A few days ago, I bought a PC for €45, sold “for parts.”
It came with a Ryzen 5 2600, a Be Quiet! Pure Rock Slim cooler, an MSI B450 A-PRO, 16 GB RAM, a GTX 1060, and an Aerocool KCAS 550G PSU.
The seller didn’t know if it worked because it had been sitting in a basement for about a year. I took the gamble because I enjoy repairing things.
When it arrived, surprisingly the PC booted perfectly (into BIOS, since there was no storage).
Only visible issues: GPU fans were dead and a few USB pins were slightly bent (I fixed those easily).
I updated the BIOS to the latest non-beta version (7B86vAH, 2022).
Update went flawlessly, the system rebooted, and the BIOS correctly showed the new version.
I didn’t have any storage at that moment, so I ordered an NVMe SSD and set the PC aside. One week later, I install the SSD, power it on… and the PC turns on for one millisecond and instantly shuts off.
Of course, I removed the SSD again → still nothing.
I suspected the PSU.
Tried another PSU → nothing.
Another power cable → nothing.
Boot without GPU → nothing.
Boot without RAM → nothing.
Tried another CPU → still nothing.
Basically, the motherboard is completely dead.
With only motherboard + CPU + PSU + cooler + one RAM stick, I get absolutely nothing.
No motherboard fans (CPU_FAN / SYS_FAN), no LEDs, no POST, no reaction to the power button.
Strange behavior depending on the CPU installed:
• With the original Ryzen 5 2600: the board produced a faint, regular buzzing sound in the bottom-left area, near the Nuvoton NCT6797D-M chip.
• With a Ryzen 5 3600: no buzzing at all, but the CPU instantly heats up the moment I turn the PSU ON… even without pressing the power button.
I removed the CMOS battery, tried a new one, reset the BIOS → nothing.
I also tried flashing an older BIOS using the Flash BIOS button on the board → no success.
I only get three quick white flashes and then nothing.
Tried with four different USB sticks, USB 2.0, properly formatted, correct filename (MSI.ROM).
Do you have any idea what could have happened? Is the board completely trash?
I looked for physical damage (capacitors, resistors, VRM) but everything looks normal.
It’s extremely frustrating because the system was working perfectly just a few days earlier.
I know repairing a B450 board isn’t really worth the money (they go for ~€50 here in France), but I’d at least like to understand the root cause.
If anyone has suggestions or tests I should try, I’m open to anything.
Thanks in advance!
Thanks in advance!
