How to: CPU Socket Reflow
  • SteveNielsen
    Retired Tech
    • 2327
    Re: How to: CPU Socket Reflow
    Originally posted by jbonetwo
    that is some useful info there, thanks!
    I did not forget to try this. the air from the heat gun kept blowing the solder wire off the board so i gave up.
    tried it again just now with a piece of solder wire propped up against the cpu socket on a dead motherboard. blasted it with the heat gun till the board started to make popping sounds :S.
    the wire curled into a ball fairly quickly and was malleable at the end but it did not melt in any sense of the word.
    Use a piece of solder long enough to bend at an angle then the air won't roll it off.
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • chth96
      Is it good to use chemistronic flux off es835b for flux remover?
      by chth96
      I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
      Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
      11-17-2023, 07:25 AM
    • Isabella91
      Possible to convert eMMC Socket to a micro SD Card socket?
      by Isabella91
      I have seen many posts where the eMMC can be read via a SD card reader, however can the opposite be achieved?
      Read/Write a Micro SD Card from an eMMC Socket.
      I have a Motherboard with a Kingston BGA153 ball socket, using HS400 bus mode, which is 8bit, as Micro SD is usually 1bit or 4bit mode, I accept that a loss of speed in read/write will occur, but I would sill like to convert.
      Theoretically speaking, Im thinking if I hard solder DAT0-3 from eMMC to SD Card Reader, this should force 4-bit mode, or only DAT0 to force 1-bit mode.
      Not to remove...
      01-14-2024, 05:10 PM
    • warsztat
      Acer AN515-57-577G JDIMM1 socket not working.
      by warsztat
      Hello, Acer AN515-57-577G JDIMM1 socket does not work. GH51G LA-L181P, 2x DDR4 RAM, both good, both work well in JDIMM2, neither works in JDIMM1. The laptop displays BIOS, when the JDIMM2 socket is occupied, you can run Linux on USB, then everything seems to work ok, there is internet access and you can browse the contents of the 512 GB SSD in Windows, but starting Windows ends with an eternal spinning circle, maybe there are corrupted files. When the RAM is inserted into the JDIMM1 socket, the laptop starts but there is no image and the downloaded current does not change and the output is ~2.25A....
      11-18-2024, 09:13 AM
    • tony359
      Reflow equipment
      by tony359
      Hello all,
      I am experimenting a bit with reflowing larger components - ideally I'd like to reflow a PS4 APU or a GPU for example.
      I know it's impossible to reflow such large components with just hot air so I bought a pre-heating plate, T-8280 classic Chinese machine, which seems to be working fine besides it's a little slow, which shouldn't be a big deal.
      Now, my hot air station is a Aoyue 852A++ and I feel it's a bit weak when used with larger nozzle. I tried reflowing a laptop chipset using one of those large, rectangular, nozzles and I failed miserably,...
      12-25-2021, 01:29 PM
