gtx1060 Chip resistance
This topic has been answered.
  • chj4591
    • Aug 2022
    • 40
    • 대한민국
    gtx1060
    Do you want to know the chip resistance value?
    Is this resistance FBD_ZQ2?
  • Answer selected by chj4591 at 01-07-2026, 03:55 AM.
    Cardinal Fang
    • Dec 2025
    • 50
    This is not the exact same card, but it is a 1060 and the resistor in the same circuit has the same ID, so it is probably fairly safe bet that it is the same component.
    from page 14:
    • Cardinal Fang
      • Dec 2025
      • 50
      from page 14:
      • chj4591
        • Aug 2022
        • 40
        • 대한민국
        thank you
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
        • DynaxSC
          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
          by DynaxSC
          Hi
          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
          08-04-2025, 12:20 PM
          Common SPI bios chip programming Questions and Answers
          by SMDFlea
          Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
          A: If you can`t read from it how do you expect to write to it ?.
          Q: Why is my bios chip unreadable ?.
          A: The programmer is faulty or has a worn or broken zif socket.
          The USB cable is frayed,connector pins worn or some other physical damage.
          Not enough amperage or voltage to power the programmer properly.
          Bad...
          09-02-2021, 04:40 PM
        • Berun
          HP EliteDesk 800 G6 mini - BIOS Chip (GD25B127DSIG) replacement after epic fail :D
          by Berun
          Hello All,
          I tried to read the the BIOs chip(GD25B127DSIG) on the mainbord of an HP EliteDesk 800 G6 mini, because the BIOs had an Admin Lock and I got the "HP Endpoint Security Problem" Screen at every startup which is not very useful when I want to use the PC as a Compute Unit for my home media system somewhere in the cellar, so it should perform a restart without any interactions.
          I only have the CH341APro Programmer available and did the 3V hardware Mod on it before I tried to read the BIOS chip.
          I read the Chip on board 8 times (with power...
          04-09-2026, 06:24 AM
        • chonkyrabbit
          Need help disassembling xx30 thinkpad battery BMS chip firmware
          by chonkyrabbit
          Hi there,
          I need some help reverse engineering a BMS chip from a battery for an xx30 thinkpad. The Laptop uses a challenge-response type of system to verify if a battery is genuine:
          The laptop writes four bytes to 0x3C and then reads 0x3C. The battery responds with "Lenovo JapanXXXX", with the Xs corresponding to four response bytes. For example "0xDC 0x42 0x5B 0x82" to BMS => "Lenovo Japan0x9F 0x76 0x97 0x2E" from BMS.
          What I know so far:
          • It's an 51F51 BMS chip based on the R2J24020F group. Karosium has already figured out how to dump
          01-21-2026, 10:32 AM
