Asus TUF X570 GAMING PLUS Motherboard BIOS fix
  • rockman97
    • Aug 2025
    • 10
    • Hungary
    I had my old motherboard i really want build a HTPC and i want use this mobo but i tried BIOS update in 2024 and the motherboard is cooked it get orange led only tried change cpu ram everything but can't fixit. (I bought the motherabord second hand in 2023.)
    It has a Winbond 25Q256JWEQ (I think this is a 1.8V model so i used the 1.8v adapter aswell.) Bios chip on it i tried reflash with my EZP2019+ programmer but when i manually choose a chip like similar to this i click the read button and only shows 000 and i can erase it when i try write i can't verify it.
    I have a clip and i want use this i can't solder the chip.
    Which chip is similar to this Winbond chip or how can i fix this?
    Can i flash this type of chip with this programmer and how?
    I have a BIOS file from ASUS Website.
    Thanks for the help.
    • 21649
    You can try to add chip support - https://www.badcaps.net/forum/troubl...ro-programmers
    Slow the speed down to 6Mhz as well
    • rockman97
      • Aug 2025
      • 10
      • Hungary
      I tried download the windows version but it says the file was removed. I can't install on linux. I asked the forum you linked me aswell hope i can reprogram this chip i tried 6mhz but the same result.
      • m1ch43lzm
        • Mar 2019
        • 780
        • Peru
        Add chip support to EZP2019, EZP2019...ro Programmers
        I downloaded the EZP2019+ software from the linked site, I attached them to my post in that thread
        When using a clip, it takes several tries to align it properly, there's a Test button, it should read the Chip ID (EF6019)
        Use the 1.8V adapter, manually select W25Q256FW
        Click image for larger version  Name:	ezp2019+.png Views:	0 Size:	54.7 KB ID:	3712639
        • rockman97
          • Aug 2025
          • 10
          • Hungary
          Thanks i try again with this. When i click the test button it shows 32 code and cant recognize the chip.
          • DynaxSC
            • Apr 2021
            • 473
            • Poland
            Make sure to disconnect mobo from PSU, disconnect monitor, take out CPU and CMOS backup battery. All this can disturb reading the chip. If all this does not help only way is to desolder the chip, or ...
            ...use a CH-341 programmer, they are very good for in-circuit programming. In-circuit means often powering 1/3 of the board electronics, so programmer must be capable to deliver significant power on VCC, normal programmers might not be able to deliver so much power. Also CH-341 costs really peanuts, so no cost issue.
            Recently I found an information, that bios vendors offer custom bios chips with undocumented protection functions, so it is not possible to erease or change bios contents without a custom SPI control sequence. I have described such a case I had recently here, I believe the reason I can't erease/modify the bios in my case is just such a custom made SPI chip. And this is also an 1.8V chip.
            • rockman97
              • Aug 2025
              • 10
              • Hungary
              Thank you for the info i will buy this type of programmer but now i don't hade time to got this yet. My main issue nomatter what hardware i put this mobo it stuck orange led.
              • glovecaps
                Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                by glovecaps
                I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                11-25-2024, 04:23 PM
              • oragano
                ASUS ex-b250-V7 motherboard bios corrupted - by me
                by oragano
                hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
                So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
                i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
                10-17-2024, 02:53 AM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • throwaway327
                by throwaway327
                Model No: RC72LA
                Serial No: SBNVKD001014459
                06-18-2025, 05:52 PM
              • eastcoastcomputing
                Please help Asus ROG G713QY-K4005T (SN: MANRKD03332840C), motherboard ref: G713-6050A3254002-MB-A01 (A1) Bios
                by eastcoastcomputing
                Hi there,
                I have an Asus G713QY that won't boot. The machine fire up to a black screen, no post but everything seems to check out on the board. I believe the motherboard needs the bios reloaded but I can't find the bios file. I've looked on the Asus website but what is available for download is the .exe to run in windows (which won't help). I've tried to unzip it but can't see the bios file that I need. Can anyone share the bios file for an Asus ROG G713QY-K4005T (SN: MANRKD03332840C), motherboard ref: G713-6050A3254002-MB-A01 (A1). Thanks
                02-21-2024, 04:32 AM
