X570 AORUS MASTER - won't post with BIOS past F22 (rev.1.2)
  • Mirenia
    • Jan 2024
    • 53
    I've got a strange issue with a X570 AORUS MASTER Rev. 1.2 motherboard. The owner (my cousin in law) told me that over time he got more and more bluescreens until the board won't boot/post anymore.
    It showed only post codes "C8, C3" and won't boot
    I found a few things:
    - cpu was faulty/dead (For further tests I replaced it with my own ryzen 7 3700X)
    - with new cpu motherboard only runs on BIOS version F22 and below
    -> And windows only runs stable if I set PCIe in BIOS settings to Gen 3. On automatic settings I got random bluescreens and USB ports and onboard LAN/WLAN won't work (showed power failure error in windows device manager)
    - with BIOS F30 and above the "C8, C3" post code issue returns (flashing with Q-flash plus)
    What could be responsible for this behavior?
    Main power rail voltages are fine.
    The only thing what got my attention was a very low resistance on PM_1VSOC/PCHIO (only 3 Ohms, but reading of 1V was fine and stable) -> comes from Chipset/PCH side
    But I don't know if this is too low or not?
    I also tried different CPUs and memory/RAM, another power supply and different graphic cards
  • DynaxSC
    • Apr 2021
    • 473
    • Poland
    Probably chipset is degraded, I think 3 ohms is quite low. Don't have much experience with AMD chipsets, but comparing to Intel, 1V power line has min. 25-60 ohms. Further AMD chipsets are much more simple compared to Intel, so theoretically should be much less power hungry and have higher resistances on power supply lines.
    The fact that the power voltage is stable says nothing, as the vrms used for chipset power supply usually are an "overkill" and can handle a few Amps current, so 3 ohms is no issue for them (3 ohms mean only 0,33A current at 1V voltage).
    The good thing on AMD chipsets is they are much cheaper then Intel chipsets, and the BGA replacement is much easier, as the solder ball grid is quite less condensed then on Intel. The replacement is quite easy and almost always succesful, contrary to Intel which is a pain.
    To go sure you might also try to reprogram the BIOS chip with a hardware programmer by hard using a stock image. Sometimes the BIOS image gets corrupted in areas which are not reprogrammed during normal BIOS or Flashback upgrade. Remember to do a backup of the old BIOS, as it might contain some individual motherboard data, like board serial, UUID, MAC Address, etc. which afterwards should be manually transferred to a stock, non-personalized BIOS image (DMI data).
    • Mirenia
      • Jan 2024
      • 53
      Thank you for your detailed answer!
      Already did a reflash of the BIOS Chip(s) with my chip programmer but the behavior stays the same as with flashing them via q-flash plus.
      I came to the same conclusion as you that the X570 chipset itself could be partially shorted or so.
      The resistance increases a lot if I put something cold (testet it with IPA and cold spray) on it.
      -> Then I've got a reading of 56 ohms.
      -> As soon as the chip goes back to room temperature its drastically decreasing back to 3 ohms.
      I also checked resistance directly after shutting down power while the chip was still on working temperature and the reading then said only 1.8 ohms.
      I learned that this is a 100% sign of a bad chipset.
      (If not, please correct me.)
      P.S: Tried a BGA replacement once on an old XBOX 360 board. It was a horrible desaster with lot's of damaged pads. (learned: a preheater is neccessary for this kind of repairs )
      Normal components are no problem for me to desolder/solder with hot air... But for BGAs I have to purchase or DIY some preheating device first.
      So this board stays with me and I'll try it as soon as I am skilled enough
      • sect-sin
        Gigabyte XT 6800 XT Aorus Master BIOS needed
        by sect-sin
        I have an AORUS MASTER RX 6800 XT (non USB-C version), and my problem is that FUSION RGB is not working, it is not finding the GPU, and the RGB lights are off. There is a new firmware on the Gigabyte site which is supposed to fix this exact issue, but their Firmware upgrade does not work (I just get the highly unhelpful Erasing Flash Failed message when trying to update). I tried various internet-recommended software fixes to address this, but nothing helped, the factory Gigabyte EXE refuses to flash the BIOS.
        My last resort would really be flashing the...
        10-13-2023, 06:08 AM
      • macabook
        by macabook
        🧩 Initial Issue
        07-24-2025, 02:17 PM
        by Vesko356
        08-11-2023, 03:27 AM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • zenius
        by zenius
        12-08-2024, 06:13 AM
