up and supply properly without this component.
This Component is not shown in the Schematic but apparently it is side piggy back mounted on the EMI filter as... - Loading...
