hello, I encountered an issue with the mac mini a1347 mid 2011 with the motherboard model being 631-1740. I tried to upgrade its dual hdd setup with ssds and upgrade the ram to 16gb. I also took apart the whole thing to replace the thermal paste. after putting everything together, it refuses to power on. I have no idea what the issue is and no idea where to start. I did check the voltage at the motherboard connector and I do get 12 volts. what else should I check?
mac mini 2011 a1347 631-1740 no power
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by mrrubikHi all,
I have a very strange issue with a HP Elitedesk 800 G6 mini (35W) unit - I acquired it as a barebones unit (no CPU/RAM/SSD), when plugging in power without any of this, I receive the correct 3 long, 5 short beeps (CPU initialization error).
I acquired the correct CPU for this, an i5-10500T and 8GB of RAM, after installing it into the motherboard:- Plugging in power adapter does not trigger auto-initialize (quick fan spin/power on check), the AMBER LED below motherboard does blink to indicate power connected
- Pressing power button does not turn unit on, the white
08-23-2025, 09:22 AM -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... - Loading...
