OEM DELL RTX3080 - after memory reflow, working then dead.
  • petr.hlavacu
    • Nov 2020
    • 11
    • CZ
    Hello, I got my RTX3080 from DELL. The problem was that in the load appeared artifacts and then BSOD or straight reboot PC.
    I tested the memory using MATS and no errors were found. So I assumed it was a cracked solder ball under one of the video memories.
    I reflowed the memory, and the card started working. It worked for about 2 days, and then after about 2-3hrs of load, the monitor suddenly shut down, and since then it can't post anymore. Temperatures were normal the whole time.
    Is this the definite end for this card?​
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • YellowJacket
    DELL Latitude 5410 - dead; pwrbtn flashing
    by YellowJacket
    Hi folks,
    DELL Latitude 5410, board number FDZ41 LA-J371P Rev: 1.0 (A00), schematic uploaded in different post, here is the link --> https://www.badcaps.net/filedata/fetch?id=3484415
    When I connect it to a power ( DELL round charger, or USB-C ), LED on the power button starts flashing white, and the laptop doesn't do anything ( flashing slows for a very brief time in time when I press it, but it continues again ). Battery is not charging. While the charger is connected, I have few voltages present, but some of them are fluctuating, see attached pictures.
    All I was able...
    04-26-2025, 07:05 AM
  • tracks
    Dell 3080 Micro BIOS dead
    by tracks
    Hello all,
    I have a Dell 3080 Micro with a problem. As it is right now, it seems to be boot looping, maybe... There's no output, just fan on and power led lights up and blinks off every 2 seconds or so.
    Previous owner told me he bought it with a BIOS password, he tried to use a CH341A programmer with some random test clip and tried to mess with it while it was powered on. Now it won't boot.
    I tried to dump the bios with an EZP2023+ but I can't get a consistent read. Every time the dump is different, so it's unusable. I think the BIOS chip is fried.
    04-19-2025, 03:42 PM
  • max-power
    Dell E6540 laptop completely dead after dssasembly
    by max-power
    Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
    that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
    After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
    03-24-2025, 08:49 AM
  • diamon
    Dell Latitude 5520 completely dead
    by diamon
    I have bought a not complete and defective Dell Latitude 5520 for parts (needed the networkconnector (RJ45) to repair a other board).
    Have repaired the other board (Dell Latitude 5540) and I wanted to know if I could find out what is wrong with the 5520 board (SouthPeak15 TGL MB 8L 19819-1) and perhaps repair this one also.
    After connecting the USB-C charger (both USB-C ports on the laptop, does not have an other option) and pressing the power button, nothing happens (no lights or fans, no capslock).
    Have checked with a thermal camera, and there are a couple of things...
    03-05-2025, 02:23 PM
